Using rtl-host in covor - some questions
Krzysztof Mięsowicz
krzysztof.miesowicz at gmail.com
Wed Aug 13 09:03:27 UTC 2014
Hi,
I think we have small misunderstanding here :-) I'm currently trying to
move symbol generation to covoar - previously symbol list was generated in
shell script do_coverage.sh and passed to covoar in configuration file or
as a command line argument. What we want now is to allow covoar to generate
symbols. Chris suggested that use of code in rtl-host repo to manage
symbols (it seems to use elf libraries inside), but this was said to be out
of the scope of this project - I am going to do this after end of SOCIS.
But as the first approximation we decided to invoke nm from covoar, using
functions from rld-process[cpp, h] and parse its output in covoar. I have
it almost done, but currently I added building rtems-syms from rtl-host as
library and use it in covoar. I don't know if this is right solution and
how should it be done better :-)
2014-08-13 0:14 GMT+02:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
> On 8/12/2014 6:58 AM, Krzysztof Mięsowicz wrote:
> > Hi,
> > I'm currently working on adding symbol generation to covoar. I'm going
> > to use rtl::process::execute function to run nm from covoar (as
> > suggested by Chris). I do not know exactly how should I use this in
> > covoar. Should I build rtl-host as a library and link it to covoar? Or
> > maybe there is another, better option?
> covoar is in C++ and you would be invoking Python instead of nm from C++
> and still producing something that the C++ has to read.
> Ian Taylor suggested using nm over the elf libraries because the output
> of nm was stable. But converting that code to use an elf reading library
> directly would likely be a better solution.
> If that's the use of nm you are talking about. :)
> Waiting to hear from Chris.
> > Thanks in advance for replies :)
> > Regards,
> > Krzysztof
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140813/8247c426/attachment-0002.html>
