or1ksim fails to build
Fri Aug 29 21:33:15 UTC 2014
I will try to get to this soon. But it is a holiday weekend and tomorrow is my wife's birthday so I have priorities :)
--Joel
On August 29, 2014 4:32:05 PM CDT, Hesham Moustafa <heshamelmatary at gmail.com> wrote:
>I have removed the entire or1k-rtems4.11-* and built a vanilla
>toolchain from latest RSB. Then I cloned latest RTEMS from the git
>HEAD, configured and built it, and I did not come across this error.
>MY configure line is:
>~/rtems/configure --target=or1k-rtems4.11 --enable-rtemsbsp=or1ksim
>--enable-networking --enable-tests
>On Fri, Aug 29, 2014 at 10:15 PM, Hesham Moustafa
>> On Aug 29, 2014 10:10 PM, "Joel Sherrill" <joel.sherrill at oarcorp.com>
>wrote:
>>> On 8/29/2014 2:24 PM, Hesham Moustafa wrote:
>>> > On Fri, Aug 29, 2014 at 9:19 PM, Joel Sherrill
>>> > <joel.sherrill at oarcorp.com> wrote:
>>> >> Hi
>>> >> I think something isn't quite right.  I don't know if gcc isn't
>>> >> including
>>> >> these or the bsp_specs isn't picking them up. It is a long
>holiday
>>> >> weekend
>>> >> and I just wanted to throw this out since I don't have time to
>>> >> investigate.
>>> >> or1k-rtems4.11-gcc -B../../../../../or1ksim/lib/ -specs bsp_specs
>>> >> -qrtems -O2 -O0 -g -Wall -Wmissing-prototypes
>>> >> -Wimplicit-function-declaration -Wstrict-prototypes
>-Wnested-externs
>>> >> -O2   -o nsecs.exe init.o empty.o
>../../../../../or1ksim/lib/librtemscpu.a(libscore_a-threadhandler.o):
>>> >> In
>>> >> function `_Thread_Handler':
>/users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/cpukit/score/../../../../../../rtems/c/src/../../cpukit/score/src/threadhandler.c:181:
>>> >> undefined reference to `_init'
>../../../../../or1ksim/lib/librtemscpu.a(libcsupport_a-newlibc_exit.o):
>>> >> In function `_exit':
>/users/joel/rtems-4.11-work/rtems-testing/rtems/build-or1k-or1ksim-rtems/or1k-rtems4.11/c/or1ksim/cpukit/libcsupport/../../../../../../rtems/c/src/../../cpukit/libcsupport/src/newlibc_exit.c:43:
>>> >> undefined reference to `_fini'
>>> >> collect2: error: ld returned 1 exit status
>>> > What's the configure line you used to build? I used to
>--disable-posix
>>> > and --disable-itron to avoid some of building errors.
>>> ITRON is no longer in the tree so that doesn't matter at all. :)
>>> POSIX was on. With it off, I get the same.
>>> I built a new toolset with the RSB just in case and got the same
>result.
>>> It is a long holiday weekend here. Heading out and not sure what is
>>> broken. Usually this indicates an issue with the linkcmds or
>>> the bsp_specs. But if it works for you, then it must be something
>>> else or all changes are not submitted.
>>> Are your tools "fresh"?
>> There is no problem with RTEMS because I use the RTEMS git repo and
>not
>> mine.
>> I believe my tools are fresh, but I will build it again now and
>report the
>> results.
>>> >> Joel Sherrill, Ph.D.             Director of Research &
>Development
>>> >> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> >> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> >> Support Available                (256) 722-9985
>>> Joel Sherrill, Ph.D.             Director of Research & Development
