[PATCH] libmisc: More useful default configuration
Wed Dec 3 06:45:25 UTC 2014
On 03/12/14 00:18, Chris Johns wrote:
> On 2/12/2014 9:11 pm, Sebastian Huber wrote:
>> The dummy.c is a de-facto default configuration so use unlimited objects
>> and the stack checker.  This makes it easier for new RTEMS users which
>> will likely use this file if they just work with the usual main()
>> function as the application entry point.
> I did not understand before now this file was being used. I assume it
> is being used with the bspinit.c file ?
> If so maybe the bspinit.c file be moved here from the bsp/shared tree
> and these files and this directory be renamed ?
Hm, I didn't know we have a bspinit.c file.  What is BSP dependent in
this file?
It is not compatible to dummy.c since this file uses main() directly as
the entry point.  This seems to be quite bad, since argv and envp is
then undefined.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
