[PATCH 2/2] i386: doxygen and comments related to VESA real mode framebuffer
Wed Dec 3 16:56:53 UTC 2014
On Wed, Dec 3, 2014 at 11:29 AM, Jan Dolezal <dolezj21 at fel.cvut.cz> wrote:
> Hello Gedare,
> thank you very much for your comments. I really appreciate them.
> On 3.12.2014 00:59, Gedare Bloom wrote:
>> Sometimes params are identified as in our out, sometimes they are not.
>> Please be consistent. Generally patch looks OK, does the doxygen look
>> right when applied? [1] can help
> There is a problem caused by redefinition of macro
> RTEMS_COMPILER_PACKED_ATTRIBUTE for edid.h (to EDID_PACKED_ATTRIBUTE) and
> vbe3.h (to VBE3_PACKED_ATTRIBUTE).
> Currently doxygen sets names of typedefed structs using these macros
> ([EDID,VBE3]_PACKED_ATTRIBUTE) to these macros names - so I ended up with
> several structs named after macro.
> I already added RTEMS_COMPILER_PACKED_ATTRIBUTE= into PREDEFINED tag under
> cpukit/Doxyfile.in, so when doxygen preprocessor encounters this macro it
> replaces it with 'nothing'.
> Now I think there are two reasonable approaches to make things work
> 1) set MACRO_EXPANSION to YES in Doxyfile.in
>    This way macros [EDID,VBE3]_PACKED... are replaced by
>    RTEMS_COMPILER_PACKED... one, that is empty.
>    Nevertheless I'm not sure if this way could harm something else.
> 2) drop usage of macros [EDID,VBE3]_PACKED_ATTRIBUTEs and use
>    RTEMS_COMPILER_PACKED_ATTRIBUTE instead
> 3) I could add macros [EDID,VBE3]_PACKED_ATTRIBUTE to PREDEFINED tag
>    under cpukit/Doxyfile.in, but it seems to me that is way too much
>    global place for small amount of things it influences in the end
> Which way would you prefer?
I prefer #2.
-Gedare
>> -Gedare
>> [1]
>> https://github.com/joelsherrill/gci_tasks/blob/master/2013/doxygen_c_header_tasks/validate/do_doxygen
>> On Tue, Dec 2, 2014 at 11:49 AM, Jan Dolezal <dolezj21 at fel.cvut.cz> wrote:
>>>   c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c   | 105 ++++---
>>>   c/src/lib/libbsp/i386/pc386/include/edid.h         |  14 +-
>>>   c/src/lib/libbsp/i386/pc386/include/fb_vesa.h      |  74 ++---
>>>   c/src/lib/libbsp/i386/pc386/include/tblsizes.h     |   1 -
>>>   c/src/lib/libbsp/i386/pc386/include/vbe3.h         | 311
>>>   c/src/lib/libbsp/i386/pc386/startup/ldsegs.S       |   6 +-
>>>   c/src/lib/libbsp/i386/shared/irq/idt.c             |  10 +-
>>>   .../libbsp/i386/shared/realmode_int/realmode_int.c |  69 ++++-
>>>   .../libbsp/i386/shared/realmode_int/realmode_int.h |  33 ++-
>>>   c/src/lib/libcpu/i386/cpu.h                        |  53 ++--
>>>   cpukit/score/cpu/i386/cpu_asm.S                    |   4 +-
>>>   cpukit/score/cpu/i386/rtems/score/i386.h           |  39 ++-
>>>   12 files changed, 468 insertions(+), 251 deletions(-)
>>> diff --git a/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
>>> b/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
>>> index b7b27b6..fb9d575 100644
>>> --- a/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
>>> +++ b/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
>>> @@ -1,35 +1,39 @@
>>> - *  FB driver for graphic hardware compatible with VESA Bios Extension
>>> - *  Real mode interface utilized
>>> - *  Tested on real HW.
>>> + * @file fb_vesa_rm.c
>>> + * @ingroup i386_pc386
>>> + * @brief FB driver for graphic hardware compatible with VESA Bios
>>> Extension
>>> + *     Real mode interface utilized
>>> + *     Tested on real HW.
>>> - *  Copyright (c) 2014 - CTU in Prague
>>> - *                       Jan Doležal ( dolezj21 at fel.cvut.cz )
>>> + * Public sources related:
>>> + *   - VESA BIOS EXTENSION (VBE) Core Function Standard, Ver: 3.0, Sep
>>> 16, 1998
>>> + *   - VESA Enhanced Extended Display Identification Data (E-EDID)
>>> Standard
>>> + *     Release A, Revision 2, September 25, 2006
>>> - *  The license and distribution terms for this file may be
>>> - *  found in the file LICENSE in this distribution or at
>>> - *  http://www.rtems.org/license/LICENSE.
>>> + * Hardware is completely initialized upon boot of the system.
>>> + * Therefore there is no way to change graphics mode later.
>>> - *  The code for rtems_buffer_* functions were greatly
>>> - *  inspired or coppied from:
>>> - *    - RTEMS fb_cirrus.c - Alexandru-Sever Horin
>>> (alex.sever.h at gmail.com)
>>> + * Interrupt 0x10 is used for entering graphics BIOS.
>>> - *  Public sources related:
>>> - *    - VESA BIOS EXTENSION (VBE) Core Function Standard, Ver: 3.0, Sep
>>> 16, 1998
>>> - *    - VESA Enhanced Extended Display Identification Data (E-EDID)
>>> Standard
>>> - *      Release A, Revision 2, September 25, 2006
>>> + * Driver reads parameter from multiboot command line to setup video:
>>> + * "--video=<resX>x<resY>[-<bpp>]"
>>> + * If cmdline parameter is not specified an attempt for obtaining
>>> + * resolution from display attached is made.
>>> - *  Hardware is completely initialized upon boot of the system.
>>> - *  Therefore there is no way to change graphics mode later.
>>> + * Copyright (c) 2014 - CTU in Prague
>>> + *                      Jan Doležal ( dolezj21 at fel.cvut.cz )
>>> - *  Interrupt 0x10 is used for entering graphics BIOS.
>>> + * The license and distribution terms for this file may be
>>> + * found in the file LICENSE in this distribution or at
>>> + * http://www.rtems.org/license/LICENSE.
>>> - *  Driver reads parameter from multiboot command line to setup video:
>>> - *  "--video=<resX>x<resY>[-<bpp>]"
>>> - *  If cmdline parameter is not specified an attempt for obtaining
>>> - *  resolution from display attached is made.
>>> + * The code for rtems_buffer_* functions were greatly
>>> + * inspired or coppied from:
>>> + *   - RTEMS fb_cirrus.c - Alexandru-Sever Horin
>>>   #include <bsp.h>
>>> @@ -48,6 +52,13 @@
>>>   #define FB_VESA_NAME    "FB_VESA_RM"
>>> + * @brief Initializes VBE framebuffer during bootup.
>>> + * utilizes switches to real mode interrupts and therefore must be
>>> + * called during bootup before tick is set up and real-time
>>> + * interrupt vectors utilized
>>>   void vesa_realmode_bootup_init(void);
>>>   /* mutex for protection against multiple opens, when called
>>> frame_buffer_open */
>>> @@ -187,19 +198,37 @@ inline uint32_t VBE_read_EDID(uint16_t
>>> controller_unit_number,
>>>       return (parret.reg_eax & 0xFFFF);
>>> + * @brief Basic graphic's mode parameters
>>>   typedef struct {
>>> +    /** number of the graphic's mode */
>>>       uint16_t mode_number;
>>> +    /** number of pixels in one line */
>>>       uint16_t resX;
>>> +    /** number of lines */
>>>       uint16_t resY;
>>> +    /** bits per pixel */
>>>       uint8_t bpp;
>>>   } Mode_params;
>>> -/* finds mode in 'modeList' of 'listLength' length according to
>>> resolution
>>> -    given in 'searchedResolution'. If bpp is given in that struct as
>>> well
>>> -    mode with such color depth and resolution is searched for. Otherwise
>>> bpp
>>> -    has to be zero. Mode number found is returned and also filled into
>>> -    'searchedResolution'. bpp is also filled into 'searchedResolution'
>>> if it
>>> -    was 0 before call. */
>>> + * @brief Find mode by resolution in the given list of modes
>>> + * finds mode in \p mode_list of \p list_length length according to
>>> resolution
>>> + * given in \p searched_resolution . If bpp is given in that struct as
>>> well
>>> + * mode with such color depth and resolution is searched for. Otherwise
>>> bpp
>>> + * has to be zero. Mode number found is returned and also filled into
>>> + * \p searched_resolution . bpp is also filled into \p
>>> searchedResolution if it
>>> + * was 0 before call.
>>> + * @param[in] mode_list list of modes to be searched
>>> + * @param[in] list_length number of modes in the list
>>> + * @param searched_resolution element filled with searched resolution
>>> or/and
>>> + *            bpp
>>> + * @retval mode number satisfying given parameters
>>> + * @retval -1 no suitable mode found
>>>   static uint16_t find_mode_by_resolution(   Mode_params *mode_list,
>>>                                           uint8_t list_length,
>>>                                           Mode_params
>>> *searched_resolution)
>>> @@ -223,14 +252,18 @@ static uint16_t find_mode_by_resolution(
>>>       return -1;
>>> - * Parse comandline option "--video=" if available.
>>> + * @brief Find mode given within command line.
>>> + * Parse command line option "--video=" if available.
>>>    *  expected format
>>>    *  --video=<resX>x<resY>[-<bpp>]
>>>    *  numbers <resX>, <resY> and <bpp> are decadic
>>>    * @retval video mode number to be set
>>> - *         -1 on parsing error or when no suitable mode found
>>> + * @retval -1 on parsing error or when no suitable mode found
>>>   static uint16_t find_mode_using_cmdline(Mode_params *mode_list,
>>>                                           uint8_t list_length)
>>> @@ -278,11 +311,13 @@ static uint16_t find_mode_using_cmdline(Mode_params
>>> *mode_list,
>>>       return -1;
>>> - * returns mode number best fitting to monitor attached
>>> + * @brief Find mode number best fitting to monitor attached
>>>   static uint16_t find_mode_using_EDID( Mode_params *mode_list,
>>> diff --git a/c/src/lib/libbsp/i386/pc386/include/edid.h
>>> b/c/src/lib/libbsp/i386/pc386/include/edid.h
>>> index 41bf1ca..16be6f6 100644
>>> --- a/c/src/lib/libbsp/i386/pc386/include/edid.h
>>> +++ b/c/src/lib/libbsp/i386/pc386/include/edid.h
>>> @@ -4,16 +4,16 @@
>>>    * @brief VESA EDID definitions.
>>> + * This file contains definitions for constants related to
>>> + * VESA Extended Display Identification Data.
>>> + *         More information can be found at
>>> + *     <http://www.vesa.org/vesa-standards/free-standards/>
>>> + *         VESA public standards may be found at
>>> + *     <http://www.vesa.org/wp-content/uploads/2010/12/thankspublic.htm>
>>> - * edid.h  - This file contains definitions for constants related to
>>> - *           VESA Extended Display Identification Data.
>>> - *          More information can be found at
>>> - *      <http://www.vesa.org/vesa-standards/free-standards/>
>>> - *          VESA public standards may be found at
>>>    * Copyright (C) 2014  Jan Doležal (dolezj21 at fel.cvut.cz)
>>>    *                     CTU in Prague.
>>> diff --git a/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
>>> b/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
>>> index 88e7dd8..d03b070 100644
>>> --- a/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
>>> +++ b/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
>>> @@ -3,12 +3,10 @@
>>> - * @brief Definitioins for vesa based framebuffer drivers.
>>> + * @brief Headers specific for framebuffer drivers utilizing VESA VBE.
>>> - * Headers specific for framebuffer drivers utilizing VESA VBE.
>>>    *                     CTU in Prague.
>>> @@ -35,15 +33,16 @@ extern "C" {
>>>   /* ----- Prototypes ----- */
>>> - * Returns information about graphic's controller in the infoBlock
>>> structure.
>>> + * @brief Returns information about graphic's controller in the \p
>>> info_block
>>> + * structure.
>>> - * @param infoBlock pointer to the struct to be filled with
>>> -                    controller information
>>> - * @param queriedVBEVersion if >0x200 then video bios is asked to fill
>>> in
>>> + * @param info_block pointer to the struct to be filled with
>>> + *                  controller information
>>> + * @param queried_VBE_Version if >0x200 then video bios is asked to fill
>>> in
>>>    *                          parameters which appeared with second
>>> version
>>>    *                          of VBE.
>>> - * @retval  register ax content as defined in VBE RETURN STATUS
>>> paragraph
>>> - *          -1 error calling graphical bios
>>> + * @retval  ax register content as defined in VBE RETURN STATUS
>>> paragraph
>>> + * @retval  -1 error calling graphical bios
>>>   uint32_t VBE_controller_information (
>>>       VBE_VbeInfoBlock *info_block,
>>> @@ -51,13 +50,13 @@ uint32_t VBE_controller_information (
>>> - * Fills structure infoBlock with informations about selected mode in
>>> - * modeNumber variable.
>>> + * @brief Fills structure \p info_block with informations about selected
>>> mode in
>>> + * \p mode_number variable.
>>> - * @param infoBlock pointer to the struct to be filled with mode
>>> information
>>> - * @param modeNumber detailes of this mode to be filled
>>> paragraph
>>> + * @param info_block pointer to the struct to be filled with mode
>>> information
>>> + * @param mode_number detailes of this mode to be filled
>>> paragraph
>>>   uint32_t VBE_mode_information (
>>>       VBE_ModeInfoBlock *info_block,
>>> @@ -65,13 +64,13 @@ uint32_t VBE_mode_information (
>>> - * Sets graphics mode selected. If mode has refreshRateCtrl bit set,
>>> than the
>>> - * infoBlock must be filled accordingly.
>>> + * @brief Sets graphics mode selected. If mode has refreshRateCtrl bit
>>> set, than
>>> + * the \p info_block must be filled accordingly.
>>> - * @param modeNumber number of mode to be set
>>> - * @param infoBlock pointer to struct containing refresh rate control
>>> info
>>> paragraph
>>> + * @param mode_number number of mode to be set
>>> + * @param info_block pointer to struct containing refresh rate control
>>> info
>>> paragraph
>>>   uint32_t VBE_set_mode (
>>>       uint16_t mode_number,
>>> @@ -79,27 +78,27 @@ uint32_t VBE_set_mode (
>>> - * Get currently set mode number.
>>> + * @brief Get currently set mode number.
>>> - * @param modeNumber variable to be filled with current mode number
>>> paragraph
>>> + * @param mode_number variable to be filled with current mode number
>>> paragraph
>>>   uint32_t VBE_current_mode (
>>>       uint16_t *mode_number
>>> - * Gets information about display data channel implemented in the
>>> + * @brief Gets information about display data channel implemented in the
>>>    * graphic's controller.
>>> - * @param controllerUnitNumber
>>> - * @param secondsToTransferEDIDBlock approximate time to transfer one
>>> EDID block
>>> - *                                   rounded up to seconds
>>> - * @param DDCLevelSupported after call contains DDC version supported
>>> and
>>> + * @param controller_unit_number
>>> + * @param seconds_to_transfer_EDID_block approximate time to transfer
>>> one EDID
>>> + *                                       block rounded up to seconds
>>> + * @param DDC_level_supported after call contains DDC version supported
>>> and
>>>    *                          screen blanking state during transfer
>>> paragraph
>>> paragraph
>>>   uint32_t VBE_report_DDC_capabilities (
>>>       uint16_t controller_unit_number,
>>> @@ -108,13 +107,14 @@ uint32_t VBE_report_DDC_capabilities (
>>> - * Reads selected EDID block from display attached to controller's
>>> interface.
>>> + * @brief Reads selected EDID block from display attached to
>>> controller's
>>> + * interface.
>>> - * @param EDIDBlockNumber block no. to be read from the display
>>> + * @param EDID_block_number block no. to be read from the display
>>>    * @param buffer place to store block fetched from the display
>>> paragraph
>>> paragraph
>>>   uint32_t VBE_read_EDID (
>>> diff --git a/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
>>> b/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
>>> index 6128d87..bd4e989 100644
>>> --- a/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
>>> +++ b/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
>>> @@ -7,7 +7,6 @@
>>> - * Definitions related to the PC386 BSP.
>>>    * This header file is also used in assembler modules.
>>> diff --git a/c/src/lib/libbsp/i386/pc386/include/vbe3.h
>>> b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
>>> index ba0ae3f..5aaa461 100644
>>> --- a/c/src/lib/libbsp/i386/pc386/include/vbe3.h
>>> +++ b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
>>> @@ -4,15 +4,15 @@
>>>    * @brief VESA Bios Extension definitions.
>>> + * This file contains definitions for constants related to VBE.
>>> - * vbe3.h  - This file contains definitions for constants related to
>>> VBE.
>>>    *                     CTU in Prague.
>>> @@ -156,22 +156,41 @@ extern "C" {
>>>   #define VBE_RetVBESupSpeInf    0x00  /* Return VBE Supplemental
>>>                                           Specification Information */
>>>   /* *** Structures *** */
>>> + * @brief Far pointer as defined by VBE standard.
>>>   typedef struct {
>>> +    /** @brief Offset to segment described by \a selector. */
>>>       uint16_t offset;
>>> +    /** @brief Selector or Segment depending on whether this is used
>>> from 16bit
>>> +        protected mode or from real mode. */
>>>       uint16_t selector;
>>>   } VBE3_PACKED_ATTRIBUTE VBE_FarPtr;
>>> + * @brief Protected mode info block as defined by VBE standard.
>>>   typedef struct {
>>> -    uint8_t   Signature[4];    /*  PM Info Block Signature */
>>> -    uint16_t  EntryPoint;      /*  Offset of PM entry point within BIOS
>>> -    uint16_t  PMInitialize;    /*  Offset of PM initialization entry
>>> point */
>>> -    uint16_t  BIOSDataSel;     /*  Selector to BIOS data area emulation
>>> block */
>>> -    uint16_t  A0000Sel;        /*  Selector to access A0000h physical
>>> mem */
>>> -    uint16_t  B0000Sel;        /*  Selector to access B0000h physical
>>> mem */
>>> -    uint16_t  B8000Sel;        /*  Selector to access B8000h physical
>>> mem */
>>> -    uint16_t  CodeSegSel;      /*  Selector to access code segment as
>>> data */
>>> -    uint8_t   InProtectMode;   /*  Set to 1 when in protected mode */
>>> -    uint8_t   Checksum;        /*  Checksum byte for structure */
>>> +    /** PM Info Block Signature */
>>> +    uint8_t   Signature[4];
>>> +    /** Offset of PM entry point within BIOS */
>>> +    uint16_t  EntryPoint;
>>> +    /** Offset of PM initialization entry point */
>>> +    uint16_t  PMInitialize;
>>> +    /** Selector to BIOS data area emulation block */
>>> +    uint16_t  BIOSDataSel;
>>> +    /** Selector to access A0000h physical memmory */
>>> +    uint16_t  A0000Sel;
>>> +    /** Selector to access B0000h physical memmory */
>>> +    uint16_t  B0000Sel;
>>> +    /** Selector to access B8000h physical memmory */
>>> +    uint16_t  B8000Sel;
>>> +    /** Selector to access code segment as data */
>>> +    uint16_t  CodeSegSel;
>>> +    /** Set to 1 when in protected mode */
>>> +    uint8_t   InProtectMode;
>>> +    /** Checksum byte for structure */
>>> +    uint8_t   Checksum;
>>>   } VBE3_PACKED_ATTRIBUTE VBE_PMInfoBlock;
>>>   /* General VBE signature */
>>> @@ -181,111 +200,201 @@ typedef struct {
>>>   /* for STUB see VBE CORE FUNCTIONS VERSION 3.0 - Appendix 1 */
>>>   #define VBE_END_OF_VideoModeList 0xFFFF
>>>   #define VBE_STUB_VideoModeList 0xFFFF
>>> + * @brief Information about VBE implementation.
>>>   typedef struct {
>>> -    uint8_t   VbeSignature[4];   /*  VBE Signature */
>>> -    uint16_t  VbeVersion;        /*  VBE Version */
>>> -    uint8_t  *OemStringPtr;      /*  VbeFarPtr to OEM String */
>>> -    uint8_t   Capabilities[4];   /*  Capabilities of graphics controller
>>> -    uint32_t *VideoModePtr;      /*  VbeFarPtr to VideoModeList */
>>> -    uint16_t  TotalMemory;       /*  Number of 64kb memory blocks    */
>>> +    /** VBE Signature */
>>> +    uint8_t   VbeSignature[4];
>>> +    /** VBE Version */
>>> +    uint16_t  VbeVersion;
>>> +    /** VbeFarPtr to OEM String */
>>> +    uint8_t  *OemStringPtr;
>>> +    /** Capabilities of graphics controller */
>>> +    uint8_t   Capabilities[4];
>>> +    /** VbeFarPtr to VideoModeList */
>>> +    uint32_t *VideoModePtr;
>>> +    /** Number of 64kb memory blocks    */
>>> +    uint16_t  TotalMemory;
>>>       /*  Added for VBE 2.0+ */
>>> -    uint16_t  OemSoftwareRev;    /*  VBE implementation Software
>>> revision */
>>> -    uint8_t  *OemVendorNamePtr;  /*  VbeFarPtr to Vendor Name String */
>>> -    uint8_t  *OemProductNamePtr; /*  VbeFarPtr to Product Name String */
>>> -    uint8_t  *OemProductRevPtr;  /*  VbeFarPtr to Product Revision
>>> String */
>>> -    uint8_t   Reserved[222];     /*  Reserved for VBE implementation
>>> scratch */
>>> -    /*    area */
>>> -    uint8_t   OemData[256];      /*  Data Area for OEM Strings */
>>> +    /** VBE implementation Software revision */
>>> +    uint16_t  OemSoftwareRev;
>>> +    /** VbeFarPtr to Vendor Name String */
>>> +    uint8_t  *OemVendorNamePtr;
>>> +    /** VbeFarPtr to Product Name String */
>>> +    uint8_t  *OemProductNamePtr;
>>> +    /** VbeFarPtr to Product Revision String */
>>> +    uint8_t  *OemProductRevPtr;
>>> +    /** Reserved for VBE implementation scratch */
>>> +    uint8_t   Reserved[222];
>>> +    /** Data Area for OEM Strings */
>>> +    uint8_t   OemData[256];
>>>   } VBE3_PACKED_ATTRIBUTE VBE_VbeInfoBlock;
>>> + * @brief Describes graphic's mode parameter.
>>>   typedef struct {
>>>       /*  Mandatory information for all VBE revisions */
>>> -    uint16_t  ModeAttributes;        /* mode attributes */
>>> -    uint8_t   WinAAttributes;        /* window A attributes */
>>> -    uint8_t   WinBAttributes;        /* window B attributes */
>>> -    uint16_t  WinGranularity;        /* window granularity */
>>> -    uint16_t  WinSize;               /* window size */
>>> -    uint16_t  WinASegment;           /* window A start segment */
>>> -    uint16_t  WinBSegment;           /* window B start segment */
>>> -    uint32_t *WinFuncPtr;            /* real mode pointer to window
>>> function */
>>> -    uint16_t  BytesPerScanLine;      /* bytes per scan line */
>>> +    /** mode attributes */
>>> +    uint16_t  ModeAttributes;
>>> +    /** window A attributes */
>>> +    uint8_t   WinAAttributes;
>>> +    /** window B attributes */
>>> +    uint8_t   WinBAttributes;
>>> +    /** window granularity */
>>> +    uint16_t  WinGranularity;
>>> +    /** window size */
>>> +    uint16_t  WinSize;
>>> +    /** window A start segment */
>>> +    uint16_t  WinASegment;
>>> +    /** window B start segment */
>>> +    uint16_t  WinBSegment;
>>> +    /** real mode pointer to window function */
>>> +    uint32_t *WinFuncPtr;
>>> +    /** bytes per scan line */
>>> +    uint16_t  BytesPerScanLine;
>>>       /*  Mandatory information for VBE 1.2 and above */
>>> -    uint16_t  XResolution;           /* horizontal resolution in px or
>>> chars */
>>> -    uint16_t  YResolution;           /* vertical resolution in px or
>>> chars */
>>> -    uint8_t   XCharSize;             /* character cell width in pixels
>>> -    uint8_t   YCharSize;             /* character cell height in pixels
>>> -    uint8_t   NumberOfPlanes;        /* number of memory planes */
>>> -    uint8_t   BitsPerPixel;          /* bits per pixel */
>>> -    uint8_t   NumberOfBanks;         /* number of banks */
>>> -    uint8_t   MemoryModel;           /* memory model type */
>>> -    uint8_t   BankSize;              /* bank size in KB */
>>> -    uint8_t   NumberOfImagePages;    /* number of images */
>>> -    uint8_t   Reserved0;             /* reserved for page function */
>>> +    /** horizontal resolution in px or chars */
>>> +    uint16_t  XResolution;
>>> +    /** vertical resolution in px or chars */
>>> +    uint16_t  YResolution;
>>> +    /** character cell width in pixels */
>>> +    uint8_t   XCharSize;
>>> +    /** character cell height in pixels */
>>> +    uint8_t   YCharSize;
>>> +    /** number of memory planes */
>>> +    uint8_t   NumberOfPlanes;
>>> +    uint8_t   BitsPerPixel;
>>> +    /** number of banks */
>>> +    uint8_t   NumberOfBanks;
>>> +    /** memory model type */
>>> +    uint8_t   MemoryModel;
>>> +    /** bank size in KB */
>>> +    uint8_t   BankSize;
>>> +    /** number of images */
>>> +    uint8_t   NumberOfImagePages;
>>> +    /** reserved for page function */
>>> +    uint8_t   Reserved0;
>>>       /*  Direct Color fields (required for direct/6 and YUV/7 memory
>>> models) */
>>> -    uint8_t   RedMaskSize;           /* size of direct color red mask in
>>> bits */
>>> -    uint8_t   RedFieldPosition;      /* bit position of lsb of red mask
>>> -    uint8_t   GreenMaskSize;         /* size of direct color green mask
>>> in b */
>>> -    uint8_t   GreenFieldPosition;    /* bit position of lsb of green
>>> mask */
>>> -    uint8_t   BlueMaskSize;          /* size of direct color blue mask
>>> in b */
>>> -    uint8_t   BlueFieldPosition;     /* bit position of lsb of blue mask
>>> -    uint8_t   RsvdMaskSize;          /* size of direct color reserved
>>> mask */
>>> -    uint8_t   RsvdFieldPosition;     /* bit position of lsb of reserved
>>> mask */
>>> -    uint8_t   DirectColorModeInfo;   /* direct color mode attributes */
>>> +    /** size of direct color red mask in bits */
>>> +    uint8_t   RedMaskSize;
>>> +    /** bit position of lsb of red mask */
>>> +    uint8_t   RedFieldPosition;
>>> +    /** size of direct color green mask in b */
>>> +    uint8_t   GreenMaskSize;
>>> +    /** bit position of lsb of green mask */
>>> +    uint8_t   GreenFieldPosition;
>>> +    /** size of direct color blue mask in b */
>>> +    uint8_t   BlueMaskSize;
>>> +    /** bit position of lsb of blue mask */
>>> +    uint8_t   BlueFieldPosition;
>>> +    /** size of direct color reserved mask */
>>> +    uint8_t   RsvdMaskSize;
>>> +    /** bit position of lsb of reserved mask */
>>> +    uint8_t   RsvdFieldPosition;
>>> +    /** direct color mode attributes */
>>> +    uint8_t   DirectColorModeInfo;
>>>       /*  Mandatory information for VBE 2.0 and above */
>>> -    uint32_t *PhysBasePtr;           /* physical address for
>>> -                                        flat memory frame buffer */
>>> -    uint32_t  Reserved1;             /* Reserved - always set to 0 */
>>> -    uint16_t  Reserved2;             /* Reserved - always set to 0 */
>>> +    /** physical address for flat memory frame buffer */
>>> +    uint32_t *PhysBasePtr;
>>> +    /** Reserved - always set to 0 */
>>> +    uint32_t  Reserved1;
>>> +    uint16_t  Reserved2;
>>>       /*  Mandatory information for VBE 3.0 and above */
>>> -    uint16_t  LinBytesPerScanLine;   /* bytes per scan line for linear
>>> modes */
>>> -    uint8_t   BnkNumberOfImagePages; /* number of images for banked
>>> modes */
>>> -    uint8_t   LinNumberOfImagePages; /* number of images for linear
>>> modes */
>>> +    /** bytes per scan line for linear modes */
>>> +    uint16_t  LinBytesPerScanLine;
>>> +    /** number of images for banked modes */
>>> +    uint8_t   BnkNumberOfImagePages;
>>> +    /** number of images for linear modes */
>>> +    uint8_t   LinNumberOfImagePages;
>>>           /* linear modes */
>>> -    uint8_t   LinRedMaskSize;        /* size of direct color red mask */
>>> -    uint8_t   LinRedFieldPosition;   /* bit position of lsb of red mask
>>> -    uint8_t   LinGreenMaskSize;      /* size of direct color green mask
>>> -    uint8_t   LinGreenFieldPosition; /* bit position of lsb of green
>>> mask */
>>> -    uint8_t   LinBlueMaskSize;       /* size of direct color blue mask
>>> -    uint8_t   LinBlueFieldPosition;  /* bit position of lsb of blue mask
>>> -    uint8_t   LinRsvdMaskSize;       /* size of direct color reserved
>>> mask */
>>> -    uint8_t   LinRsvdFieldPosition;  /* bit position of lsb of reserved
>>> mask */
>>> -    uint32_t  MaxPixelClock;         /* maximum pixel clock
>>> -                                        (in Hz) for graphics mode */
>>> -    uint8_t   Reserved3[189];        /* remainder of ModeInfoBlock */
>>> +    /** size of direct color red mask */
>>> +    uint8_t   LinRedMaskSize;
>>> +    uint8_t   LinRedFieldPosition;
>>> +    /** size of direct color green mask  */
>>> +    uint8_t   LinGreenMaskSize;
>>> +    uint8_t   LinGreenFieldPosition;
>>> +    /** size of direct color blue mask  */
>>> +    uint8_t   LinBlueMaskSize;
>>> +    uint8_t   LinBlueFieldPosition;
>>> +    uint8_t   LinRsvdMaskSize;
>>> +    uint8_t   LinRsvdFieldPosition;
>>> +    /** maximum pixel clock (in Hz) for graphics mode */
>>> +    uint32_t  MaxPixelClock;
>>> +    /** remainder of ModeInfoBlock */
>>> +    uint8_t   Reserved3[189];
>>>   } VBE3_PACKED_ATTRIBUTE VBE_ModeInfoBlock;
>>> + * @brief Describes monitor synchronization.
>>>   typedef struct {
>>> -    uint16_t  HorizontalTotal;       /* Horizontal total in pixels */
>>> -    uint16_t  HorizontalSyncStart;   /* Horizontal sync start in pixels
>>> -    uint16_t  HorizontalSyncEnd;     /* Horizontal sync end in pixels */
>>> -    uint16_t  VerticalTotal;         /* Vertical total in lines */
>>> -    uint16_t  VerticalSyncStart;     /* Vertical sync start in lines */
>>> -    uint16_t  VerticalSyncEnd;       /* Vertical sync end in lines */
>>> -    uint8_t   Flags;                 /* Flags (Interlaced, Double Scan
>>> etc) */
>>> -    uint32_t  PixelClock;            /* Pixel clock in units of Hz */
>>> -    uint16_t  RefreshRate;           /* Refresh rate in units of 0.01 Hz
>>> -    uint8_t   Reserved[40];          /* remainder of ModeInfoBlock */
>>> +    /** Horizontal total in pixels */
>>> +    uint16_t  HorizontalTotal;
>>> +    /** Horizontal sync start in pixels */
>>> +    uint16_t  HorizontalSyncStart;
>>> +    /** Horizontal sync end in pixels */
>>> +    uint16_t  HorizontalSyncEnd;
>>> +    /** Vertical total in lines */
>>> +    uint16_t  VerticalTotal;
>>> +    /** Vertical sync start in lines */
>>> +    uint16_t  VerticalSyncStart;
>>> +    /** Vertical sync end in lines */
>>> +    uint16_t  VerticalSyncEnd;
>>> +    /** Flags (Interlaced, Double Scan etc) */
>>> +    uint8_t   Flags;
>>> +    /** Pixel clock in units of Hz */
>>> +    uint32_t  PixelClock;
>>> +    /** Refresh rate in units of 0.01 Hz */
>>> +    uint16_t  RefreshRate;
>>> +    uint8_t   Reserved[40];
>>>   } VBE3_PACKED_ATTRIBUTE VBE_CRTCInfoBlock;
>>> + * @brief Describes palette entry.
>>>   typedef struct {
>>> -    uint8_t   Blue;                  /* Blue channel value (6 or 8 bits)
>>> -    uint8_t   Green;                 /* Green channel value (6 or 8
>>> bits) */
>>> -    uint8_t   Red;                   /* Red channel value(6 or 8 bits)
>>> -    uint8_t   Alignment;             /* DWORD alignment byte (unused) */
>>> +    /** Blue channel value (6 or 8 bits) */
>>> +    uint8_t   Blue;
>>> +    /** Green channel value (6 or 8 bits) */
>>> +    uint8_t   Green;
>>> +    /** Red channel value(6 or 8 bits) */
>>> +    uint8_t   Red;
>>> +    /** DWORD alignment byte (unused) */
>>> +    uint8_t   Alignment;
>>>   } VBE3_PACKED_ATTRIBUTE VBE_PaletteEntry;
>>> + * @brief Supplemental VBE info block.
>>>   typedef struct {
>>> -    uint8_t   SupVbeSignature[7];    /* Supplemental VBE Signature */
>>> -    uint16_t  SupVbeVersion;         /* Supplemental VBE Version */
>>> -    uint8_t   SupVbeSubFunc[8];      /* Bitfield of supported
>>> subfunctions */
>>> -    uint16_t  OemSoftwareRev;        /* OEM Software revision */
>>> String */
>>> -    uint8_t   Reserved[221];         /* Reserved for description
>>> -                                        strings and future */
>>> -    /*  expansion */
>>> +    /** Supplemental VBE Signature */
>>> +    uint8_t   SupVbeSignature[7];
>>> +    /** Supplemental VBE Version */
>>> +    uint16_t  SupVbeVersion;
>>> +    /** Bitfield of supported subfunctions */
>>> +    uint8_t   SupVbeSubFunc[8];
>>> +    /** OEM Software revision */
>>> +    /** Reserved for description strings and future expansion */
>>> +    uint8_t   Reserved[221];
>>>   } VBE3_PACKED_ATTRIBUTE VBE_SupVbeInfoBlock;
>>>   /* VbeInfoBlock Capabilities */
>>> diff --git a/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S
>>> b/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S
>>> index 14cbb95..9d61caf 100644
>>> --- a/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S
>>> +++ b/c/src/lib/libbsp/i386/pc386/startup/ldsegs.S
>>> @@ -200,7 +200,7 @@ SYM (_Global_descriptor_table):
>>>           PUBLIC(gdtdesc)
>>>   SYM(gdtdesc):
>>> -       .word (GDT_SIZE*8 - 1)
>>> +        .word (GDT_SIZE*8 - 1)
>>>          .long SYM (_Global_descriptor_table)
>>> @@ -210,7 +210,7 @@ SYM(gdtdesc):
>>>          PUBLIC(Interrupt_descriptor_table)
>>>   SYM(Interrupt_descriptor_table):
>>> -       .rept IDT_SIZE
>>> +        .rept IDT_SIZE
>>>          .word 0,0,0,0
>>>          .endr
>>> @@ -221,7 +221,7 @@ SYM(Interrupt_descriptor_table):
>>>          .p2align 4
>>>          PUBLIC(IDT_Descriptor)
>>>   SYM(IDT_Descriptor):
>>> -       .word  (IDT_SIZE*8 - 1)
>>> +        .word  (IDT_SIZE*8 - 1)
>>>          .long  SYM (Interrupt_descriptor_table)
>>>   END_DATA
>>> diff --git a/c/src/lib/libbsp/i386/shared/irq/idt.c
>>> b/c/src/lib/libbsp/i386/shared/irq/idt.c
>>> index fc9364e..ff7db36 100644
>>> --- a/c/src/lib/libbsp/i386/shared/irq/idt.c
>>> +++ b/c/src/lib/libbsp/i386/shared/irq/idt.c
>>> @@ -1,12 +1,12 @@
>>> - * cpu.c  - This file contains implementation of C function to
>>> + * idt.c  - This file contains implementation of C function to
>>>    *          instantiate IDT entries. More detailled information can be
>>> found
>>> - *         on Intel site and more precisely in the following book :
>>> + *          on Intel site and more precisely in the following book :
>>> - *             Pentium Processor family
>>> - *             Developper's Manual
>>> + *              Pentium Processor family
>>> + *              Developper's Manual
>>> - *             Volume 3 : Architecture and Programming Manual
>>> + *              Volume 3 : Architecture and Programming Manual
>>>    * Copyright (C) 1998  Eric Valette (valette at crf.canon.fr)
>>>    *                     Canon Centre Recherche France.
>>> diff --git a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
>>> b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
>>> index af5cf1e..8e9a83d 100644
>>> --- a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
>>> +++ b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
>>> @@ -1,20 +1,28 @@
>>> - *  Realmode interrupt call implementation.
>>> + * @file realmode_int.c
>>> + * @ingroup i386_shared
>>> + * @brief Real mode interrupt call implementation
>>>   #include <bsp/realmode_int.h>
>>>   #include <string.h>
>>>   #include <rtems/score/cpu.h>
>>> + * offsets to \a i386_realmode_interrupt_registers declared in
>>> realmode_int.h
>>> + * used in inline assmbler for better readability
>>>   #define IR_EAX_OFF      "0x00"
>>>   #define IR_EBX_OFF      "0x04"
>>>   #define IR_ECX_OFF      "0x08"
>>> @@ -26,25 +34,45 @@
>>>   #define IR_FS_OFF       "0x1C"
>>>   #define IR_GS_OFF       "0x1E"
>>> + * offsets to \a rm_int_regs_bkp_param
>>>   #define BKP_ESP_OFF     "0x20"
>>>   #define BKP_SS_OFF      "0x24"
>>>   #define BKP_DS_OFF      "0x26"
>>>   #define RM_ENTRY        "0x28"
>>>   #define PM_ENTRY        "0x2C"
>>> -/* parameters, results, backup values accessible in real mode */
>>> + * @brief parameters, results, backup values accessible in real mode
>>> + * @note Struct members not necessarily used in C. This serves also as
>>> + *       layout of memory and it is used within inline assembler.
>>>   typedef struct {
>>>       i386_realmode_interrupt_registers inoutregs;
>>> +    /** spot for back up of protected mode stack pointer */
>>>       uint32_t pm_esp_bkp;
>>> +    /** spot for back up of protected mode stack selector */
>>>       uint16_t pm_ss_bkp;
>>> +    /** spot for back up of protected mode data selector */
>>>       uint16_t ds_bkp;
>>> +    /** spot for setting up long indirect jump offset
>>> +        to real mode from 16bit protected mode */
>>>       uint16_t rm_entry;
>>> +    /** spot for setting up long indirect jump segment
>>>       uint16_t rm_code_segment;
>>> +    /** returning offset for long indirect jump back
>>> +        to 32bit protected mode */
>>>       uint32_t pm_entry;
>>> +    /** returning selector for long indirect jump back
>>>       uint16_t pm_code_selector;
>>> -    /* if modifying update offset definitions as well */
>>> +    /* if this struct is to be modified update offset definitions as
>>> well */
>>>   } RTEMS_COMPILER_PACKED_ATTRIBUTE rm_int_regs_bkp_param;
>>> +/* offsets to \a pm_bkp_and_param */
>>>   #define BKP_IDTR_LIM    "0x00"
>>>   #define BKP_IDTR_BASE   "0x02"
>>>   #define BKP_ES_OFF      "0x06"
>>> @@ -55,18 +83,35 @@ typedef struct {
>>>   #define RM_SS           "0x14"
>>>   #define RM_SP           "0x16"
>>>   #define RM_DS           "0x18"
>>> -/* backup values, pointers/parameters accessible in protected mode */
>>> + * @brief backup values, pointers/parameters accessible in protected
>>> mode
>>>   typedef struct {
>>> +    /** spot for backup protected mode interrupt descriptor table
>>> register */
>>>       uint16_t idtr_lim_bkp;
>>> +    /** @see idtr_lim_bkp */
>>>       uint32_t idtr_base_bkp;
>>> +    /** spot to backup of ES register value in 32bit protected mode */
>>>       uint16_t es_bkp;
>>> +    /** spot to backup of FS register value in 32bit protected mode */
>>>       uint16_t fs_bkp;
>>> +    /** spot to backup of GS register value in 32bit protected mode */
>>>       uint16_t gs_bkp;
>>> +    /** values for indirect jump to 16bit protected mode */
>>>       uint32_t rml_entry;
>>> +    /** @see rml_entry */
>>>       uint16_t rml_code_selector;
>>> +    /** data selector for 16bit protected mode */
>>>       uint16_t rml_data_selector;
>>> +    /** values determinig location of real mode stack */
>>>       uint16_t rm_stack_segment;
>>> +    /** @see rm_stack_segment */
>>>       uint16_t rm_stack_pointer;
>>> +    /** data segment for real mode */
>>>       uint16_t rm_data_segment;
>>>   } RTEMS_COMPILER_PACKED_ATTRIBUTE pm_bkp_and_param;
>>> @@ -112,10 +157,14 @@ static __DP_TYPE descsPrepared = __DP_NO;
>>>   static uint16_t rml_code_dsc_index = 0;
>>>   static uint16_t rml_data_dsc_index = 0;
>>> - * Prepares real-mode like descriptors to be used for switching
>>> + * @brief Prepares real-mode like descriptors to be used for switching
>>>    * to real mode.
>>> + * Descriptors will be placed to the GDT.
>>> + * @param[in] base32 32-bit physical address to be used as base for
>>> 16-bit
>>> + *               protected mode descriptors
>>>    * @retval __DP_YES descriptors are prepared
>>>    * @retval __DP_FAIL descriptors allocation failed (GDT too small)
>>> diff --git a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
>>> b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
>>> index a0216ea..6f77ec9 100644
>>> --- a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
>>> +++ b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
>>> @@ -4,14 +4,14 @@
>>>    * @brief Definitioins supporting real mode interrupt calls.
>>> + * Interface allows calling given interrupt number with content of the
>>> + * registers defined. For passing or receiving higher amounts of the
>>> data
>>> + * there is a buffer accessible from real mode available. Real mode
>>> pointer
>>> + * to this buffer is passed to the interrupt in the registers.
>>> - *  Interface allows calling given interrupt number with content of the
>>> - *  registers defined. For passing or receiving higher amounts of the
>>> data
>>> - *  there is a buffer accessible from real mode available. Real mode
>>> pointer
>>> - *  to this buffer is passed to the interrupt in the registers.
>>>    *                     CTU in Prague.
>>> @@ -36,7 +36,11 @@ extern "C" {
>>>   /* number of interrupt servicing video functions */
>>>   #define INTERRUPT_NO_VIDEO_SERVICES 0x10
>>> -typedef struct { /* used for passing parameters, fetching results and
>>> preserving values */
>>> + * @brief Used for passing and retrieving registers content to/from real
>>> mode
>>> + * interrupt call.
>>> +typedef struct {
>>>       uint32_t reg_eax;
>>>       uint32_t reg_ebx;
>>>       uint32_t reg_ecx;
>>> @@ -50,6 +54,8 @@ typedef struct { /* used for passing parameters,
>>> fetching results and preserving
>>>   } RTEMS_COMPILER_PACKED_ATTRIBUTE i386_realmode_interrupt_registers;
>>> + * @brief Returns buffer and its size usable with real mode interrupt
>>> call.
>>>    * Provides position to real mode buffer. It is buffer
>>>    * accessible from real mode context - it is located below
>>>    * address ~0x100000 in order for it to be accessible
>>> @@ -57,22 +63,25 @@ typedef struct { /* used for passing parameters,
>>>    * and through this get bigger portion of an information to/from
>>>    * interrupt service routine than just by using register.
>>> - * @param size pointer to variable, where the size of buffer
>>> - *        will be filled
>>> + * @param[out] size pointer to variable, where the size of buffer
>>> + *             will be filled
>>>    * @retval pointer to buffer
>>>   extern void *i386_get_default_rm_buffer(uint16_t *size);
>>> + * @brief Call to real mode interrupt with specified int NO and
>>> processor
>>> + * registers.
>>>    * This function allows calling interrupts in real mode and to set
>>> processor
>>>    * registers as desired before interrupt call is made and to retrieve
>>> the
>>>    * registers content after call was made.
>>> - * @param interruptNumber interrupt number to be called
>>> - * @param ir pointer to structure containing registers to be passed to
>>> interrupt
>>> - *        and to retrieve register content after call was made.
>>> + * @param[in] interrupt_number interrupt number to be called
>>> + * @param[in] ir pointer to structure containing registers to be passed
>>> to
>>> + *            interrupt and to retrieve register content after call was
>>> made.
>>>    * @retval  0 call failed (GDT too small or pagin is on)
>>> - *          1 call successful
>>> + * @retval  1 call successful
>>>   extern int i386_real_interrupt_call(
>>>       uint8_t interrupt_number,
>>> diff --git a/c/src/lib/libcpu/i386/cpu.h b/c/src/lib/libcpu/i386/cpu.h
>>> index 23a82de..50234a6 100644
>>> --- a/c/src/lib/libcpu/i386/cpu.h
>>> +++ b/c/src/lib/libcpu/i386/cpu.h
>>> @@ -1,5 +1,7 @@
>>> - * cpu.h  - This file contains definitions for data structure related
>>> + * @file cpu.h
>>> + *          This file contains definitions for data structure related
>>>    *          to Intel system programming. More information can be found
>>> @@ -241,7 +243,9 @@ extern int i386_get_idt_config
>>> (rtems_raw_irq_global_settings** config);
>>>    * See page 11.12 Figure 11-8.
>>> + * @brief segment_descriptors sturcture describes one entry of
>>> Descriptor Table
>>>   typedef struct {
>>>     unsigned int limit_15_0              : 16;
>>>     unsigned int base_address_15_0       : 16;
>>> @@ -272,34 +276,36 @@ extern void i386_set_GDTR (segment_descriptors*,
>>>                              uint16_t limit);
>>> - * C callable function:
>>> - * Puts global descriptor @sd to the global descriptor table on index
>>> - * @segment_selector_index
>>> + * @brief Allows to set a GDT entry.
>>> + * Puts global descriptor \p sd to the global descriptor table on index
>>> + * \p segment_selector_index
>>> + * @param[in] segment_selector_index index to GDT entry
>>> + * @param[in] sd structure to be coppied to given \p segment_selector in
>>> GDT
>>>    * @retval  0 FAILED out of GDT range or index is 0, which is not valid
>>>    *                   index in GDT
>>> - *          1 SUCCESS
>>> + * @retval  1 SUCCESS
>>>   extern uint32_t i386_raw_gdt_entry (uint16_t segment_selector_index,
>>>                                  segment_descriptors* sd);
>>> - * fills @sd with provided @base in appropriate fields of @sd
>>> + * @brief fills \p sd with provided \p base in appropriate fields of \p
>>> sd
>>>    * @param base 32-bit address to be set as descriptor's base
>>> - * @param sd descriptor being filled with @base
>>> + * @param sd descriptor being filled with \p base
>>>   extern void i386_fill_segment_desc_base (uint32_t base,
>>> - * fills @sd with provided @limit in appropriate fields of @sd
>>> - * also influences granularity bit
>>> + * @brief fills \p sd with provided \p limit in appropriate fields of \p
>>> sd
>>> + * sets granularity bit if necessary
>>>    * @param limit 32-bit value representing number of limit bytes
>>> - * @param sd descriptor being filled with @limit
>>> + * @param sd descriptor being filled with \p limit
>>>   extern void i386_fill_segment_desc_limit (uint32_t limit,
>>> @@ -312,35 +318,36 @@ extern uint32_t i386_set_gdt_entry (uint16_t
>>> segment_selector,
>>>                                       uint32_t limit);
>>> - * C callable function returns next empty descriptor in GDT.
>>> + * @brief Returns next empty descriptor in GDT.
>>>    * @retval  0 FAILED GDT is full
>>> - *          <1;65535> segment_selector number as index to GDT
>>> + * @retval  <1;65535> segment_selector number as index to GDT
>>>   extern uint16_t i386_next_empty_gdt_entry (void);
>>> - * Copies GDT entry at index @segment_selector to structure
>>> - * pointed to by @struct_to_fill
>>> + * @brief Copies GDT entry at index \p segment_selector to structure
>>> + * pointed to by \p struct_to_fill
>>>    * @param  segment_selector index to GDT table for specifying
>>> descriptor to copy
>>> + * @param  struct_to_fill pointer to memory where should be descriptor
>>> coppied
>>>    * @retval  0 FAILED segment_selector out of GDT range
>>> - *          <1;65535> retrieved segment_selector
>>> + * @retval  <1;65535> retrieved segment_selector
>>>   extern uint16_t i386_cpy_gdt_entry (uint16_t segment_selector,
>>> struct_to_fill);
>>> - * Returns pointer to GDT table at index given by @segment_selector
>>> + * @brief Returns pointer to GDT table at index given by \p
>>> segment_selector
>>> - * @param   segment_selector index to GDT table for specifying
>>> descriptor to get
>>> + * @param   sgmnt_selector index to GDT table for specifying descriptor
>>> to get
>>>    * @retval  NULL FAILED segment_selector out of GDT range
>>> - *          pointer to GDT table at @segment_selector
>>> + * @retval  pointer to GDT table at \p segment_selector
>>>   extern segment_descriptors* i386_get_gdt_entry (uint16_t
>>> sgmnt_selector);
>>> - * Extracts base address from GDT entry pointed to by @gdt_entry
>>> + * @brief Extracts base address from GDT entry pointed to by \p
>>> gdt_entry
>>>    * @param  gdt_entry pointer to entry from which base should be
>>> retrieved
>>>    * @retval base address from GDT entry
>>> @@ -353,7 +360,7 @@ RTEMS_INLINE_ROUTINE void* i386_base_gdt_entry
>>> (segment_descriptors* gdt_entry)
>>> - * Extracts limit in bytes from GDT entry pointed to by @gdt_entry
>>> + * @brief Extracts limit in bytes from GDT entry pointed to by \p
>>> gdt_entry
>>>    * @param  gdt_entry pointer to entry from which limit should be
>>> retrieved
>>>    * @retval limit value in bytes from GDT entry
>>> diff --git a/cpukit/score/cpu/i386/cpu_asm.S
>>> b/cpukit/score/cpu/i386/cpu_asm.S
>>> index f3ef4e2..45079a6 100644
>>> --- a/cpukit/score/cpu/i386/cpu_asm.S
>>> +++ b/cpukit/score/cpu/i386/cpu_asm.S
>>> @@ -334,9 +334,9 @@ SYM (i386_Physical_to_logical):
>>>    *     uint16_t *offset
>>> - *  Fills segment:offest realmode pointer counted from thirty-two bit
>>> physical
>>> + *  Fills segment:offest real mode pointer counted from thirty-two bit
>>> physical
>>>    *  address.
>>> - *  Returns 0 if unconvertible, 1 if successfuly converted.
>>> + *  Returns 0 if inconvertible, 1 if successfuly converted.
>>>   .set PHYS_PTR_ARG,   4
>>> diff --git a/cpukit/score/cpu/i386/rtems/score/i386.h
>>> b/cpukit/score/cpu/i386/rtems/score/i386.h
>>> index 926627d..875526a 100644
>>> --- a/cpukit/score/cpu/i386/rtems/score/i386.h
>>> +++ b/cpukit/score/cpu/i386/rtems/score/i386.h
>>> @@ -185,10 +185,14 @@ void *i386_Physical_to_logical(
>>>     void           *address
>>> - *  i386_Real_to_physical
>>> + * @brief Converts real mode pointer {segment, offset} to physical
>>> address.
>>> + * i386_Real_to_physical
>>> - *  Converts real mode pointer {segment, offset} to physical address.
>>> + * @param[in] segment used with \p offset to compute physical address
>>> + * @param[in] offset used with \p segment to compute physical address
>>> + * @retval    physical address
>>>   RTEMS_INLINE_ROUTINE void *i386_Real_to_physical(
>>>       uint16_t segment,
>>> @@ -197,19 +201,24 @@ RTEMS_INLINE_ROUTINE void *i386_Real_to_physical(
>>>       return (void *)(((uint32_t)segment<<4)+offset);
>>> - *  i386_Physical_to_real
>>> - *  Retreives real mode pointer elements {segmnet, offset} from physical
>>> address
>>> - *  Function returns the highest segment (base) address possible.
>>> - *  Example:    input   address - 0x4B3A2
>>> - *              output  segment - 0x4B3A
>>> - *                      offset  - 0x2
>>> - *              input   address - 0x10F12E
>>> - *              output  segment - 0xFFFF
>>> - *                      offset  - 0xF13E
>>> + * @brief Retreives real mode pointer elements {segmnet, offset} from
>>> + * physical address.
>>> + * i386_Physical_to_real
>>> + * Function returns the highest segment (base) address possible.
>>> + * Example:    input   address - 0x4B3A2
>>> + *             output  segment - 0x4B3A
>>> + *                     offset  - 0x2
>>> + *             input   address - 0x10F12E
>>> + *             output  segment - 0xFFFF
>>> + *                     offset  - 0xF13E
>>> - *  return  0 address not convertible, must be less than 0x10FFEF
>>> - *          1 segment and offset extracted
>>> + * @param[in]  address address to be converted, must be less than
>>> 0x10FFEF
>>> + * @param[out] segment segment computed from \p address
>>> + * @param[out] offset offset computed from \p address
>>> + * @retval  0 address not convertible
>>> + * @retval  1 segment and offset extracted
>>>   int i386_Physical_to_real(
>>>     void *address,
>>> 1.9.1
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
