or1ksim fails to build
Fri Aug 29 20:10:40 UTC 2014
On 8/29/2014 2:24 PM, Hesham Moustafa wrote:
> On Fri, Aug 29, 2014 at 9:19 PM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
>> Hi
>> I think something isn't quite right.  I don't know if gcc isn't including
>> these or the bsp_specs isn't picking them up. It is a long holiday weekend
>> and I just wanted to throw this out since I don't have time to investigate.
>> or1k-rtems4.11-gcc -B../../../../../or1ksim/lib/ -specs bsp_specs
>> -qrtems -O2 -O0 -g -Wall -Wmissing-prototypes
>> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
>> -O2   -o nsecs.exe init.o empty.o
>> ../../../../../or1ksim/lib/librtemscpu.a(libscore_a-threadhandler.o): In
>> function `_Thread_Handler':
>> /users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/cpukit/score/../../../../../../rtems/c/src/../../cpukit/score/src/threadhandler.c:181:
>> undefined reference to `_init'
>> ../../../../../or1ksim/lib/librtemscpu.a(libcsupport_a-newlibc_exit.o):
>> In function `_exit':
>> /users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/cpukit/libcsupport/../../../../../../rtems/c/src/../../cpukit/libcsupport/src/newlibc_exit.c:43:
>> undefined reference to `_fini'
>> collect2: error: ld returned 1 exit status
> What's the configure line you used to build? I used to --disable-posix
> and --disable-itron to avoid some of building errors.
ITRON is no longer in the tree so that doesn't matter at all. :)
POSIX was on. With it off, I get the same.
I built a new toolset with the RSB just in case and got the same result.
It is a long holiday weekend here. Heading out and not sure what is
broken. Usually this indicates an issue with the linkcmds or
the bsp_specs. But if it works for you, then it must be something
else or all changes are not submitted.
Are your tools "fresh"?
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> Support Available                (256) 722-9985
