[PATCH 1/3] i386/pc386: cammelCase (struct and function names) to underscores, typedefed structs, break >80 chars lines, removed newlines at EOFs
Jan Dolezal dolezj21 at fel.cvut.cz
Wed Dec 3 23:56:38 UTC 2014
fb_vesa_rm.c: removed inline from functions declared in fb_vesa.h
              removed unnecessary printks in the end of patch
edid.h, vbe3.h: switched from custom *PACKED_ATTRIBUTE at the structs to the
                RTEMS_COMPILER_PACKED_ATTRIBUTE for easier maintainability
                of doxygen
 c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c   | 293 +++++++++++----------
 c/src/lib/libbsp/i386/pc386/include/edid.h         | 123 +++++----
 c/src/lib/libbsp/i386/pc386/include/fb_vesa.h      |  38 +--
 c/src/lib/libbsp/i386/pc386/include/tblsizes.h     |   1 -
 c/src/lib/libbsp/i386/pc386/include/vbe3.h         |  30 +--
 .../libbsp/i386/shared/realmode_int/realmode_int.c |   5 +-
 .../libbsp/i386/shared/realmode_int/realmode_int.h |   5 +-
 7 files changed, 250 insertions(+), 245 deletions(-)
diff --git a/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c b/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
index 6b26d35..e5acbd5 100644
--- a/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
+++ b/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
@@ -59,14 +59,14 @@ static pthread_mutex_t vesa_mutex = PTHREAD_MUTEX_INITIALIZER;
 static struct fb_var_screeninfo fb_var;
 static struct fb_fix_screeninfo fb_fix;
-static uint16_t vbe_usedMode;
+static uint16_t vbe_used_mode;
-inline uint32_t VBEControllerInformation(   struct VBE_VbeInfoBlock *infoBlock,
-                                            uint16_t queriedVBEVersion)
+uint32_t VBE_controller_information( VBE_vbe_info_block *info_block,
+                                            uint16_t queried_VBE_Version)
     uint16_t size;
-    struct VBE_VbeInfoBlock *VBE_buffer =
-        (struct VBE_VbeInfoBlock *)i386_get_default_rm_buffer(&size);
+    VBE_vbe_info_block *VBE_buffer =
+        (VBE_vbe_info_block *)i386_get_default_rm_buffer(&size);
     i386_realmode_interrupt_registers parret;
     parret.reg_eax = VBE_RetVBEConInf;
     uint16_t seg, off;
@@ -74,7 +74,7 @@ inline uint32_t VBEControllerInformation(   struct VBE_VbeInfoBlock *infoBlock,
     parret.reg_edi = (uint32_t)off;
     parret.reg_es = seg;
     /* indicate to graphic's bios that VBE2.0 extended information is desired */
-    if (queriedVBEVersion >= 0x200)
+    if (queried_VBE_Version >= 0x200)
         strncpy(
             (char *)&VBE_buffer->VbeSignature,
@@ -87,20 +87,20 @@ inline uint32_t VBEControllerInformation(   struct VBE_VbeInfoBlock *infoBlock,
     if ((parret.reg_eax & 0xFFFF) ==
         (VBE_callSuccessful<<8 | VBE_functionSupported))
-        *infoBlock = *VBE_buffer;
+        *info_block = *VBE_buffer;
     return (parret.reg_eax & 0xFFFF);
-inline uint32_t VBEModeInformation( struct VBE_ModeInfoBlock *infoBlock,
-                                    uint16_t modeNumber)
+uint32_t VBE_mode_information( VBE_mode_info_block *info_block,
+                                    uint16_t mode_number)
     uint16_t size;
-    struct VBE_ModeInfoBlock *VBE_buffer =
-        (struct VBE_ModeInfoBlock *)i386_get_default_rm_buffer(&size);
+    VBE_mode_info_block *VBE_buffer =
+        (VBE_mode_info_block *)i386_get_default_rm_buffer(&size);
     parret.reg_eax = VBE_RetVBEModInf;
-    parret.reg_ecx = modeNumber;
+    parret.reg_ecx = mode_number;
     uint16_t seg, off;
     i386_Physical_to_real(VBE_buffer, &seg, &off);
@@ -110,22 +110,22 @@ inline uint32_t VBEModeInformation( struct VBE_ModeInfoBlock *infoBlock,
-inline uint32_t VBESetMode( uint16_t modeNumber,
-                            struct VBE_CRTCInfoBlock *infoBlock)
+uint32_t VBE_set_mode( uint16_t mode_number,
+                            VBE_CRTC_info_block *info_block)
     uint16_t size;
-    struct VBE_CRTCInfoBlock *VBE_buffer =
-        (struct VBE_CRTCInfoBlock *)i386_get_default_rm_buffer(&size);
+    VBE_CRTC_info_block *VBE_buffer =
+        (VBE_CRTC_info_block *)i386_get_default_rm_buffer(&size);
     /* copy CRTC */
-    *VBE_buffer = *infoBlock;
+    *VBE_buffer = *info_block;
     parret.reg_eax = VBE_SetVBEMod;
-    parret.reg_ebx = modeNumber;
+    parret.reg_ebx = mode_number;
     uint16_t seg, off;
@@ -135,44 +135,44 @@ inline uint32_t VBESetMode( uint16_t modeNumber,
-inline uint32_t VBECurrentMode(uint16_t *modeNumber)
+uint32_t VBE_current_mode(uint16_t *mode_number)
     parret.reg_eax = VBE_RetCurVBEMod;
     if (i386_real_interrupt_call(INTERRUPT_NO_VIDEO_SERVICES, &parret) == 0)
         return -1;
-    *modeNumber = (uint16_t)parret.reg_ebx;
+    *mode_number = (uint16_t)parret.reg_ebx;
-inline uint32_t VBEReportDDCCapabilities(   uint16_t controllerUnitNumber,
-                                            uint8_t *secondsToTransferEDIDBlock,
-                                            uint8_t *DDCLevelSupported)
+uint32_t VBE_report_DDC_capabilities(uint16_t controller_unit_number,
+                                        uint8_t *seconds_to_transfer_EDID_block,
+                                        uint8_t *DDC_level_supported)
     parret.reg_eax = VBE_DisDatCha;
     parret.reg_ebx = VBEDDC_Capabilities;
-    parret.reg_ecx = controllerUnitNumber;
+    parret.reg_ecx = controller_unit_number;
     parret.reg_edi = 0;
     parret.reg_es = 0;
         return -1;
-    *secondsToTransferEDIDBlock = (uint8_t)parret.reg_ebx >> 8;
-    *DDCLevelSupported = (uint8_t)parret.reg_ebx;
+    *seconds_to_transfer_EDID_block = (uint8_t)parret.reg_ebx >> 8;
+    *DDC_level_supported = (uint8_t)parret.reg_ebx;
-inline uint32_t VBEReadEDID(uint16_t controllerUnitNumber,
-                            uint16_t EDIDBlockNumber,
-                            struct edid1 *buffer)
+uint32_t VBE_read_EDID(uint16_t controller_unit_number,
+                            uint16_t EDID_block_number,
+                            EDID_edid1 *buffer)
     uint16_t size;
-    struct edid1 *VBE_buffer = (struct edid1 *)i386_get_default_rm_buffer(&size);
+    EDID_edid1 *VBE_buffer = (EDID_edid1*)i386_get_default_rm_buffer(&size);
     parret.reg_ebx = VBEDDC_ReadEDID;
-    parret.reg_edx = EDIDBlockNumber;
+    parret.reg_edx = EDID_block_number;
     uint16_t seg, off;
@@ -188,11 +188,11 @@ inline uint32_t VBEReadEDID(uint16_t controllerUnitNumber,
 typedef struct {
-    uint16_t modeNumber;
+    uint16_t mode_number;
     uint16_t resX;
     uint16_t resY;
     uint8_t bpp;
-} modeParams;
+} Mode_params;
 /* finds mode in 'modeList' of 'listLength' length according to resolution
     given in 'searchedResolution'. If bpp is given in that struct as well
@@ -200,22 +200,22 @@ typedef struct {
     has to be zero. Mode number found is returned and also filled into
     'searchedResolution'. bpp is also filled into 'searchedResolution' if it
     was 0 before call. */
-static uint16_t findModeByResolution(   modeParams *modeList,
-                                        uint8_t listLength,
-                                        modeParams *searchedResolution)
+static uint16_t find_mode_by_resolution(Mode_params *mode_list,
+                                        uint8_t list_length,
+                                        Mode_params *searched_resolution)
     uint8_t i = 0;
-    while (i < listLength)
+    while (i < list_length)
-        if (searchedResolution->resX == modeList[i].resX &&
-            searchedResolution->resY == modeList[i].resY)
+        if (searched_resolution->resX == mode_list[i].resX &&
+            searched_resolution->resY == mode_list[i].resY)
-            if (searchedResolution->bpp==0 ||
-                searchedResolution->bpp==modeList[i].bpp)
+            if (searched_resolution->bpp==0 ||
+                searched_resolution->bpp==mode_list[i].bpp)
-                searchedResolution->bpp = modeList[i].bpp;
-                searchedResolution->modeNumber = modeList[i].modeNumber;
-                return modeList[i].modeNumber;
+                searched_resolution->bpp = mode_list[i].bpp;
+                searched_resolution->mode_number = mode_list[i].mode_number;
+                return mode_list[i].mode_number;
         i++;
@@ -232,33 +232,33 @@ static uint16_t findModeByResolution(   modeParams *modeList,
  * @retval video mode number to be set
  *         -1 on parsing error or when no suitable mode found
-static uint16_t findModeUsingCmdline(   modeParams *modeList,
-                                        uint8_t listLength)
+static uint16_t find_mode_using_cmdline(Mode_params *mode_list,
+                                        uint8_t list_length)
     const char* opt;
-    modeParams cmdlineMode;
+    Mode_params cmdline_mode;
     char* endptr;
-    cmdlineMode.bpp = 0;
+    cmdline_mode.bpp = 0;
     opt = bsp_cmdline_arg("--video=");
     if (opt)
         opt += sizeof("--video=")-1;
-        cmdlineMode.resX = strtol(opt, &endptr, 10);
+        cmdline_mode.resX = strtol(opt, &endptr, 10);
         if (*endptr != 'x')
             return -1;
         opt = endptr+1;
-        cmdlineMode.resY = strtol(opt, &endptr, 10);
+        cmdline_mode.resY = strtol(opt, &endptr, 10);
         switch (*endptr)
             case '-':
                 opt = endptr+1;
                 if (strlen(opt) <= 2)
-                    cmdlineMode.bpp = strtol(opt, &endptr, 10);
+                    cmdline_mode.bpp = strtol(opt, &endptr, 10);
                 else
                     if (*endptr != ' ')
                         return -1;
@@ -271,9 +271,9 @@ static uint16_t findModeUsingCmdline(   modeParams *modeList,
                 return -1;
-        if (findModeByResolution(modeList, listLength, &cmdlineMode) !=
+        if (find_mode_by_resolution(mode_list, list_length, &cmdline_mode) !=
             (uint16_t)-1)
-            return cmdlineMode.modeNumber;
+            return cmdline_mode.mode_number;
     return -1;
@@ -284,17 +284,17 @@ static uint16_t findModeUsingCmdline(   modeParams *modeList,
-static uint16_t findModeUsingEDID(  modeParams *modeList,
+static uint16_t find_mode_using_EDID( Mode_params *mode_list,
-    struct edid1 edid;
+    EDID_edid1 edid;
     uint8_t checksum, iterator;
     uint8_t index, j;
-    modeParams EDIDmode;
+    Mode_params EDIDmode;
     checksum = 0;
     iterator = 0;
     EDIDmode.bpp = 0;
-    if (VBEReadEDID(0, 0, &edid) !=
+    if (VBE_read_EDID(0, 0, &edid) !=
         printk(FB_VESA_NAME " Function 15h (read EDID) not supported.\n");
@@ -303,7 +303,7 @@ static uint16_t findModeUsingEDID(  modeParams *modeList,
 /* version of EDID structure */
     if (edid.Version == 1)
     { /* EDID version 1 */
-        while (iterator < sizeof(struct edid1))
+        while (iterator < sizeof(EDID_edid1))
             checksum += *((uint8_t *)&edid+iterator);
             iterator++;
@@ -325,11 +325,11 @@ static uint16_t findModeUsingEDID(  modeParams *modeList,
                 index++;
                 continue;
-            EDIDmode.resX = DTD_HorizontalActive(&edid.dtd_md[0].dtd);
-            EDIDmode.resY = DTD_VerticalActive(&edid.dtd_md[0].dtd);
-            if (findModeByResolution(modeList, listLength, &EDIDmode) !=
+            EDIDmode.resX = DTD_horizontal_active(&edid.dtd_md[0].dtd);
+            EDIDmode.resY = DTD_vertical_active(&edid.dtd_md[0].dtd);
+            if (find_mode_by_resolution(mode_list, list_length, &EDIDmode) !=
                 (uint16_t)-1)
-                return EDIDmode.modeNumber;
+                return EDIDmode.mode_number;
             index++;
@@ -350,13 +350,15 @@ static uint16_t findModeUsingEDID(  modeParams *modeList,
                 edid.dtd_md[index].md.Flag1 == 0     &&
                 edid.dtd_md[index].md.Flag2 == 0)
-                struct CVTTimingCodes3B *cvt = (struct CVTTimingCodes3B *)
+                EDID_CVT_timing_codes_3B *cvt = (EDID_CVT_timing_codes_3B *)
                     &edid.dtd_md[index].md.DescriptorData[0];
                 j = 0;
                 while (j < 4)
-                    EDIDmode.resY = edid1_CVT_AddressableLinesHigh(&cvt->cvt[j]);
-                    switch (edid1_CVT_AspectRatio(&cvt->cvt[j]))
+                    EDIDmode.resY = edid1_CVT_addressable_lines_high(
+                        &cvt->cvt[j]
+                    switch (edid1_CVT_aspect_ratio(&cvt->cvt[j]))
                         case EDID_CVT_AspectRatio_4_3:
                             EDIDmode.resX = (EDIDmode.resY*4)/3;
@@ -372,9 +374,9 @@ static uint16_t findModeUsingEDID(  modeParams *modeList,
                             break;
                     EDIDmode.resX = (EDIDmode.resX/8)*8;
-                        (uint16_t)-1)
+                            mode_list, list_length, &EDIDmode) != (uint16_t)-1)
                     j++;
@@ -396,7 +398,8 @@ static uint16_t findModeUsingEDID(  modeParams *modeList,
                 continue;
             EDIDmode.resX = (edid.STI[index].HorizontalActivePixels+31)*8;
-            switch (edid.STI[index].ImageAspectRatio_RefreshRate & EDID1_STI_ImageAspectRatioMask)
+            switch (edid.STI[index].ImageAspectRatio_RefreshRate &
+                    EDID1_STI_ImageAspectRatioMask)
                 case EDID_STI_AspectRatio_16_10:
                     EDIDmode.resY = (EDIDmode.resX*10)/16;
@@ -411,9 +414,9 @@ static uint16_t findModeUsingEDID(  modeParams *modeList,
                     EDIDmode.resY = (EDIDmode.resX*9)/16;
                     break;
                 (uint16_t)-1)
             index++;
@@ -421,78 +424,78 @@ static uint16_t findModeUsingEDID(  modeParams *modeList,
         in controller mode list */
         /* not implemented */
         /* use Established Timings */
-        if (edid1_EstablishedTim(&edid, EST_1280x1024_75Hz))
+        if (edid1_established_tim(&edid, EST_1280x1024_75Hz))
             EDIDmode.resX = 1280;
             EDIDmode.resY = 1024;
             EDIDmode.bpp = 0;
                 (uint16_t)-1)
-        if (edid1_EstablishedTim(&edid, EST_1152x870_75Hz))
+        if (edid1_established_tim(&edid, EST_1152x870_75Hz))
             EDIDmode.resX = 1152;
             EDIDmode.resY = 870;
             EDIDmode.bpp = 0;
                 (uint16_t)-1)
-        if (edid1_EstablishedTim(&edid, EST_1024x768_75Hz) ||
-            edid1_EstablishedTim(&edid, EST_1024x768_70Hz) ||
-            edid1_EstablishedTim(&edid, EST_1024x768_60Hz) ||
-            edid1_EstablishedTim(&edid, EST_1024x768_87Hz))
+        if (edid1_established_tim(&edid, EST_1024x768_75Hz) ||
+            edid1_established_tim(&edid, EST_1024x768_70Hz) ||
+            edid1_established_tim(&edid, EST_1024x768_60Hz) ||
+            edid1_established_tim(&edid, EST_1024x768_87Hz))
             EDIDmode.resX = 1024;
             EDIDmode.resY = 768;
             EDIDmode.bpp = 0;
                 (uint16_t)-1)
-        if (edid1_EstablishedTim(&edid, EST_832x624_75Hz))
+        if (edid1_established_tim(&edid, EST_832x624_75Hz))
             EDIDmode.resX = 832;
             EDIDmode.resY = 624;
             EDIDmode.bpp = 0;
                 (uint16_t)-1)
-        if (edid1_EstablishedTim(&edid, EST_800x600_60Hz) ||
-            edid1_EstablishedTim(&edid, EST_800x600_56Hz) ||
-            edid1_EstablishedTim(&edid, EST_800x600_75Hz) ||
-            edid1_EstablishedTim(&edid, EST_800x600_72Hz))
+        if (edid1_established_tim(&edid, EST_800x600_60Hz) ||
+            edid1_established_tim(&edid, EST_800x600_56Hz) ||
+            edid1_established_tim(&edid, EST_800x600_75Hz) ||
+            edid1_established_tim(&edid, EST_800x600_72Hz))
             EDIDmode.resX = 800;
             EDIDmode.resY = 600;
             EDIDmode.bpp = 0;
                 (uint16_t)-1)
-        if (edid1_EstablishedTim(&edid, EST_720x400_88Hz) ||
-            edid1_EstablishedTim(&edid, EST_720x400_70Hz))
+        if (edid1_established_tim(&edid, EST_720x400_88Hz) ||
+            edid1_established_tim(&edid, EST_720x400_70Hz))
             EDIDmode.resX = 720;
             EDIDmode.resY = 400;
             EDIDmode.bpp = 0;
                 (uint16_t)-1)
-        if (edid1_EstablishedTim(&edid, EST_640x480_75Hz) ||
-            edid1_EstablishedTim(&edid, EST_640x480_72Hz) ||
-            edid1_EstablishedTim(&edid, EST_640x480_67Hz) ||
-            edid1_EstablishedTim(&edid, EST_640x480_60Hz))
+        if (edid1_established_tim(&edid, EST_640x480_75Hz) ||
+            edid1_established_tim(&edid, EST_640x480_72Hz) ||
+            edid1_established_tim(&edid, EST_640x480_67Hz) ||
+            edid1_established_tim(&edid, EST_640x480_60Hz))
             EDIDmode.resX = 640;
             EDIDmode.resY = 480;
             EDIDmode.bpp = 0;
                 (uint16_t)-1)
     else
@@ -504,9 +507,9 @@ void vesa_realmode_bootup_init(void)
     uint32_t vbe_ret_val;
     uint16_t size;
-    struct VBE_VbeInfoBlock *vib = (struct VBE_VbeInfoBlock *)
+    VBE_vbe_info_block *vib = (VBE_vbe_info_block *)
-    vbe_ret_val = VBEControllerInformation(vib, 0x300);
+    vbe_ret_val = VBE_controller_information(vib, 0x300);
     if (vbe_ret_val == -1)
         printk(FB_VESA_NAME " error calling real mode interrupt.\n");
@@ -525,7 +528,7 @@ void vesa_realmode_bootup_init(void)
     structure and if found we set such mode using corresponding
     VESA function. */
 #define MAX_NO_OF_SORTED_MODES 100
-    modeParams sortModeParams[MAX_NO_OF_SORTED_MODES];
+    Mode_params sorted_mode_params[MAX_NO_OF_SORTED_MODES];
     uint16_t *vmpSegOff = (uint16_t *)&vib->VideoModePtr;
     uint16_t *modeNOPtr = (uint16_t*)
@@ -543,17 +546,17 @@ void vesa_realmode_bootup_init(void)
         { /* some bios implementations ends the list incorrectly with 0 */
             if (iterator < MAX_NO_OF_SORTED_MODES)
-                sortModeParams[iterator].modeNumber = *(modeNOPtr+iterator);
+                sorted_mode_params[iterator].mode_number =*(modeNOPtr+iterator);
                 iterator ++;
             else
                 break;
-            sortModeParams[iterator].modeNumber = 0;
+            sorted_mode_params[iterator].mode_number = 0;
-    struct VBE_ModeInfoBlock *mib = (struct VBE_ModeInfoBlock *)
+    VBE_mode_info_block *mib = (VBE_mode_info_block *)
     iterator = 0;
     uint8_t nextFilteredMode = 0;
@@ -562,45 +565,49 @@ void vesa_realmode_bootup_init(void)
     /* get parameters of modes and filter modes according to set
         required parameters */
     while (iterator < MAX_NO_OF_SORTED_MODES &&
-        sortModeParams[iterator].modeNumber!=0)
+        sorted_mode_params[iterator].mode_number!=0)
-        VBEModeInformation(mib, sortModeParams[iterator].modeNumber);
+        VBE_mode_information(mib, sorted_mode_params[iterator].mode_number);
         if ((mib->ModeAttributes&required_mode_attributes) ==
-            sortModeParams[nextFilteredMode].modeNumber =
-                sortModeParams[iterator].modeNumber;
-            sortModeParams[nextFilteredMode].resX = mib->XResolution;
-            sortModeParams[nextFilteredMode].resY = mib->YResolution;
-            sortModeParams[nextFilteredMode].bpp  = mib->BitsPerPixel;
+            sorted_mode_params[nextFilteredMode].mode_number =
+                sorted_mode_params[iterator].mode_number;
+            sorted_mode_params[nextFilteredMode].resX = mib->XResolution;
+            sorted_mode_params[nextFilteredMode].resY = mib->YResolution;
+            sorted_mode_params[nextFilteredMode].bpp  = mib->BitsPerPixel;
             nextFilteredMode ++;
         iterator ++;
-    sortModeParams[nextFilteredMode].modeNumber = 0;
+    sorted_mode_params[nextFilteredMode].mode_number = 0;
-    uint8_t numberOfModes = nextFilteredMode;
+    uint8_t number_of_modes = nextFilteredMode;
     /* sort filtered modes */
-    modeParams modeXchgPlace;
+    Mode_params modeXchgPlace;
     iterator = 0;
     uint8_t j;
     uint8_t idxBestMode;
-    while (iterator < numberOfModes)
+    while (iterator < number_of_modes)
         idxBestMode = iterator;
         j = iterator+1;
-        while (j < numberOfModes)
+        while (j < number_of_modes)
-            if (sortModeParams[j].resX > sortModeParams[idxBestMode].resX)
+            if (sorted_mode_params[j].resX >
+                    sorted_mode_params[idxBestMode].resX)
                 idxBestMode = j;
-            else if (sortModeParams[j].resX == sortModeParams[idxBestMode].resX)
+            else if (sorted_mode_params[j].resX ==
-                if (sortModeParams[j].resY > sortModeParams[idxBestMode].resY)
+                if (sorted_mode_params[j].resY >
+                        sorted_mode_params[idxBestMode].resY)
                     idxBestMode = j;
-                else if (sortModeParams[j].resY ==
-                    sortModeParams[idxBestMode].resY)
+                else if (sorted_mode_params[j].resY ==
-                    if (sortModeParams[j].bpp > sortModeParams[idxBestMode].bpp)
+                    if (sorted_mode_params[j].bpp >
+                            sorted_mode_params[idxBestMode].bpp)
                         idxBestMode = j;
@@ -608,32 +615,34 @@ void vesa_realmode_bootup_init(void)
         if (idxBestMode != iterator)
-            modeXchgPlace = sortModeParams[iterator];
-            sortModeParams[iterator] = sortModeParams[idxBestMode];
-            sortModeParams[idxBestMode] = modeXchgPlace;
+            modeXchgPlace = sorted_mode_params[iterator];
+            sorted_mode_params[iterator] = sorted_mode_params[idxBestMode];
+            sorted_mode_params[idxBestMode] = modeXchgPlace;
         iterator++;
     /* first search for video argument in multiboot options */
-    vbe_usedMode = findModeUsingCmdline(sortModeParams, numberOfModes);
-    if (vbe_usedMode == (uint16_t)-1)
+    vbe_used_mode = find_mode_using_cmdline(sorted_mode_params,
+                                            number_of_modes);
+    if (vbe_used_mode == (uint16_t)-1)
         printk(FB_VESA_NAME " video on command line not provided"
             "\n\ttrying EDID ...\n");
         /* second search monitor for good resolution */
-        vbe_usedMode = findModeUsingEDID(sortModeParams, numberOfModes);
+        vbe_used_mode = find_mode_using_EDID(sorted_mode_params,
+                                             number_of_modes);
             printk(FB_VESA_NAME" monitor's EDID video parameters not supported"
                                "\n\tusing mode with highest resolution, bpp\n");
             /* third set highest values */
-            vbe_usedMode = sortModeParams[0].modeNumber;
+            vbe_used_mode = sorted_mode_params[0].mode_number;
     /* fill framebuffer structs with info about selected mode */
-    vbe_ret_val = VBEModeInformation(mib, vbe_usedMode);
+    vbe_ret_val = VBE_mode_information(mib, vbe_used_mode);
     if ((vbe_ret_val&0xff)!=VBE_functionSupported ||
         (vbe_ret_val>>8)!=VBE_callSuccessful)
@@ -667,8 +676,8 @@ void vesa_realmode_bootup_init(void)
         fb_fix.visual  = FB_VISUAL_TRUECOLOR;
     /* set selected mode */
-    vbe_ret_val = VBESetMode(vbe_usedMode | VBE_linearFlatFrameBufMask,
-        (struct VBE_CRTCInfoBlock *)(i386_get_default_rm_buffer(&size)));
+    vbe_ret_val = VBE_set_mode(vbe_used_mode | VBE_linearFlatFrameBufMask,
+        (VBE_CRTC_info_block *)(i386_get_default_rm_buffer(&size)));
     if (vbe_ret_val>>8 == VBE_callFailed)
         printk(FB_VESA_NAME " VBE: Requested mode is not available.");
@@ -799,14 +808,12 @@ frame_buffer_write(
 static int get_fix_screen_info( struct fb_fix_screeninfo *info )
-    printk("get_fix_screen_info\n");
   *info = fb_fix;
   return 0;
 static int get_var_screen_info( struct fb_var_screeninfo *info )
-    printk("get_var_screen_info\n");
   *info =  fb_var;
   return 0;
diff --git a/c/src/lib/libbsp/i386/pc386/include/edid.h b/c/src/lib/libbsp/i386/pc386/include/edid.h
index db3ec25..fe6d7da 100644
--- a/c/src/lib/libbsp/i386/pc386/include/edid.h
+++ b/c/src/lib/libbsp/i386/pc386/include/edid.h
@@ -34,7 +34,6 @@ extern "C" {
 #endif /* __cplusplus */
-#define EDID_PACKED_ATTRIBUTE   RTEMS_COMPILER_PACKED_ATTRIBUTE
 #define EDID_INLINE_ROUTINE     RTEMS_INLINE_ROUTINE
 /*  VESA Enhanced Extended Display Identification Data (E-EDID) Proposed
@@ -70,7 +69,7 @@ extern "C" {
 #define EDID1_DTD_HorizontalSyncIsPositiveOff   1
 #define EDID1_DTD_HorizontalSyncIsPositiveMask  0x1
-struct DetailedTimingDescriptor {
+typedef struct {
     uint8_t PixelClock_div10000[2];
     uint8_t HorizontalActiveLow;
     uint8_t HorizontalBlankingLow;
@@ -88,85 +87,85 @@ struct DetailedTimingDescriptor {
     uint8_t HorizontalBorder;
     uint8_t VerticalBorder;
     uint8_t Flags;
-} EDID_PACKED_ATTRIBUTE;
+} RTEMS_COMPILER_PACKED_ATTRIBUTE EDID_detailed_timing_descriptor;
-EDID_INLINE_ROUTINE uint16_t DTD_HorizontalActive (
-    struct DetailedTimingDescriptor *dtd)
+EDID_INLINE_ROUTINE uint16_t DTD_horizontal_active (
+    EDID_detailed_timing_descriptor *dtd)
     return (dtd->HorizontalActiveLow |
         (dtd->HorizontalBlanking_ActiveHigh & 0xF0) << 4);
-EDID_INLINE_ROUTINE uint16_t DTD_HorizontalBlanking (
+EDID_INLINE_ROUTINE uint16_t DTD_horizontal_blanking (
     return (dtd->HorizontalBlankingLow |
         (dtd->HorizontalBlanking_ActiveHigh & 0xF) << 8);
-EDID_INLINE_ROUTINE uint16_t DTD_VerticalActive (
+EDID_INLINE_ROUTINE uint16_t DTD_vertical_active (
     return (dtd->VerticalActiveLow |
         (dtd->VerticalBlanking_ActiveHigh & 0xF0) << 4);
-EDID_INLINE_ROUTINE uint16_t DTD_VerticalBlanking (
+EDID_INLINE_ROUTINE uint16_t DTD_vertical_blanking (
     return (dtd->VerticalBlankingLow |
         (dtd->VerticalBlanking_ActiveHigh & 0xF) << 8);
-EDID_INLINE_ROUTINE uint16_t DTD_VerticalSyncPulseWidth (
+EDID_INLINE_ROUTINE uint16_t DTD_vertical_sync_pulse_width (
     return ((dtd->VerticalSyncPulseWidth_OffsetLow & 0xF) |
         (dtd->Vert_Hor_SyncPulseWidth_Offset_High & 0x3) << 4);
-EDID_INLINE_ROUTINE uint16_t DTD_VerticalSyncOffset (
+EDID_INLINE_ROUTINE uint16_t DTD_vertical_sync_offset (
     return ((dtd->VerticalSyncPulseWidth_OffsetLow >> 4) |
         (dtd->Vert_Hor_SyncPulseWidth_Offset_High & 0xC) << 2);
-EDID_INLINE_ROUTINE uint16_t DTD_HorizontalSyncPulseWidth (
+EDID_INLINE_ROUTINE uint16_t DTD_horizontal_sync_pulse_width (
     return (dtd->HorizontalSyncPulseWidthLow |
         (dtd->Vert_Hor_SyncPulseWidth_Offset_High & 0x30) << 4);
-EDID_INLINE_ROUTINE uint16_t DTD_HorizontalSyncOffset (
+EDID_INLINE_ROUTINE uint16_t DTD_horizontal_sync_offset (
     return (dtd->HorizontalSyncOffsetLow |
         (dtd->Vert_Hor_SyncPulseWidth_Offset_High & 0xC0) << 2);
-EDID_INLINE_ROUTINE uint16_t DTD_VerticalImageSize (
+EDID_INLINE_ROUTINE uint16_t DTD_vertical_image_size (
     return (dtd->VerticalImageSizeLow |
         (dtd->Vertical_HorizontalImageSizeHigh & 0xF) << 8);
-EDID_INLINE_ROUTINE uint16_t DTD_HorizontalImageSize (
+EDID_INLINE_ROUTINE uint16_t DTD_horizontal_image_size (
     return (dtd->HorizontalImageSizeLow |
         (dtd->Vertical_HorizontalImageSizeHigh & 0xF0) << 4);
-struct ColorPointData {
+typedef struct {
     uint8_t ColorPointWhitePointIndexNumber;
     uint8_t ColorPointWhiteLowBits;
     uint8_t ColorPointWhite_x;
     uint8_t ColorPointWhite_y;
     uint8_t ColorPointWhiteGamma;
+} RTEMS_COMPILER_PACKED_ATTRIBUTE EDID_color_point_data;
 /* Basic Display Parameters */
 /* Monitor Descriptor - Data Type Tag */
@@ -175,7 +174,7 @@ struct ColorPointData {
 #define EDID_DTT_ASCIIString                0xFE
 #define EDID_DTT_MonitorRangeLimits         0xFD
-struct MonitorRangeLimits {
+typedef struct {
     uint8_t MinVerticalRateInHz;
     uint8_t MaxVerticalRateInHz;
     uint8_t MinHorizontalInKHz;
@@ -184,7 +183,7 @@ struct MonitorRangeLimits {
 /* see  VESA, Generalized Timing Formula Standard - GTF
         Version 1.0, December 18, 1996 */
     uint8_t GTFStandard[8];
+} RTEMS_COMPILER_PACKED_ATTRIBUTE EDID_monitor_range_limits;
 #define EDID_DTT_MonitorName                0xFC
@@ -222,18 +221,18 @@ struct MonitorRangeLimits {
 #define EDID_CVT_PrefVertRate60Hz           1
 #define EDID_CVT_PrefVertRate75Hz           2
 #define EDID_CVT_PrefVertRate85Hz           3
-struct CVT3ByteCodeDescriptor {
+typedef struct {
     uint8_t AddressableLinesLow;
     uint8_t AspectRatio_AddressableLinesHigh;
     uint8_t VerticalRate_PreferredVerticalRate;
-struct CVTTimingCodes3B {
+} RTEMS_COMPILER_PACKED_ATTRIBUTE EDID_CVT_3_byte_code_descriptor;
+typedef struct {
     uint8_t VersionNumber;
-    struct CVT3ByteCodeDescriptor cvt[4];
+    EDID_CVT_3_byte_code_descriptor cvt[4];
+} RTEMS_COMPILER_PACKED_ATTRIBUTE EDID_CVT_timing_codes_3B;
-EDID_INLINE_ROUTINE uint16_t edid1_CVT_AddressableLinesHigh (
-    struct CVT3ByteCodeDescriptor *cvt)
+EDID_INLINE_ROUTINE uint16_t edid1_CVT_addressable_lines_high (
+    EDID_CVT_3_byte_code_descriptor *cvt)
     return (cvt->AddressableLinesLow |
         (cvt->VerticalRate_PreferredVerticalRate &
@@ -241,18 +240,18 @@ EDID_INLINE_ROUTINE uint16_t edid1_CVT_AddressableLinesHigh (
         ) << (8-EDID1_CVT_AddressableLinesHighOff) );
-EDID_INLINE_ROUTINE uint8_t edid1_CVT_AspectRatio (
+EDID_INLINE_ROUTINE uint8_t edid1_CVT_aspect_ratio (
     return (cvt->AspectRatio_AddressableLinesHigh >> EDID1_CVT_AspectRatioOff) &
         EDID1_CVT_AspectRatioMask;
 #define EDID_DTT_EstablishedTimingsIII      0xF7
-struct EstablishedTimingsIII {
+typedef struct {
     uint8_t RevisionNumber;
     uint8_t EST_III[12];
+} RTEMS_COMPILER_PACKED_ATTRIBUTE EDID_established_timings_III;
 enum EST_III {
     EST_1152x864_75Hz   = 0,
     EST_1024x768_85Hz   = 1,
@@ -308,18 +307,18 @@ enum EST_III {
 #define EDID_DTT_DescriptorSpaceUnused      0x10
 /* DTT 0x0 - 0xF are manufacturer specific */
-struct MonitorDescriptor {
+typedef struct {
     uint8_t Flag0[2];
     uint8_t Flag1;
     uint8_t DataTypeTag;
     uint8_t Flag2;
     uint8_t DescriptorData[13];
+} RTEMS_COMPILER_PACKED_ATTRIBUTE EDID_monitor_descriptor;
-union DTD_MD {
-    struct DetailedTimingDescriptor dtd;
-    struct MonitorDescriptor md;
+union EDID_DTD_MD {
+    EDID_detailed_timing_descriptor dtd;
+    EDID_monitor_descriptor md;
+} RTEMS_COMPILER_PACKED_ATTRIBUTE;
 #define EDID1_STI_ImageAspectRatioOff           0
 #define EDID1_STI_ImageAspectRatioMask          0x3
@@ -331,10 +330,10 @@ union DTD_MD {
 #define EDID_STI_AspectRatio_4_3            1
 #define EDID_STI_AspectRatio_5_4            2
 #define EDID_STI_AspectRatio_16_9           3
-struct StandardTimingIdentification {
+typedef struct {
     uint8_t HorizontalActivePixels;
     uint8_t ImageAspectRatio_RefreshRate;
+} RTEMS_COMPILER_PACKED_ATTRIBUTE EDID_standard_timing_identification;
 /* Video Input Definition */
 /* Analog = 0, Digital = 1 */
@@ -409,7 +408,7 @@ struct StandardTimingIdentification {
 #define EDID_DisplayType_RGB444YCrCb422             2
 #define EDID_DisplayType_RGB444YCrCb444YCrCb422     3
-struct edid1 {
+typedef struct {
     uint8_t Header[8];
 /*  Vendor Product Identification */
     uint8_t IDManufacturerName[2];
@@ -442,39 +441,39 @@ struct edid1 {
 /*  Established Timings I, II, Manufacturer's */
     uint8_t EST_I_II_Man[3];
 /*  Standard Timing Identification */
-    struct StandardTimingIdentification STI[8];
+    EDID_standard_timing_identification STI[8];
 /*  Detailed Timing Descriptions / Monitor Descriptions */
-    union DTD_MD dtd_md[4];
+    union EDID_DTD_MD dtd_md[4];
     uint8_t ExtensionFlag;
     uint8_t Checksum;
+} RTEMS_COMPILER_PACKED_ATTRIBUTE EDID_edid1;
-EDID_INLINE_ROUTINE uint16_t edid1_RedX (struct edid1 *edid) {
+EDID_INLINE_ROUTINE uint16_t edid1_RedX (EDID_edid1 *edid) {
     return (edid->RedXHigh<<2) | (edid->GreenRedLow>>6);
-EDID_INLINE_ROUTINE uint16_t edid1_RedY (struct edid1 *edid) {
+EDID_INLINE_ROUTINE uint16_t edid1_RedY (EDID_edid1 *edid) {
     return (edid->RedYHigh<<2) | (edid->GreenRedLow>>4)&&0x3;
-EDID_INLINE_ROUTINE uint16_t edid1_GreenX (struct edid1 *edid) {
+EDID_INLINE_ROUTINE uint16_t edid1_GreenX (EDID_edid1 *edid) {
     return (edid->GreenXHigh<<2) | (edid->GreenRedLow>>2)&&0x3;
-EDID_INLINE_ROUTINE uint16_t edid1_GreenY (struct edid1 *edid) {
+EDID_INLINE_ROUTINE uint16_t edid1_GreenY (EDID_edid1 *edid) {
     return (edid->GreenYHigh<<2) | (edid->GreenRedLow&0x3);
-EDID_INLINE_ROUTINE uint16_t edid1_BlueX (struct edid1 *edid) {
+EDID_INLINE_ROUTINE uint16_t edid1_BlueX (EDID_edid1 *edid) {
     return (edid->BlueXHigh<<2)  | (edid->WhiteBlueLow>>6);
-EDID_INLINE_ROUTINE uint16_t edid1_BlueY (struct edid1 *edid) {
+EDID_INLINE_ROUTINE uint16_t edid1_BlueY (EDID_edid1 *edid) {
     return (edid->BlueYHigh<<2)  | (edid->WhiteBlueLow>>4)&&0x3;
-EDID_INLINE_ROUTINE uint16_t edid1_WhiteX (struct edid1 *edid) {
+EDID_INLINE_ROUTINE uint16_t edid1_WhiteX (EDID_edid1 *edid) {
     return (edid->WhiteXHigh<<2) | (edid->WhiteBlueLow>>2)&&0x3;
-EDID_INLINE_ROUTINE uint16_t edid1_WhiteY (struct edid1 *edid) {
+EDID_INLINE_ROUTINE uint16_t edid1_WhiteY (EDID_edid1 *edid) {
     return (edid->WhiteYHigh<<2) | (edid->WhiteBlueLow&0x3);
-enum edid1_EstablishedTimings {
+enum edid1_established_timings {
 /*  Established Timings I */
     EST_800x600_60Hz    = 0,
     EST_800x600_56Hz    = 1,
@@ -497,9 +496,9 @@ enum edid1_EstablishedTimings {
     EST_1152x870_75Hz   = 23,
-EDID_INLINE_ROUTINE uint8_t edid1_EstablishedTim (
-    struct edid1 *edid,
-    enum edid1_EstablishedTimings est)
+EDID_INLINE_ROUTINE uint8_t edid1_established_tim (
+    EDID_edid1 *edid,
+    enum edid1_established_timings est)
     return (uint8_t)(edid->EST_I_II_Man[est/8] & (est%8));
diff --git a/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h b/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
index 5638b50..b82d3e7 100644
--- a/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
+++ b/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
@@ -45,9 +45,9 @@ extern "C" {
  * @retval  register ax content as defined in VBE RETURN STATUS paragraph
  *          -1 error calling graphical bios
-uint32_t VBEControllerInformation (
-    struct VBE_VbeInfoBlock *infoBlock,
+uint32_t VBE_controller_information (
+    VBE_vbe_info_block *info_block,
@@ -59,9 +59,9 @@ uint32_t VBEControllerInformation (
-uint32_t VBEModeInformation (
-    struct VBE_ModeInfoBlock *infoBlock,
+uint32_t VBE_mode_information (
+    VBE_mode_info_block *info_block,
@@ -73,9 +73,9 @@ uint32_t VBEModeInformation (
-uint32_t VBESetMode (
-    uint16_t modeNumber,
+uint32_t VBE_set_mode (
+    uint16_t mode_number,
@@ -85,8 +85,8 @@ uint32_t VBESetMode (
-uint32_t VBECurrentMode (
-    uint16_t *modeNumber
+uint32_t VBE_current_mode (
+    uint16_t *mode_number
@@ -101,10 +101,10 @@ uint32_t VBECurrentMode (
-uint32_t VBEReportDDCCapabilities (
-    uint16_t controllerUnitNumber,
+uint32_t VBE_report_DDC_capabilities (
+    uint16_t controller_unit_number,
@@ -116,10 +116,10 @@ uint32_t VBEReportDDCCapabilities (
-uint32_t VBEReadEDID (
+uint32_t VBE_read_EDID (
 #ifdef __cplusplus
diff --git a/c/src/lib/libbsp/i386/pc386/include/tblsizes.h b/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
index ef51ae7..6128d87 100644
--- a/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
+++ b/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
@@ -22,4 +22,3 @@
 #define IDT_SIZE (256)
 #define GDT_SIZE (3 + NUM_APP_DRV_GDT_DESCRIPTORS)
diff --git a/c/src/lib/libbsp/i386/pc386/include/vbe3.h b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
index 2bf1b59..811fc3d 100644
--- a/c/src/lib/libbsp/i386/pc386/include/vbe3.h
+++ b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
@@ -33,7 +33,6 @@ extern "C" {
-#define VBE3_PACKED_ATTRIBUTE   RTEMS_COMPILER_PACKED_ATTRIBUTE
 /*  VESA BIOS EXTENSION (VBE) Core functions Standard
     Version: 3.0 Date: September 16, 1998               */
@@ -156,12 +155,12 @@ extern "C" {
 #define VBE_RetVBESupSpeInf    0x00  /* Return VBE Supplemental
                                         Specification Information */
 /* *** Structures *** */
-struct VBE_FarPtr {
+typedef struct {
     uint16_t offset;
     uint16_t selector;
-} VBE3_PACKED_ATTRIBUTE;
+} RTEMS_COMPILER_PACKED_ATTRIBUTE VBE_far_pointer;
-struct VBE_PMInfoBlock {
+typedef struct {
     uint8_t   Signature[4];    /*  PM Info Block Signature */
     uint16_t  EntryPoint;      /*  Offset of PM entry point within BIOS */
     uint16_t  PMInitialize;    /*  Offset of PM initialization entry point */
@@ -172,7 +171,7 @@ struct VBE_PMInfoBlock {
     uint16_t  CodeSegSel;      /*  Selector to access code segment as data */
     uint8_t   InProtectMode;   /*  Set to 1 when in protected mode */
     uint8_t   Checksum;        /*  Checksum byte for structure */
+} RTEMS_COMPILER_PACKED_ATTRIBUTE VBE_protected_mode_info_block;
 /* General VBE signature */
 #define VBE_SIGNATURE "VESA"
@@ -181,7 +180,7 @@ struct VBE_PMInfoBlock {
 /* for STUB see VBE CORE FUNCTIONS VERSION 3.0 - Appendix 1 */
 #define VBE_END_OF_VideoModeList 0xFFFF
 #define VBE_STUB_VideoModeList 0xFFFF
-struct VBE_VbeInfoBlock {
+typedef struct {
     uint8_t   VbeSignature[4];   /*  VBE Signature */
     uint16_t  VbeVersion;        /*  VBE Version */
     uint8_t  *OemStringPtr;      /*  VbeFarPtr to OEM String */
@@ -196,9 +195,9 @@ struct VBE_VbeInfoBlock {
     uint8_t   Reserved[222];     /*  Reserved for VBE implementation scratch */
     /*    area */
     uint8_t   OemData[256];      /*  Data Area for OEM Strings */
+} RTEMS_COMPILER_PACKED_ATTRIBUTE VBE_vbe_info_block;
-struct VBE_ModeInfoBlock {
+typedef struct {
     /*  Mandatory information for all VBE revisions */
     uint16_t  ModeAttributes;        /* mode attributes */
     uint8_t   WinAAttributes;        /* window A attributes */
@@ -252,9 +251,9 @@ struct VBE_ModeInfoBlock {
     uint32_t  MaxPixelClock;         /* maximum pixel clock
                                         (in Hz) for graphics mode */
     uint8_t   Reserved3[189];        /* remainder of ModeInfoBlock */
+} RTEMS_COMPILER_PACKED_ATTRIBUTE VBE_mode_info_block;
-struct VBE_CRTCInfoBlock {
+typedef struct {
     uint16_t  HorizontalTotal;       /* Horizontal total in pixels */
     uint16_t  HorizontalSyncStart;   /* Horizontal sync start in pixels */
     uint16_t  HorizontalSyncEnd;     /* Horizontal sync end in pixels */
@@ -265,16 +264,16 @@ struct VBE_CRTCInfoBlock {
     uint32_t  PixelClock;            /* Pixel clock in units of Hz */
     uint16_t  RefreshRate;           /* Refresh rate in units of 0.01 Hz */
     uint8_t   Reserved[40];          /* remainder of ModeInfoBlock */
+} RTEMS_COMPILER_PACKED_ATTRIBUTE VBE_CRTC_info_block;
-struct VBE_PaletteEntry {
+typedef struct {
     uint8_t   Blue;                  /* Blue channel value (6 or 8 bits) */
     uint8_t   Green;                 /* Green channel value (6 or 8 bits) */
     uint8_t   Red;                   /* Red channel value(6 or 8 bits) */
     uint8_t   Alignment;             /* DWORD alignment byte (unused) */
+} RTEMS_COMPILER_PACKED_ATTRIBUTE VBE_palette_entry;
-struct VBE_SupVbeInfoBlock {
+typedef struct {
     uint8_t   SupVbeSignature[7];    /* Supplemental VBE Signature */
     uint16_t  SupVbeVersion;         /* Supplemental VBE Version */
     uint8_t   SupVbeSubFunc[8];      /* Bitfield of supported subfunctions */
@@ -286,7 +285,7 @@ struct VBE_SupVbeInfoBlock {
     uint8_t   Reserved[221];         /* Reserved for description
                                         strings and future */
     /*  expansion */
+} RTEMS_COMPILER_PACKED_ATTRIBUTE VBE_supplemental_vbe_info_block;
 /* VbeInfoBlock Capabilities */
 /*  D0 = 0  DAC is fixed width, with 6 bits per primary color */
@@ -460,4 +459,3 @@ struct VBE_SupVbeInfoBlock {
 #endif /* ASM */
 #endif /* _VBE_H */
diff --git a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
index 0aa71e6..af5cf1e 100644
--- a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
+++ b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
@@ -181,7 +181,7 @@ void *i386_get_default_rm_buffer(uint16_t *size) {
     return default_rm_buffer_spot;
-int i386_real_interrupt_call(uint8_t interruptNumber,
+int i386_real_interrupt_call(uint8_t interrupt_number,
                              i386_realmode_interrupt_registers *ir)
     uint32_t pagingon;
@@ -270,7 +270,7 @@ int i386_real_interrupt_call(uint8_t interruptNumber,
         : "=rm"(interrupt_number_off)
     interrupt_number_ptr = (uint8_t *)(rm_swtch_code_dst+interrupt_number_off);
-    *interrupt_number_ptr = interruptNumber;
+    *interrupt_number_ptr = interrupt_number;
     /* execute code that jumps to coppied function, which switches to real mode,
        loads registers with values passed to interrupt and executes interrupt */
     __asm__ volatile(   "\t"
@@ -403,4 +403,3 @@ int i386_real_interrupt_call(uint8_t interruptNumber,
     *ir = int_passed_regs_spot->inoutregs;
     return 1;
diff --git a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
index e5f80d0..a0216ea 100644
--- a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
+++ b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
@@ -74,7 +74,10 @@ extern void *i386_get_default_rm_buffer(uint16_t *size);
  * @retval  0 call failed (GDT too small or pagin is on)
  *          1 call successful
-extern int i386_real_interrupt_call(uint8_t interruptNumber, i386_realmode_interrupt_registers *ir);
+extern int i386_real_interrupt_call(
+    uint8_t interrupt_number,
+    i386_realmode_interrupt_registers *ir
 #ifdef __cplusplus
1.9.1
