or1ksim fails to build
Hesham Moustafa heshamelmatary at gmail.com
Fri Aug 29 19:24:15 UTC 2014
On Fri, Aug 29, 2014 at 9:19 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Hi
> I think something isn't quite right.  I don't know if gcc isn't including
> these or the bsp_specs isn't picking them up. It is a long holiday weekend
> and I just wanted to throw this out since I don't have time to investigate.
> or1k-rtems4.11-gcc -B../../../../../or1ksim/lib/ -specs bsp_specs
> -qrtems -O2 -O0 -g -Wall -Wmissing-prototypes
> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
> -O2   -o nsecs.exe init.o empty.o
> ../../../../../or1ksim/lib/librtemscpu.a(libscore_a-threadhandler.o): In
> function `_Thread_Handler':
> /users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/cpukit/score/../../../../../../rtems/c/src/../../cpukit/score/src/threadhandler.c:181:
> undefined reference to `_init'
> ../../../../../or1ksim/lib/librtemscpu.a(libcsupport_a-newlibc_exit.o):
> In function `_exit':
> /users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/cpukit/libcsupport/../../../../../../rtems/c/src/../../cpukit/libcsupport/src/newlibc_exit.c:43:
> undefined reference to `_fini'
> collect2: error: ld returned 1 exit status
What's the configure line you used to build? I used to --disable-posix
and --disable-itron to avoid some of building errors.
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
