[PATCH] libmisc: More useful default configuration
Tue Dec 2 23:18:21 UTC 2014
On 2/12/2014 9:11 pm, Sebastian Huber wrote:
> The dummy.c is a de-facto default configuration so use unlimited objects
> and the stack checker.  This makes it easier for new RTEMS users which
> will likely use this file if they just work with the usual main()
> function as the application entry point.
I did not understand before now this file was being used. I assume it is
being used with the bspinit.c file ?
If so maybe the bspinit.c file be moved here from the bsp/shared tree
and these files and this directory be renamed ?
