[PATCH] Adding "eth" linker script section for arm bsp.
Federico Casares federico.casares at tallertechnologies.com
Thu Aug 28 17:24:17 UTC 2014
On Wed, Aug 27, 2014 at 10:29 AM, Sebastian Huber <
> On 27/08/14 15:18, Federico Casares wrote:
>> Hi, attached the patch for:
>> - Adding "eth" linker script section for arm bsp.
>> - Adding new  linker comands for LPC176x bsp that includes eth section.
>> This patch is useful useful when working with DMA devices, so we can put
>> "ethernet memory" in specific locations.
>> Regards
>> http://www.tallertechnologies.com <http://www.tallertechnologies.com>
>> Casares, Federico
>> Sr. Software Engineer
>> Taller Technologies Argentina
>> San Lorenzo 47, 3rd Floor, Office 5
>> Córdoba, Argentina
>> 0001-Adding-eth-linker-script-section-for-arm-bsp.patch
>>  From 6c1f50a00a43cb9128441195508f5a0563907440 Mon Sep 17 00:00:00 2001
>> From: Federico Casares<federico.casares at tallertechnologies.com>
>> Date: Wed, 27 Aug 2014 10:12:30 -0300
>> Subject: [PATCH] Adding "eth" linker script section for arm bsp. Adding
>> new
>>   c/src/lib/libbsp/arm/lpc176x/Makefile.am           |  1 +
>>   .../startup/linkcmds.lpc1768_mbed_ahb_ram_eth      | 30
>>   c/src/lib/libbsp/arm/shared/startup/linkcmds.base  |  7 +++++
> If you add this section to linkcmds.base, then every ARM BSP must define
> this region.  I don't think this makes sense.
Right. Where you suggest we can put this?
>    3 files changed, 38 insertions(+)
>>   create mode 100644 c/src/lib/libbsp/arm/lpc176x/
>> diff --git a/c/src/lib/libbsp/arm/lpc176x/Makefile.am
>> b/c/src/lib/libbsp/arm/lpc176x/Makefile.am
>> index 3a1d4b2..36711a6 100644
>> --- a/c/src/lib/libbsp/arm/lpc176x/Makefile.am
>> +++ b/c/src/lib/libbsp/arm/lpc176x/Makefile.am
>> @@ -69,6 +69,7 @@ project_lib_DATA += startup/linkcmds
>>   EXTRA_DIST =
>>   EXTRA_DIST += startup/linkcmds.lpc1768_mbed
>>   EXTRA_DIST += startup/linkcmds.lpc1768_mbed_ahb_ram
>> +EXTRA_DIST += startup/linkcmds.lpc1768_mbed_ahb_ram_eth
> Do you really need a lpc1768_mbed_ahb_ram and a lpc1768_mbed_ahb_ram_eth
> variant?
Yes, for example, currently we are using both configuration for two
different projects.
One that uses AHB2 for ethernet and the other that uses AHB1 and AHB2 as a
single memory range for a big program.
regards
[image: http://www.tallertechnologies.com]
Casares, Federico
Córdoba, Argentina
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140828/2011161c/attachment-0002.html>
