[PATCH 3/3] or1k: Implement context validate and context volatile clobber functions.
Hesham ALMatary
heshamelmatary at gmail.com
Sun Aug 31 23:29:41 UTC 2014
score/cpu/or1k: Add two new assembly functions: _CPU_Context_validate
and _CPU_Context_volatile_clobber; their implementation follows
corresponding ARM functions.
cpukit/score/cpu/or1k/Makefile.am | 2 +
cpukit/score/cpu/or1k/or1k-context-validate.S | 186 +++++++++++++++++++++
.../score/cpu/or1k/or1k-context-volatile-clobber.S | 35 ++++
cpukit/score/cpu/or1k/preinstall.am | 6 +-
4 files changed, 226 insertions(+), 3 deletions(-)
create mode 100644 cpukit/score/cpu/or1k/or1k-context-validate.S
create mode 100644 cpukit/score/cpu/or1k/or1k-context-volatile-clobber.S
diff --git a/cpukit/score/cpu/or1k/Makefile.am b/cpukit/score/cpu/or1k/Makefile.am
index cb96856..b9e00d3 100644
--- a/cpukit/score/cpu/or1k/Makefile.am
+++ b/cpukit/score/cpu/or1k/Makefile.am
@@ -24,6 +24,8 @@ libscorecpu_a_SOURCES =
libscorecpu_a_SOURCES += cpu.c
libscorecpu_a_SOURCES += or1k-context-switch.S
libscorecpu_a_SOURCES += or1k-context-initialize.c
+libscorecpu_a_SOURCES += or1k-context-validate.S
+libscorecpu_a_SOURCES += or1k-context-volatile-clobber.S
libscorecpu_a_SOURCES += or1k-exception-default.c
libscorecpu_a_SOURCES += or1k-exception-frame-print.c
libscorecpu_a_SOURCES += or1k-exception-handler-low.S
diff --git a/cpukit/score/cpu/or1k/or1k-context-validate.S b/cpukit/score/cpu/or1k/or1k-context-validate.S
new file mode 100644
index 0000000..463cc77
--- /dev/null
+++ b/cpukit/score/cpu/or1k/or1k-context-validate.S
@@ -0,0 +1,186 @@
+ * COPYRIGHT (c) 2014 Hesham ALMatary <heshamelmatary at gmail.com>
+#ifdef HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/asm.h>
+#include <rtems/score/cpu.h>
+.section .text
+PUBLIC(_CPU_Context_validate)
+SYM(_CPU_Context_validate):
+ l.addi r1, r1, -140
+ l.sw 8(r1), r2
+ l.sw 12(r1), r3
+ l.sw 16(r1), r4
+ l.sw 20(r1), r5
+ l.sw 24(r1), r6
+ l.sw 28(r1), r7
+ l.sw 32(r1), r8
+ l.sw 36(r1), r9
+ l.sw 40(r1), r10
+ l.sw 44(r1), r11
+ l.sw 48(r1), r12
+ l.sw 52(r1), r13
+ l.sw 56(r1), r14
+ l.sw 60(r1), r15
+ l.sw 64(r1), r16
+ l.sw 68(r1), r17
+ l.sw 72(r1), r18
+ l.sw 76(r1), r19
+ l.sw 80(r1), r20
+ l.sw 84(r1), r21
+ l.sw 88(r1), r22
+ l.sw 92(r1), r23
+ l.sw 96(r1), r24
+ l.sw 100(r1), r25
+ l.sw 104(r1), r26
+ l.sw 108(r1), r27
+ l.sw 112(r1), r28
+ l.sw 116(r1), r29
+ l.sw 120(r1), r30
+ l.sw 124(r1), r31
+ /* Fill */
+ /* r13 is used for temporary values */
+ l.add r13, r0, r0
+ /* r31 contains the stack pointer */
+ l.add r31, r1, r0
+.macro fill_register reg
+ l.addi r13, r13, 1
+ l.addi \reg, r13, 0
+.endm
+ fill_register r2
+ fill_register r3
+ fill_register r4
+ fill_register r5
+ fill_register r6
+ fill_register r7
+ fill_register r8
+ fill_register r9
+ fill_register r10
+ fill_register r11
+ fill_register r12
+ fill_register r13
+ fill_register r14
+ fill_register r15
+ fill_register r16
+ fill_register r17
+ fill_register r18
+ fill_register r19
+ fill_register r20
+ fill_register r21
+ fill_register r22
+ fill_register r23
+ fill_register r24
+ fill_register r25
+ fill_register r26
+ fill_register r27
+ fill_register r28
+ fill_register r29
+ fill_register r30
+ fill_register r31
+ /* Check */
+check:
+.macro check_register reg
+ l.sfne \reg, r13
+ l.bf restore
+ l.nop
+.endm
+ l.sfne r31, r1
+ l.bf restore
+ l.nop
+ l.addi r13, r0, 0
+ check_register r2
+ check_register r3
+ check_register r4
+ check_register r5
+ check_register r6
+ check_register r7
+ check_register r8
+ check_register r9
+ check_register r10
+ check_register r11
+ check_register r12
+ check_register r13
+ check_register r14
+ check_register r15
+ check_register r16
+ check_register r17
+ check_register r18
+ check_register r19
+ check_register r20
+ check_register r21
+ check_register r22
+ check_register r23
+ check_register r24
+ check_register r25
+ check_register r26
+ check_register r27
+ check_register r28
+ check_register r29
+ check_register r30
+ check_register r31
+ l.j check
+ l.nop
+/* Restore */
+restore:
+ l.lwz r2, 8(r1)
+ l.lwz r3, 12(r1)
+ l.lwz r4, 16(r1)
+ l.lwz r5, 20(r1)
+ l.lwz r6, 24(r1)
+ l.lwz r7, 28(r1)
+ l.lwz r8, 32(r1)
+ l.lwz r9, 36(r1)
+ l.lwz r10, 40(r1)
+ l.lwz r11, 44(r1)
+ l.lwz r12, 48(r1)
+ l.lwz r13, 52(r1)
+ l.lwz r14, 56(r1)
+ l.lwz r15, 60(r1)
+ l.lwz r16, 64(r1)
+ l.lwz r17, 68(r1)
+ l.lwz r18, 72(r1)
+ l.lwz r19, 76(r1)
+ l.lwz r20, 80(r1)
+ l.lwz r21, 84(r1)
+ l.lwz r22, 88(r1)
+ l.lwz r23, 92(r1)
+ l.lwz r24, 96(r1)
+ l.lwz r25, 100(r1)
+ l.lwz r26, 104(r1)
+ l.lwz r27, 108(r1)
+ l.lwz r28, 112(r1)
+ l.lwz r29, 116(r1)
+ l.lwz r30, 120(r1)
+ l.lwz r31, 124(r1)
+ l.addi r1, r1, 140
+ l.jr r9
+ l.nop
diff --git a/cpukit/score/cpu/or1k/or1k-context-volatile-clobber.S b/cpukit/score/cpu/or1k/or1k-context-volatile-clobber.S
index 0000000..304b769
--- /dev/null
+++ b/cpukit/score/cpu/or1k/or1k-context-volatile-clobber.S
@@ -0,0 +1,35 @@
+#endif
+.section .text
+PUBLIC(_CPU_Context_volatile_clobber)
+SYM(_CPU_Context_volatile_clobber):
+.macro clobber_register reg
+ l.addi r0, r0, -1
+ l.addi \reg, r0, 0
+.endm
+ clobber_register r3
+ clobber_register r4
+ clobber_register r5
+ clobber_register r6
+ clobber_register r7
+ clobber_register r8
+ clobber_register r13
+ clobber_register r31
+ l.jr r9
+ l.nop
diff --git a/cpukit/score/cpu/or1k/preinstall.am b/cpukit/score/cpu/or1k/preinstall.am
index f4d7153..01cd68f 100644
--- a/cpukit/score/cpu/or1k/preinstall.am
+++ b/cpukit/score/cpu/or1k/preinstall.am
@@ -5,14 +5,14 @@ $(srcdir)/preinstall.am: Makefile.am
$(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
endif
-PREINSTALL_DIRS =
-DISTCLEANFILES += $(PREINSTALL_DIRS)
all-am: $(PREINSTALL_FILES)
PREINSTALL_FILES =
CLEANFILES += $(PREINSTALL_FILES)
+PREINSTALL_DIRS =
+DISTCLEANFILES += $(PREINSTALL_DIRS)
$(PROJECT_INCLUDE)/rtems/$(dirstamp):
@$(MKDIR_P) $(PROJECT_INCLUDE)/rtems
@: > $(PROJECT_INCLUDE)/rtems/$(dirstamp)
1.9.3
