[RSB] [PATCH 2/2] Add support for building bare-metal or1ksim.
Hesham ALMatary
heshamelmatary at gmail.com
Thu Aug 28 17:14:34 UTC 2014
This patch adds support to enable RSB to build or1ksim emulator
(the main OpenRISC 1000 simulator) from latest or1ksim github repo.
bare/config/devel/or1ksim-1.1.0.cfg | 16 ++++++++++
bare/config/devel/or1ksim.bset | 7 +++++
source-builder/config/or1ksim-1-1.cfg | 57 +++++++++++++++++++++++++++++++++++
3 files changed, 80 insertions(+)
create mode 100644 bare/config/devel/or1ksim-1.1.0.cfg
create mode 100644 bare/config/devel/or1ksim.bset
create mode 100644 source-builder/config/or1ksim-1-1.cfg
diff --git a/bare/config/devel/or1ksim-1.1.0.cfg b/bare/config/devel/or1ksim-1.1.0.cfg
new file mode 100644
index 0000000..bfd1a44
--- /dev/null
+++ b/bare/config/devel/or1ksim-1.1.0.cfg
@@ -0,0 +1,16 @@
+# or1ksim emulator 1.1.0
+%if %{release} == %{nil}
+%define release 1
+%endif
+%include %{_configdir}/base.cfg
+%define or1ksim_version 1.1.0
+# The or1ksim build instructions. We use 1.x.x Release 1.
+%include %{_configdir}/or1ksim-1-1.cfg
diff --git a/bare/config/devel/or1ksim.bset b/bare/config/devel/or1ksim.bset
index 0000000..2941553
--- /dev/null
+++ b/bare/config/devel/or1ksim.bset
@@ -0,0 +1,7 @@
+# Build set for or1ksim emulator
+%define release 1
+devel/or1ksim-1.1.0
diff --git a/source-builder/config/or1ksim-1-1.cfg b/source-builder/config/or1ksim-1-1.cfg
index 0000000..30dfe13
--- /dev/null
+++ b/source-builder/config/or1ksim-1-1.cfg
@@ -0,0 +1,57 @@
+# or1ksim 1.x.x Version 1.
+# This configuration file configure's, make's and install's or1ksim.
+%define release 1
+%endif
+Name: or1ksim-1.1.0
+Summary: or1ksim-github
+Version: %{or1ksim_version}
+Release: %{release}
+URL: https://github.com/openrisc/or1ksim
+BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
+# Source
+%source set or1ksim https://github.com/openrisc/or1ksim/archive/or1k-master.zip
+# Prepare the source code.
+%prep
+ build_top=$(pwd)
+ %source setup or1ksim -q -n or1ksim-or1k-master
+ cd ${build_top}
+%build
+ build_top=$(pwd)
+ cd or1ksim-or1k-master/
+ ../or1ksim-or1k-master/configure \
+ --target=or1k-elf \
+ --prefix=%{_prefix} \
+ CFLAGS="-O0 -DINLINE=static -DNO_SOFTFLOAT_UNUSED"
+ %{__make} %{?_smp_mflags} all$
+ cd ${build_top}
+%install
+ build_top=$(pwd)
+ rm -rf $SB_BUILD_ROOT
+ %{__make} DESTDIR=$SB_BUILD_ROOT PREFIX=%{_prefix} install
+ cd ${build_top}
1.9.3
