[PATCH] fix for default configuration for pc386 bsp
Jan Dolezal dolezj21 at fel.cvut.cz
Wed Dec 3 16:42:15 UTC 2014
Hello Ben,
that is my fault, thank you for your correction.
Jan Dolezal
On 2.12.2014 23:40, Ben Gras wrote:
> All,
> If USE_VBE_RM is not on, vesa_realmode_bootup_init shouldn't be
> referenced, but it's always defined, so the test shoudl be #if instead
> of #ifdef.
> devel mailing list
> devel at rtems.org
