or1ksim fails to build
Hesham Moustafa heshamelmatary at gmail.com
Fri Aug 29 21:32:05 UTC 2014
I have removed the entire or1k-rtems4.11-* and built a vanilla
toolchain from latest RSB. Then I cloned latest RTEMS from the git
HEAD, configured and built it, and I did not come across this error.
MY configure line is:
~/rtems/configure --target=or1k-rtems4.11 --enable-rtemsbsp=or1ksim
--enable-networking --enable-tests
On Fri, Aug 29, 2014 at 10:15 PM, Hesham Moustafa
<heshamelmatary at gmail.com> wrote:
> On Aug 29, 2014 10:10 PM, "Joel Sherrill" <joel.sherrill at oarcorp.com> wrote:
>> On 8/29/2014 2:24 PM, Hesham Moustafa wrote:
>> > On Fri, Aug 29, 2014 at 9:19 PM, Joel Sherrill
>> >> Hi
>> >> I think something isn't quite right.  I don't know if gcc isn't
>> >> including
>> >> these or the bsp_specs isn't picking them up. It is a long holiday
>> >> weekend
>> >> and I just wanted to throw this out since I don't have time to
>> >> investigate.
>> >> or1k-rtems4.11-gcc -B../../../../../or1ksim/lib/ -specs bsp_specs
>> >> -qrtems -O2 -O0 -g -Wall -Wmissing-prototypes
>> >> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
>> >> -O2   -o nsecs.exe init.o empty.o
>> >> ../../../../../or1ksim/lib/librtemscpu.a(libscore_a-threadhandler.o):
>> >> In
>> >> function `_Thread_Handler':
>> >> /users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/cpukit/score/../../../../../../rtems/c/src/../../cpukit/score/src/threadhandler.c:181:
>> >> undefined reference to `_init'
>> >> ../../../../../or1ksim/lib/librtemscpu.a(libcsupport_a-newlibc_exit.o):
>> >> In function `_exit':
>> >> /users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/cpukit/libcsupport/../../../../../../rtems/c/src/../../cpukit/libcsupport/src/newlibc_exit.c:43:
>> >> undefined reference to `_fini'
>> >> collect2: error: ld returned 1 exit status
>> > What's the configure line you used to build? I used to --disable-posix
>> > and --disable-itron to avoid some of building errors.
>> ITRON is no longer in the tree so that doesn't matter at all. :)
>> POSIX was on. With it off, I get the same.
>> I built a new toolset with the RSB just in case and got the same result.
>> It is a long holiday weekend here. Heading out and not sure what is
>> broken. Usually this indicates an issue with the linkcmds or
>> the bsp_specs. But if it works for you, then it must be something
>> else or all changes are not submitted.
>> Are your tools "fresh"?
> There is no problem with RTEMS because I use the RTEMS git repo and not
> mine.
> I believe my tools are fresh, but I will build it again now and report the
> results.
>> >> Joel Sherrill, Ph.D.             Director of Research & Development
>> >> joel.sherrill at OARcorp.com        On-Line Applications Research
>> >> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>> >> Support Available                (256) 722-9985
