Remaining BSP Build Failures
Hesham Moustafa heshamelmatary at gmail.com
Wed Aug 27 15:54:42 UTC 2014
Hi,
On Wed, Aug 27, 2014 at 5:02 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Hi
> Hesham.. or1k is missing a method.
Yes, I am aware of that, I will add missing methods just after I
submit another RSB patch for or1ksim.
> Ric.. any chance you can fix the virtex5 compile failure?
> Others  please review and see what you can help with.
> I attempted to build all BSPs over night with this configuration:
> ../rtems/configure --target=@CPU at -rtems4.11 \
>   --prefix=/home/joel/rtems-4.11-work/bsp-install/ \
>   --disable-multiprocessing --disable-cxx --disable-rdbg \
>   --enable-maintainer-mode --enable-tests --enable-networking \
>   --enable-posix --disable-itron --disable-deprecated \
>   --disable-ada --disable-expada --enable-rtemsbsp=@BSP@
> Although not printed, SMP was enabled in the configure command
> echoed in the output. :(
> The results were better than last time:
> arm/nds:
> ../../../../../nds/lib/librtemsbsp.a(startup.rel): In function `boot_card':
> :(.text+0x19c): multiple definition of `boot_card'
> init.o:init.c:(.text+0x70): first defined here
> collect2: error: ld returned 1 exit status
> gmake[6]: *** [spinternalerror01.exe] Error 1
> I think that's because it makes a set of .rel's and ends up pulling in
> a chunk of binary instead of individual files for the BSP. I think I
> can fix this one.
> avr/avrtest: Compiler error. Reported as
> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=62284
> nios2/nios2_iss: Compilation error which I think means that
> the newlib version needs to be bumped in the RSB.
> ../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c: In function
> 'dwmac_desc_enh_destroy_tx_desc':
> ../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c:814:
> warning: implicit declaration of function '__DEVOLATILE'
> warning: nested extern declaration of '__DEVOLATILE'
> ../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c:814: error:
> expected expression before 'void'
> warning: initialization makes pointer from integer without a cast
> 'dwmac_desc_enh_release_tx_bufs':
> ../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c:850: error:
> or1k/or1ksim:  Port Missing methods
> /users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/testsuites/sptests/spcontext01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcontext01/init.c:42:
> undefined reference to `_CPU_Context_validate'
> init.o: In function `clobber_and_switch_timer':
> /users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/testsuites/sptests/spcontext01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcontext01/init.c:118:
> undefined reference to `_CPU_Context_volatile_clobber'
> powerpc/virtex5: BSP missing method
> /users/joel/rtems-4.11-work/rtems-testing/rtems/build-powerpc-virtex5-rtems/powerpc-rtems4.11/c/virtex5/lib/libcpu/powerpc/../../../../../../../rtems/c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c:85:
> undefined reference to `BSP_Convert_decrementer'
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
