[PATCH 1/2] rtems: Add rtems_cache_coherent_allocate()
Tue Dec 2 07:02:29 UTC 2014
Hello Daniel,
On 01/12/14 15:33, Daniel Hellstrom wrote:
> The coherent code looks nice and clean. I'm wondering, is it possbile
> to add a memory region to the coherent area and at the same time make
> malloc() return memory from that area when the default heap connected
> to malloc() is empty? As I recall that is the behaviour of linux, when
> the standard zone is empty it allocates from the DMA able memory zone
> since it can do both. I would be interested in such an approach for
> the LEON, where all memory can be used for the CPU but only 256MB of
> memory can be accessed from the PCI.
this should be possible.  One option is to allow a list of heaps instead
of single RTEMS_Malloc_Heap.  The overhead seems to be acceptable too
me.  It needs a bit of work and testing, probably more than a couple of
hours.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
