Remaining BSP Build Failures
Ric Claus claus at slac.stanford.edu
Wed Aug 27 17:56:34 UTC 2014
Thank you, Joel.  I really appreciate it!
Ric
On Aug 27, 2014, at 10:55 AM, Joel Sherrill wrote:
> I just fixed the virtex5. The missing code was pretty simple and
> I just used the code from another BSP. That leaves:
> avr/avrtest:
>   GCC PR 62284
> nios2/nios2_iss:
>   Needs new toolset but binutils 2.20 has bug and won't assemble
>   some code produced by gcc 4.9.1. Reported on binutils mailing list.
> or1k/or1ksim:
>   Hesham knows and this will get fixed.
> I will now start a build with POSIX, Networking, and SMP disabled but
> tests enabled to see if that breaks anything.
> --joel
> On 8/27/2014 11:44 AM, Joel Sherrill wrote:
>> On 8/27/2014 11:34 AM, Ric Claus wrote:
>>> Hi Joel,
>>>  Sorry, but unfortunately I no longer have the ability or time to work on Virtex5 since we moved to Zynqs.  If someone else can't take it over, I think you have no choice but to deprecate it.
>> I understand. This may not be hard to remember though. It is really a simple
>> method. It looks like the clock tick was using the shared decrementer
>> driver.
>> If so, then this from the beatnik BSP should work:
>> #define BSP_Convert_decrementer( _value ) \
>>  ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) *
>> 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long
>> long) (_value)))
>>> 	Ric
>>> On Aug 27, 2014, at 8:02 AM, Joel Sherrill wrote:
>>>> Hi
>>>> Hesham.. or1k is missing a method.
>>>> Ric.. any chance you can fix the virtex5 compile failure?
>>>> Others  please review and see what you can help with.
>>>> I attempted to build all BSPs over night with this configuration:
>>>> ../rtems/configure --target=@CPU at -rtems4.11 \
>>>> --prefix=/home/joel/rtems-4.11-work/bsp-install/ \
>>>> --disable-multiprocessing --disable-cxx --disable-rdbg \
>>>> --enable-maintainer-mode --enable-tests --enable-networking \
>>>> --enable-posix --disable-itron --disable-deprecated \
>>>> --disable-ada --disable-expada --enable-rtemsbsp=@BSP@
>>>> Although not printed, SMP was enabled in the configure command
>>>> echoed in the output. :(
>>>> The results were better than last time:
>>>> arm/nds:
>>>> ../../../../../nds/lib/librtemsbsp.a(startup.rel): In function `boot_card':
>>>> :(.text+0x19c): multiple definition of `boot_card'
>>>> init.o:init.c:(.text+0x70): first defined here
>>>> collect2: error: ld returned 1 exit status
>>>> gmake[6]: *** [spinternalerror01.exe] Error 1
>>>> I think that's because it makes a set of .rel's and ends up pulling in
>>>> a chunk of binary instead of individual files for the BSP. I think I
>>>> can fix this one.
>>>> avr/avrtest: Compiler error. Reported as
>>>> https://gcc.gnu.org/bugzilla/show_bug.cgi?id=62284
>>>> nios2/nios2_iss: Compilation error which I think means that
>>>> the newlib version needs to be bumped in the RSB.
>>>> ../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c: In function
>>>> 'dwmac_desc_enh_destroy_tx_desc':
>>>> ../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c:814:
>>>> warning: implicit declaration of function '__DEVOLATILE'
>>>> warning: nested extern declaration of '__DEVOLATILE'
>>>> ../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c:814: error:
>>>> expected expression before 'void'
>>>> warning: initialization makes pointer from integer without a cast
>>>> 'dwmac_desc_enh_release_tx_bufs':
>>>> ../../../../../rtems/c/src/libchip/network/dwmac-desc-enh.c:850: error:
>>>> or1k/or1ksim:  Port Missing methods
>>>> /users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/testsuites/sptests/spcontext01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcontext01/init.c:42:
>>>> undefined reference to `_CPU_Context_validate'
>>>> init.o: In function `clobber_and_switch_timer':
>>>> /users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/testsuites/sptests/spcontext01/../../../../../../../rtems/c/src/../../testsuites/sptests/spcontext01/init.c:118:
>>>> undefined reference to `_CPU_Context_volatile_clobber'
>>>> powerpc/virtex5: BSP missing method
>>>> /users/joel/rtems-4.11-work/rtems-testing/rtems/build-powerpc-virtex5-rtems/powerpc-rtems4.11/c/virtex5/lib/libcpu/powerpc/../../../../../../../rtems/c/src/lib/libcpu/powerpc/mpc6xx/timer/timer.c:85:
>>>> undefined reference to `BSP_Convert_decrementer'
>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>> Support Available                (256) 722-9985
