Remaining BSP Build Failures
Wed Aug 27 15:02:58 UTC 2014
Hi
Hesham.. or1k is missing a method.
Ric.. any chance you can fix the virtex5 compile failure?
Others  please review and see what you can help with.
I attempted to build all BSPs over night with this configuration:
../rtems/configure --target=@CPU at -rtems4.11 \
  --prefix=/home/joel/rtems-4.11-work/bsp-install/ \
  --disable-multiprocessing --disable-cxx --disable-rdbg \
  --enable-maintainer-mode --enable-tests --enable-networking \
  --enable-posix --disable-itron --disable-deprecated \
  --disable-ada --disable-expada --enable-rtemsbsp=@BSP@
Although not printed, SMP was enabled in the configure command
echoed in the output. :(
The results were better than last time:
arm/nds:
../../../../../nds/lib/librtemsbsp.a(startup.rel): In function `boot_card':
:(.text+0x19c): multiple definition of `boot_card'
init.o:init.c:(.text+0x70): first defined here
collect2: error: ld returned 1 exit status
gmake[6]: *** [spinternalerror01.exe] Error 1
I think that's because it makes a set of .rel's and ends up pulling in
a chunk of binary instead of individual files for the BSP. I think I
can fix this one.
avr/avrtest: Compiler error. Reported as
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=62284
nios2/nios2_iss: Compilation error which I think means that
the newlib version needs to be bumped in the RSB.
../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c: In function
'dwmac_desc_enh_destroy_tx_desc':
../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c:814:
warning: implicit declaration of function '__DEVOLATILE'
warning: nested extern declaration of '__DEVOLATILE'
../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c:814: error:
expected expression before 'void'
warning: initialization makes pointer from integer without a cast
'dwmac_desc_enh_release_tx_bufs':
../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c:850: error:
or1k/or1ksim:  Port Missing methods
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/testsuites/sptests/spcontext01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcontext01/init.c:42:
undefined reference to `_CPU_Context_validate'
init.o: In function `clobber_and_switch_timer':
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/testsuites/sptests/spcontext01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcontext01/init.c:118:
undefined reference to `_CPU_Context_volatile_clobber'
powerpc/virtex5: BSP missing method
/users/joel/rtems-4.11-work/rtems-testing/rtems/build-powerpc-virtex5-rtems/powerpc-rtems4.11/c/virtex5/lib/libcpu/powerpc/../../../../../../../rtems/c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c:85:
undefined reference to `BSP_Convert_decrementer'
