[PATCH 1/2] capture: change to use malloc/vs/rtems_workspace_alloc.
Chris Johns
chrisj at rtems.org
Wed Aug 27 00:46:56 UTC 2014
On 27/08/2014 6:16 am, Jennifer Averett wrote:
> Since neither malloc nor rtems_workspace_alloc should be called during a
> task switch the capture task was changed to manage a pool of capture
> tasks that is allocated at open.
Maybe the locking issue should be resolved first. For example the
approach I outlined in the other thread may remove the need to manage
task data in the capture engine and generally improve the design. For
example the "id" could be held in the TCB.
