[PATCH 1/2] capture: Split user extension methods out.
Jennifer Averett
jennifer.averett at oarcorp.com
Thu Aug 28 17:55:31 UTC 2014
cpukit/libmisc/Makefile.am | 3 +-
cpukit/libmisc/capture/capture.c | 428 +++--------------------
cpukit/libmisc/capture/capture_user_extension.c | 435 ++++++++++++++++++++++++
cpukit/libmisc/capture/captureimpl.h | 195 +++++++++++
4 files changed, 673 insertions(+), 388 deletions(-)
create mode 100644 cpukit/libmisc/capture/capture_user_extension.c
create mode 100644 cpukit/libmisc/capture/captureimpl.h
diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
index bc9edd0..ee7745d 100644
--- a/cpukit/libmisc/Makefile.am
+++ b/cpukit/libmisc/Makefile.am
@@ -18,7 +18,8 @@ EXTRA_DIST += capture/README
noinst_LIBRARIES += libcapture.a
libcapture_a_SOURCES = capture/capture.c capture/capture-cli.c \
- capture/capture.h capture/capture-cli.h
+ capture/capture_user_extension.c \
+ capture/capture.h capture/captureimpl.h capture/capture-cli.h
## cpuuse
EXTRA_DIST += cpuuse/README
diff --git a/cpukit/libmisc/capture/capture.c b/cpukit/libmisc/capture/capture.c
index 9ec07b8..54b2894 100644
--- a/cpukit/libmisc/capture/capture.c
+++ b/cpukit/libmisc/capture/capture.c
@@ -29,7 +29,7 @@
-#include "capture.h"
+#include "captureimpl.h"
@@ -57,46 +57,6 @@
#define RTEMS_CAPTURE_RECORD_EVENTS (0)
#endif
-static bool
-rtems_capture_create_task (rtems_tcb* current_task,
- rtems_tcb* new_task);
-static void
-rtems_capture_start_task (rtems_tcb* current_task,
- rtems_tcb* started_task);
-static void
-rtems_capture_restart_task (rtems_tcb* current_task,
- rtems_tcb* restarted_task);
-static void
-rtems_capture_delete_task (rtems_tcb* current_task,
- rtems_tcb* deleted_task);
-static void
-rtems_capture_switch_task (rtems_tcb* current_task,
- rtems_tcb* heir_task);
-static void
-rtems_capture_begin_task (rtems_tcb* begin_task);
-static void
-rtems_capture_exitted_task (rtems_tcb* exitted_task);
-static void
-rtems_capture_terminated_task (rtems_tcb* terminated_task);
- * Global capture flags.
-#define RTEMS_CAPTURE_ON (1U << 0)
-#define RTEMS_CAPTURE_NO_MEMORY (1U << 1)
-#define RTEMS_CAPTURE_OVERFLOW (1U << 2)
-#define RTEMS_CAPTURE_TRIGGERED (1U << 3)
-#define RTEMS_CAPTURE_READER_ACTIVE (1U << 4)
-#define RTEMS_CAPTURE_READER_WAITING (1U << 5)
-#define RTEMS_CAPTURE_GLOBAL_WATCH (1U << 6)
-#define RTEMS_CAPTURE_ONLY_MONITOR (1U << 7)
* RTEMS Capture Data.
@@ -110,7 +70,6 @@ static uint32_t capture_flags;
static rtems_capture_task_t* capture_tasks;
static rtems_capture_control_t* capture_controls;
static int capture_extension_index;
-static rtems_id capture_id;
static rtems_capture_timestamp capture_timestamp;
static rtems_task_priority capture_ceiling;
static rtems_task_priority capture_floor;
@@ -118,18 +77,6 @@ static rtems_id capture_reader;
static rtems_interrupt_lock capture_lock =
RTEMS_INTERRUPT_LOCK_INITIALIZER("capture");
-static const rtems_extensions_table capture_extensions = {
- .thread_create = rtems_capture_create_task,
- .thread_start = rtems_capture_start_task,
- .thread_restart = rtems_capture_restart_task,
- .thread_delete = rtems_capture_delete_task,
- .thread_switch = rtems_capture_switch_task,
- .thread_begin = rtems_capture_begin_task,
- .thread_exitted = rtems_capture_exitted_task,
- .fatal = NULL,
- .thread_terminate = rtems_capture_terminated_task
* RTEMS Event text.
@@ -151,11 +98,43 @@ static const char* capture_event_text[] =
"TIMESTAMP"
+void rtems_capture_set_extension_index(int index)
+ capture_extension_index = index;
+int rtems_capture_get_extension_index(void)
+ return capture_extension_index;
+uint32_t rtems_capture_get_flags(void)
+ return capture_flags;
+void rtems_capture_set_flags(uint32_t mask)
+ capture_flags |= mask;
+rtems_capture_task_t* rtems_capture_find_capture_task( rtems_id ct_id )
+ rtems_capture_task_t* ct;
+ for (ct = capture_tasks; ct; ct = ct->forw) {
+ if (ct->id == ct_id)
+ break;
+ return ct;
* This function returns the current time. If a handler is provided
* by the user get the time from that.
-static inline void
+void
rtems_capture_get_time (rtems_capture_time_t* time)
if (capture_timestamp)
@@ -290,7 +269,7 @@ rtems_capture_refcount_down (rtems_capture_task_t* task)
* This function setups a stack so its usage can be monitored.
-static inline void
+void
rtems_capture_init_stack_usage (rtems_capture_task_t* task)
if (task->tcb)
@@ -378,7 +357,7 @@ rtems_capture_create_control (rtems_name name, rtems_id id)
* This function create the task control.
-static inline rtems_capture_task_t*
rtems_capture_create_capture_task (rtems_tcb* new_task)
rtems_interrupt_lock_context lock_context;
@@ -456,7 +435,7 @@ rtems_capture_create_capture_task (rtems_tcb* new_task)
* is 0 and the tcb has been cleared signalling the task has been
* deleted.
-static inline void
+void
rtems_capture_destroy_capture_task (rtems_capture_task_t* task)
if (task)
@@ -487,7 +466,7 @@ rtems_capture_destroy_capture_task (rtems_capture_task_t* task)
* This function records a capture record into the capture buffer.
-static inline void
+void
rtems_capture_record (rtems_capture_task_t* task,
uint32_t events)
@@ -550,7 +529,7 @@ rtems_capture_record (rtems_capture_task_t* task,
* See if we have triggered and if not see if this event is a
* cause of a trigger.
-static bool
+bool
rtems_capture_trigger (rtems_capture_task_t* ft,
rtems_capture_task_t* tt,
uint32_t events)
@@ -616,328 +595,12 @@ rtems_capture_trigger (rtems_capture_task_t* ft,
- * This function is called when a task is created.
-static bool
- rtems_capture_task_t* ct;
- rtems_capture_task_t* nt;
- ct = current_task->extensions[capture_extension_index];
- * The task pointers may not be known as the task may have
- * been created before the capture engine was open. Add them.
- if (ct == NULL)
- ct = rtems_capture_create_capture_task (current_task);
- * Create the new task's capture control block.
- nt = rtems_capture_create_capture_task (new_task);
- if (rtems_capture_trigger (ct, nt, RTEMS_CAPTURE_CREATE))
- rtems_capture_record (ct, RTEMS_CAPTURE_CREATED_BY_EVENT);
- rtems_capture_record (nt, RTEMS_CAPTURE_CREATED_EVENT);
- return 1 == 1;
- * This function is called when a task is started.
-static void
- * Get the capture task control block so we can trace this
- * event.
- rtems_capture_task_t* st;
- st = started_task->extensions[capture_extension_index];
- if (ct == NULL)
- if (st == NULL)
- st = rtems_capture_create_capture_task (started_task);
- if (rtems_capture_trigger (ct, st, RTEMS_CAPTURE_START))
- rtems_capture_record (ct, RTEMS_CAPTURE_STARTED_BY_EVENT);
- rtems_capture_record (st, RTEMS_CAPTURE_STARTED_EVENT);
- rtems_capture_init_stack_usage (st);
- * This function is called when a task is restarted.
-static void
- * event.
- rtems_capture_task_t* rt;
- rt = restarted_task->extensions[capture_extension_index];
- if (ct == NULL)
- if (rt == NULL)
- rt = rtems_capture_create_capture_task (restarted_task);
- if (rtems_capture_trigger (ct, rt, RTEMS_CAPTURE_RESTART))
- rtems_capture_record (ct, RTEMS_CAPTURE_RESTARTED_BY_EVENT);
- rtems_capture_record (rt, RTEMS_CAPTURE_RESTARTED_EVENT);
- rtems_capture_task_stack_usage (rt);
- rtems_capture_init_stack_usage (rt);
- * This function is called when a task is deleted.
-static void
- * event.
- rtems_capture_task_t* dt;
- dt = deleted_task->extensions[capture_extension_index];
- if (ct == NULL)
- if (dt == NULL)
- dt = rtems_capture_create_capture_task (deleted_task);
- if (rtems_capture_trigger (ct, dt, RTEMS_CAPTURE_DELETE))
- rtems_capture_record (ct, RTEMS_CAPTURE_DELETED_BY_EVENT);
- rtems_capture_record (dt, RTEMS_CAPTURE_DELETED_EVENT);
- rtems_capture_task_stack_usage (dt);
- * This task's tcb will be invalid. This signals the
- * task has been deleted.
- dt->tcb = 0;
- rtems_capture_destroy_capture_task (dt);
- * This function is called when a task is begun.
-static void
- * event.
- rtems_capture_task_t* bt;
- bt = begin_task->extensions[capture_extension_index];
- if (bt == NULL)
- bt = rtems_capture_create_capture_task (begin_task);
- if (rtems_capture_trigger (NULL, bt, RTEMS_CAPTURE_BEGIN))
- rtems_capture_record (bt, RTEMS_CAPTURE_BEGIN_EVENT);
- * This function is called when a task is exitted. That is
- * returned rather than was deleted.
-static void
- * event.
- rtems_capture_task_t* et;
- et = exitted_task->extensions[capture_extension_index];
- if (et == NULL)
- et = rtems_capture_create_capture_task (exitted_task);
- if (rtems_capture_trigger (NULL, et, RTEMS_CAPTURE_EXITTED))
- rtems_capture_record (et, RTEMS_CAPTURE_EXITTED_EVENT);
- rtems_capture_task_stack_usage (et);
- * This function is called when a termination request is identified.
-static void
- * event.
- rtems_capture_task_t* tt;
- tt = terminated_task->extensions[capture_extension_index];
- if (tt == NULL)
- tt = rtems_capture_create_capture_task (terminated_task);
- if (rtems_capture_trigger (NULL, tt, RTEMS_CAPTURE_TERMINATED))
- rtems_capture_record (tt, RTEMS_CAPTURE_TERMINATED_EVENT);
- rtems_capture_task_stack_usage (tt);
- * This function is called when a context is switched.
-static void
- * Only perform context switch trace processing if tracing is
- * enabled.
- if (capture_flags & RTEMS_CAPTURE_ON)
- rtems_capture_time_t time;
- * Get the cpature task control block so we can update the
- * reference and perform any watch or trigger functions.
- rtems_capture_task_t* ht;
- if (_States_Is_dormant (current_task->current_state))
- rtems_id ct_id = current_task->Object.id;
- for (ct = capture_tasks; ct; ct = ct->forw)
- if (ct->id == ct_id)
- break;
- else
- if (ct == NULL)
- ht = heir_task->extensions[capture_extension_index];
- if (ht == NULL)
- ht = rtems_capture_create_capture_task (heir_task);
- * Update the execution time. Assume the time will not overflow
- * for now. This may need to change.
- rtems_capture_get_time (&time);
- * We could end up with null pointers for both the current task
- * and the heir task.
- if (ht)
- ht->in++;
- ht->time_in = time;
- if (ct)
- ct->out++;
- if (ct->time_in)
- ct->time += time - ct->time_in;
- if (rtems_capture_trigger (ct, ht, RTEMS_CAPTURE_SWITCH))
- rtems_capture_record (ct, RTEMS_CAPTURE_SWITCHED_OUT_EVENT);
- rtems_capture_record (ht, RTEMS_CAPTURE_SWITCHED_IN_EVENT);
* This function initialises the realtime capture engine allocating the trace
* buffer. It is assumed we have a working heap at stage of initialisation.
rtems_status_code
rtems_capture_open (uint32_t size, rtems_capture_timestamp timestamp __attribute__((unused)))
- rtems_name name;
rtems_status_code sc;
@@ -961,22 +624,13 @@ rtems_capture_open (uint32_t size, rtems_capture_timestamp timestamp __attribu
capture_ceiling = 0;
capture_floor = 255;
- * Register the user extension handlers for the CAPture Engine.
- name = rtems_build_name ('C', 'A', 'P', 'E');
- sc = rtems_extension_create (name, &capture_extensions, &capture_id);
+ sc = rtems_capture_user_extension_open();
if (sc != RTEMS_SUCCESSFUL)
- capture_id = 0;
free (capture_records);
capture_records = NULL;
- else
- capture_extension_index = rtems_object_id_get_index (capture_id);
* Iterate over the list of existing tasks.
@@ -1016,7 +670,7 @@ rtems_capture_close (void)
* release the resources we have without them being used.
- sc = rtems_extension_delete (capture_id);
+ sc = rtems_capture_user_extension_close();
return sc;
diff --git a/cpukit/libmisc/capture/capture_user_extension.c b/cpukit/libmisc/capture/capture_user_extension.c
new file mode 100644
index 0000000..f3bebc8
--- /dev/null
+++ b/cpukit/libmisc/capture/capture_user_extension.c
@@ -0,0 +1,435 @@
+ Copyright Objective Design Systems Pty Ltd, 2002
+ All rights reserved Objective Design Systems Pty Ltd, 2002
+ Chris Johns (ccj at acm.org)
+ COPYRIGHT (c) 1989-2009.
+ On-Line Applications Research Corporation (OAR).
+ The license and distribution terms for this file may be
+ found in the file LICENSE in this distribution.
+ This software with is provided ``as is'' and with NO WARRANTY.
+ RTEMS Performance Monitoring and Measurement Framework.
+ This is the Capture Engine component.
+rtems_status_code rtems_capture_user_extension_open(void);
+rtems_status_code rtems_capture_user_extension_close(void);
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <stdlib.h>
+#include <string.h>
+#include <rtems/rtems/tasksimpl.h>
+#include <rtems/score/statesimpl.h>
+#include <rtems/score/todimpl.h>
+ * RTEMS Capture User Extension Data.
+static rtems_id capture_id;
+static bool
+rtems_capture_create_task (rtems_tcb* current_task,
+ rtems_tcb* new_task);
+static void
+rtems_capture_start_task (rtems_tcb* current_task,
+ rtems_tcb* started_task);
+static void
+rtems_capture_restart_task (rtems_tcb* current_task,
+ rtems_tcb* restarted_task);
+static void
+rtems_capture_delete_task (rtems_tcb* current_task,
+ rtems_tcb* deleted_task);
+static void
+rtems_capture_switch_task (rtems_tcb* current_task,
+ rtems_tcb* heir_task);
+static void
+rtems_capture_begin_task (rtems_tcb* begin_task);
+static void
+rtems_capture_exitted_task (rtems_tcb* exitted_task);
+static void
+rtems_capture_terminated_task (rtems_tcb* terminated_task);
+static const rtems_extensions_table capture_extensions = {
+ .thread_create = rtems_capture_create_task,
+ .thread_start = rtems_capture_start_task,
+ .thread_restart = rtems_capture_restart_task,
+ .thread_delete = rtems_capture_delete_task,
+ .thread_switch = rtems_capture_switch_task,
+ .thread_begin = rtems_capture_begin_task,
+ .thread_exitted = rtems_capture_exitted_task,
+ .fatal = NULL,
+ .thread_terminate = rtems_capture_terminated_task
+ rtems_status_code sc;
+ rtems_name name;
+ int index;
+ * Register the user extension handlers for the CAPture Engine.
+ name = rtems_build_name ('C', 'A', 'P', 'E');
+ sc = rtems_extension_create (name, &capture_extensions, &capture_id);
+ if (sc != RTEMS_SUCCESSFUL)
+ capture_id = 0;
+ else {
+ index = rtems_object_id_get_index (capture_id);
+ rtems_capture_set_extension_index( index );
+ return sc;
+ sc = rtems_extension_delete (capture_id);
+ return sc;
+ * This function is called when a task is created.
+static bool
+ rtems_capture_task_t* nt;
+ int index = rtems_capture_get_extension_index();
+ ct = current_task->extensions[index];
+ * The task pointers may not be known as the task may have
+ * been created before the capture engine was open. Add them.
+ if (ct == NULL)
+ ct = rtems_capture_create_capture_task (current_task);
+ * Create the new task's capture control block.
+ nt = rtems_capture_create_capture_task (new_task);
+ if (rtems_capture_trigger (ct, nt, RTEMS_CAPTURE_CREATE))
+ rtems_capture_record (ct, RTEMS_CAPTURE_CREATED_BY_EVENT);
+ rtems_capture_record (nt, RTEMS_CAPTURE_CREATED_EVENT);
+ return 1 == 1;
+ * This function is called when a task is started.
+static void
+ * Get the capture task control block so we can trace this
+ * event.
+ rtems_capture_task_t* st;
+ st = started_task->extensions[index];
+ if (ct == NULL)
+ if (st == NULL)
+ st = rtems_capture_create_capture_task (started_task);
+ if (rtems_capture_trigger (ct, st, RTEMS_CAPTURE_START))
+ rtems_capture_record (ct, RTEMS_CAPTURE_STARTED_BY_EVENT);
+ rtems_capture_record (st, RTEMS_CAPTURE_STARTED_EVENT);
+ rtems_capture_init_stack_usage (st);
+ * This function is called when a task is restarted.
+static void
+ * event.
+ rtems_capture_task_t* rt;
+ rt = restarted_task->extensions[index];
+ if (ct == NULL)
+ if (rt == NULL)
+ rt = rtems_capture_create_capture_task (restarted_task);
+ if (rtems_capture_trigger (ct, rt, RTEMS_CAPTURE_RESTART))
+ rtems_capture_record (ct, RTEMS_CAPTURE_RESTARTED_BY_EVENT);
+ rtems_capture_record (rt, RTEMS_CAPTURE_RESTARTED_EVENT);
+ rtems_capture_task_stack_usage (rt);
+ rtems_capture_init_stack_usage (rt);
+ * This function is called when a task is deleted.
+static void
+ * event.
+ rtems_capture_task_t* dt;
+ dt = deleted_task->extensions[index];
+ if (ct == NULL)
+ if (dt == NULL)
+ dt = rtems_capture_create_capture_task (deleted_task);
+ if (rtems_capture_trigger (ct, dt, RTEMS_CAPTURE_DELETE))
+ rtems_capture_record (ct, RTEMS_CAPTURE_DELETED_BY_EVENT);
+ rtems_capture_record (dt, RTEMS_CAPTURE_DELETED_EVENT);
+ rtems_capture_task_stack_usage (dt);
+ * This task's tcb will be invalid. This signals the
+ * task has been deleted.
+ dt->tcb = 0;
+ rtems_capture_destroy_capture_task (dt);
+ * This function is called when a task is begun.
+static void
+ * event.
+ rtems_capture_task_t* bt;
+ bt = begin_task->extensions[index];
+ if (bt == NULL)
+ bt = rtems_capture_create_capture_task (begin_task);
+ if (rtems_capture_trigger (NULL, bt, RTEMS_CAPTURE_BEGIN))
+ rtems_capture_record (bt, RTEMS_CAPTURE_BEGIN_EVENT);
+ * This function is called when a task is exitted. That is
+ * returned rather than was deleted.
+static void
+ * event.
+ rtems_capture_task_t* et;
+ et = exitted_task->extensions[index];
+ if (et == NULL)
+ et = rtems_capture_create_capture_task (exitted_task);
+ if (rtems_capture_trigger (NULL, et, RTEMS_CAPTURE_EXITTED))
+ rtems_capture_record (et, RTEMS_CAPTURE_EXITTED_EVENT);
+ rtems_capture_task_stack_usage (et);
+ * This function is called when a termination request is identified.
+static void
+ * event.
+ rtems_capture_task_t* tt;
+ tt = terminated_task->extensions[index];
+ if (tt == NULL)
+ tt = rtems_capture_create_capture_task (terminated_task);
+ if (rtems_capture_trigger (NULL, tt, RTEMS_CAPTURE_TERMINATED))
+ rtems_capture_record (tt, RTEMS_CAPTURE_TERMINATED_EVENT);
+ rtems_capture_task_stack_usage (tt);
+ * This function is called when a context is switched.
+static void
+ uint32_t flags = rtems_capture_get_flags();
+ * Only perform context switch trace processing if tracing is
+ * enabled.
+ if (flags & RTEMS_CAPTURE_ON)
+ rtems_capture_time_t time;
+ * Get the cpature task control block so we can update the
+ * reference and perform any watch or trigger functions.
+ rtems_capture_task_t* ht;
+ if (_States_Is_dormant (current_task->current_state))
+ rtems_id ct_id = current_task->Object.id;
+ ct = rtems_capture_find_capture_task( ct_id );
+ else
+ if (ct == NULL)
+ ht = heir_task->extensions[index];
+ if (ht == NULL)
+ ht = rtems_capture_create_capture_task (heir_task);
+ * Update the execution time. Assume the time will not overflow
+ * for now. This may need to change.
+ rtems_capture_get_time (&time);
+ * We could end up with null pointers for both the current task
+ * and the heir task.
+ if (ht)
+ ht->in++;
+ ht->time_in = time;
+ if (ct)
+ ct->out++;
+ if (ct->time_in)
+ ct->time += time - ct->time_in;
+ if (rtems_capture_trigger (ct, ht, RTEMS_CAPTURE_SWITCH))
+ rtems_capture_record (ct, RTEMS_CAPTURE_SWITCHED_OUT_EVENT);
+ rtems_capture_record (ht, RTEMS_CAPTURE_SWITCHED_IN_EVENT);
diff --git a/cpukit/libmisc/capture/captureimpl.h b/cpukit/libmisc/capture/captureimpl.h
index 0000000..ee18d82
--- /dev/null
+++ b/cpukit/libmisc/capture/captureimpl.h
@@ -0,0 +1,195 @@
+ * @file rtems/captureimpl.h
+ * @brief Capture Implementation file
+ * This file contains an interface between the capture engine and
+ * capture user extension methods.
+ COPYRIGHT (c) 1989-2014.
+#ifndef __CAPTUREIMPL_H_
+#define __CAPTUREIMPL_H_
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include "capture.h"
+ * Global capture flags.
+#define RTEMS_CAPTURE_ON (1U << 0)
+#define RTEMS_CAPTURE_NO_MEMORY (1U << 1)
+#define RTEMS_CAPTURE_OVERFLOW (1U << 2)
+#define RTEMS_CAPTURE_TRIGGERED (1U << 3)
+#define RTEMS_CAPTURE_READER_ACTIVE (1U << 4)
+#define RTEMS_CAPTURE_READER_WAITING (1U << 5)
+#define RTEMS_CAPTURE_GLOBAL_WATCH (1U << 6)
+#define RTEMS_CAPTURE_ONLY_MONITOR (1U << 7)
+ * @brief Capture set extension index.
+ * This function is used to set the extension index
+ * for the capture engine.
+ * @param[in] index specifies the extension index to be
+ * used for capture engine data.
+void rtems_capture_set_extension_index(int index);
+ * @brief Capture get extension index.
+ * This function rturns the extension index for the
+ * capture engine.
+ * @retval This method returns the extension index.
+int rtems_capture_get_extension_index(void);
+ * @brief Capture get flags.
+ * This function gets the current flag settings
+ * @retval This method returns the global capture
+ * flags.
+uint32_t rtems_capture_get_flags(void);
+ * @brief Capture set flags.
+ * This function sets a flag in the capture engine
+ * @param[in] mask specifies the flag to set
+void rtems_capture_set_flags(uint32_t mask);
+ * @brief Capture user extension open.
+ * This function creates the capture user extensions.
+ * @retval This method returns RTEMS_SUCCESSFUL upon successful
+ * creation of the user extensions.
+ * @brief Capture user extension close.
+ * This function closes the capture user extensions.
+ * @retval This method returns RTEMS_SUCCESSFUL upon a successful
+ * delete of the user extensions.
+ * @brief Capture find capture task.
+ * This function finds the capture task control block
+ * @param[in] ct_id specifies the task_id
+ * @retval This method returns the capture task control block associated
+ * with the given task id.
+rtems_capture_task_t* rtems_capture_find_capture_task( rtems_id ct_id );
+ * @brief Capture create capture task control block.
+ * This function create the capture task control block
+ * @param[in] new_task specifies the rtems thread control block
+ * @retval This method returns a capture task control block.
+rtems_capture_task_t* rtems_capture_create_capture_task (rtems_tcb* new_task);
+ * @brief Capture trigger.
+ * This function checks if we have triggered or if this event is a
+ * cause of a trigger.
+ * @param[in] ft specifies specifices the capture from task
+ * @param[in] tt specifies specifices the capture to task
+ * @param[in] events specifies the events
+ * @retval This method returns true if we have triggered or
+ * if the event is a cause of a trigger.
+bool rtems_capture_trigger (rtems_capture_task_t* ft,
+ rtems_capture_task_t* tt,
+ uint32_t events);
+ * @brief Capture initialize stack usage
+ * This function setups a stack so its usage can be monitored.
+ * @param[in] task specifies the capture task block
+void rtems_capture_init_stack_usage (rtems_capture_task_t* task);
+ * @brief Capture destroy task.
+ * This function destroy the task structure if the reference count
+ * is 0 and the tcb has been cleared signalling the task has been
+ * deleted.
+void rtems_capture_destroy_capture_task (rtems_capture_task_t* task);
+ * @brief .
+ * This function returns the current time. If a handler is provided
+ * by the user the time is gotten from that.
+ * @param[in] time specifies the capture time
+ * @retval This method returns a nano-second time if no user handler
+ * is provided. Otherwise, it returns a resolution defined by the handler.
+void rtems_capture_get_time (rtems_capture_time_t* time);
+#ifdef __cplusplus
+#endif
+#endif
1.8.1.4
