[RSB] QEMU build fails
Hesham Moustafa heshamelmatary at gmail.com
Wed Aug 27 21:15:04 UTC 2014
Hi,
I was trying to build QEMU bare-metal package (just to imitate its
scripts to create a similar or1ksim one) and I got the following
error:
RTEMS Source Builder - Set Builder, v0.4.0
Build Set: devel/qemu
Build Set: devel/autotools-internal.bset
config: devel/autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-linux-gnu-1
Creating source directory: sources
download: ftp://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz ->
sources/autoconf-2.69.tar.gz
downloading: sources/autoconf-2.69.tar.gz - 1.8MB of 1.8MB (100%)
building: autoconf-2.69-x86_64-linux-gnu-1
config: devel/automake-1.12.6-1.cfg
error: automake-1.12.6-1.cfg:13: macro '%{rtems_automake_version}' not found
warning: switched to dry run due to errors
error: cannot expand default macro: %{rtems_automake_version} in
"automake-%{rtems_automake_version}.tar.gz"
Build FAILED
Build Set: Time 0:00:11.816999
I am using fedora 20 distro and latest RSB repo.
Regards,
Hesham
