C++ cdtest Build Failure
Sat Aug 30 14:02:24 UTC 2014
Is it only on or1k?
On Fri, Aug 29, 2014 at 3:14 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Hi
> Any suggestions?
> In file included from
> ../../../../../../../rtems/c/src/../../testsuites/samples/cdtest/main.cc:29:0:
> /users/joel/rtems-4.11-work/tools/lib/gcc/or1k-rtems4.11/4.8.3/include/c++/cstdlib:
> In function 'long long int std::abs(long long int)':
> /users/joel/rtems-4.11-work/tools/lib/gcc/or1k-rtems4.11/4.8.3/include/c++/cstdlib:174:20:
> error: declaration of C function 'long long int std::abs(long long int)'
> conflicts with
>    abs(long long __x) { return __builtin_llabs (__x); }
> /users/joel/rtems-4.11-work/tools/lib/gcc/or1k-rtems4.11/4.8.3/include/c++/cstdlib:166:3:
> error: previous declaration 'long int std::abs(long int)' here
>    abs(long __i) { return __builtin_labs(__i); }
> ../../../../../../../rtems/c/src/../../testsuites/samples/cdtest/main.cc: At
> global scope:
> ../../../../../../../rtems/c/src/../../testsuites/samples/cdtest/main.cc:216:1:
> error: expected '}' at end of input
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
