Remaining BSP Build Failures
Wed Aug 27 16:44:19 UTC 2014
On 8/27/2014 11:34 AM, Ric Claus wrote:
> Hi Joel,
>   Sorry, but unfortunately I no longer have the ability or time to work on Virtex5 since we moved to Zynqs.  If someone else can't take it over, I think you have no choice but to deprecate it.
I understand. This may not be hard to remember though. It is really a simple
method. It looks like the clock tick was using the shared decrementer
driver.
If so, then this from the beatnik BSP should work:
#define BSP_Convert_decrementer( _value ) \
  ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) *
1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long
long) (_value)))
> 	Ric
> On Aug 27, 2014, at 8:02 AM, Joel Sherrill wrote:
>> Hi
>> Hesham.. or1k is missing a method.
>> Ric.. any chance you can fix the virtex5 compile failure?
>> Others  please review and see what you can help with.
>> I attempted to build all BSPs over night with this configuration:
>> ../rtems/configure --target=@CPU at -rtems4.11 \
>>  --prefix=/home/joel/rtems-4.11-work/bsp-install/ \
>>  --disable-multiprocessing --disable-cxx --disable-rdbg \
>>  --enable-maintainer-mode --enable-tests --enable-networking \
>>  --enable-posix --disable-itron --disable-deprecated \
>>  --disable-ada --disable-expada --enable-rtemsbsp=@BSP@
>> Although not printed, SMP was enabled in the configure command
>> echoed in the output. :(
>> The results were better than last time:
>> arm/nds:
>> ../../../../../nds/lib/librtemsbsp.a(startup.rel): In function `boot_card':
>> :(.text+0x19c): multiple definition of `boot_card'
>> init.o:init.c:(.text+0x70): first defined here
>> collect2: error: ld returned 1 exit status
>> gmake[6]: *** [spinternalerror01.exe] Error 1
>> I think that's because it makes a set of .rel's and ends up pulling in
>> a chunk of binary instead of individual files for the BSP. I think I
>> can fix this one.
>> avr/avrtest: Compiler error. Reported as
>> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=62284
>> nios2/nios2_iss: Compilation error which I think means that
>> the newlib version needs to be bumped in the RSB.
>> ../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c: In function
>> 'dwmac_desc_enh_destroy_tx_desc':
>> ../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c:814:
>> warning: implicit declaration of function '__DEVOLATILE'
>> warning: nested extern declaration of '__DEVOLATILE'
>> ../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c:814: error:
>> expected expression before 'void'
>> warning: initialization makes pointer from integer without a cast
>> 'dwmac_desc_enh_release_tx_bufs':
>> ../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c:850: error:
>> or1k/or1ksim:  Port Missing methods
>> /users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/testsuites/sptests/spcontext01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcontext01/init.c:42:
>> undefined reference to `_CPU_Context_validate'
>> init.o: In function `clobber_and_switch_timer':
>> /users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/testsuites/sptests/spcontext01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcontext01/init.c:118:
>> undefined reference to `_CPU_Context_volatile_clobber'
>> powerpc/virtex5: BSP missing method
>> /users/joel/rtems-4.11-work/rtems-testing/rtems/build-powerpc-virtex5-rtems/powerpc-rtems4.11/c/virtex5/lib/libcpu/powerpc/../../../../../../../rtems/c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c:85:
>> undefined reference to `BSP_Convert_decrementer'
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
