[PATCH 2/3] i386: doxygen and comments related to VESA real mode framebuffer
Jan Dolezal dolezj21 at fel.cvut.cz
Wed Dec 3 23:56:39 UTC 2014
 c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c   | 105 ++--
 c/src/lib/libbsp/i386/pc386/include/edid.h         |  14 +-
 c/src/lib/libbsp/i386/pc386/include/fb_vesa.h      |  77 +--
 c/src/lib/libbsp/i386/pc386/include/tblsizes.h     |   1 -
 c/src/lib/libbsp/i386/pc386/include/vbe3.h         | 694 +++++++++++++--------
 .../libbsp/i386/shared/realmode_int/realmode_int.c |  69 +-
 .../libbsp/i386/shared/realmode_int/realmode_int.h |  33 +-
 c/src/lib/libcpu/i386/cpu.h                        |  65 +-
 cpukit/score/cpu/i386/cpu_asm.S                    |   4 +-
 cpukit/score/cpu/i386/rtems/score/i386.h           |  39 +-
 10 files changed, 685 insertions(+), 416 deletions(-)
diff --git a/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c b/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
index e5acbd5..d6fd174 100644
--- a/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
+++ b/c/src/lib/libbsp/i386/pc386/console/fb_vesa_rm.c
@@ -1,35 +1,39 @@
- *  FB driver for graphic hardware compatible with VESA Bios Extension
- *  Real mode interface utilized
- *  Tested on real HW.
+ * @file fb_vesa_rm.c
+ * @ingroup i386_pc386
+ * @brief FB driver for graphic hardware compatible with VESA Bios Extension
+ *     Real mode interface utilized
+ *     Tested on real HW.
- *  Copyright (c) 2014 - CTU in Prague
- *                       Jan Doležal ( dolezj21 at fel.cvut.cz )
+ * Public sources related:
+ *   - VESA BIOS EXTENSION (VBE) Core Function Standard, Ver: 3.0, Sep 16, 1998
+ *   - VESA Enhanced Extended Display Identification Data (E-EDID) Standard
+ *     Release A, Revision 2, September 25, 2006
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * Hardware is completely initialized upon boot of the system.
+ * Therefore there is no way to change graphics mode later.
- *  The code for rtems_buffer_* functions were greatly
- *  inspired or coppied from:
- *    - RTEMS fb_cirrus.c - Alexandru-Sever Horin (alex.sever.h at gmail.com)
+ * Interrupt 0x10 is used for entering graphics BIOS.
- *  Public sources related:
- *    - VESA BIOS EXTENSION (VBE) Core Function Standard, Ver: 3.0, Sep 16, 1998
- *    - VESA Enhanced Extended Display Identification Data (E-EDID) Standard
- *      Release A, Revision 2, September 25, 2006
+ * Driver reads parameter from multiboot command line to setup video:
+ * "--video=<resX>x<resY>[-<bpp>]"
+ * If cmdline parameter is not specified an attempt for obtaining
+ * resolution from display attached is made.
- *  Hardware is completely initialized upon boot of the system.
- *  Therefore there is no way to change graphics mode later.
+ * Copyright (c) 2014 - CTU in Prague
+ *                      Jan Doležal ( dolezj21 at fel.cvut.cz )
- *  Interrupt 0x10 is used for entering graphics BIOS.
- *  Driver reads parameter from multiboot command line to setup video:
- *  "--video=<resX>x<resY>[-<bpp>]"
- *  If cmdline parameter is not specified an attempt for obtaining
- *  resolution from display attached is made.
+ * The code for rtems_buffer_* functions were greatly
+ * inspired or coppied from:
+ *   - RTEMS fb_cirrus.c - Alexandru-Sever Horin (alex.sever.h at gmail.com)
 #include <bsp.h>
@@ -48,6 +52,13 @@
 #define FB_VESA_NAME    "FB_VESA_RM"
+ * @brief Initializes VBE framebuffer during bootup.
+ * utilizes switches to real mode interrupts and therefore must be
+ * called during bootup before tick is set up and real-time
+ * interrupt vectors utilized
 void vesa_realmode_bootup_init(void);
 /* mutex for protection against multiple opens, when called frame_buffer_open */
@@ -187,19 +198,37 @@ uint32_t VBE_read_EDID(uint16_t controller_unit_number,
     return (parret.reg_eax & 0xFFFF);
+ * @brief Basic graphic's mode parameters
 typedef struct {
+    /** number of the graphic's mode */
     uint16_t mode_number;
+    /** number of pixels in one line */
     uint16_t resX;
+    /** number of lines */
     uint16_t resY;
+    /** bits per pixel */
     uint8_t bpp;
 } Mode_params;
-/* finds mode in 'modeList' of 'listLength' length according to resolution
-    given in 'searchedResolution'. If bpp is given in that struct as well
-    mode with such color depth and resolution is searched for. Otherwise bpp
-    has to be zero. Mode number found is returned and also filled into
-    'searchedResolution'. bpp is also filled into 'searchedResolution' if it
-    was 0 before call. */
+ * @brief Find mode by resolution in the given list of modes
+ * finds mode in \p mode_list of \p list_length length according to resolution
+ * given in \p searched_resolution . If bpp is given in that struct as well
+ * mode with such color depth and resolution is searched for. Otherwise bpp
+ * has to be zero. Mode number found is returned and also filled into
+ * \p searched_resolution . bpp is also filled into \p searchedResolution if it
+ * was 0 before call.
+ * @param[in] mode_list list of modes to be searched
+ * @param[in] list_length number of modes in the list
+ * @param[in,out] searched_resolution element filled with searched resolution
+ *                or/and bpp; mode_number is filled in if appropriate mode found
+ * @retval mode number satisfying given parameters
+ * @retval -1 no suitable mode found
 static uint16_t find_mode_by_resolution(Mode_params *mode_list,
                                         uint8_t list_length,
                                         Mode_params *searched_resolution)
@@ -223,14 +252,18 @@ static uint16_t find_mode_by_resolution(Mode_params *mode_list,
     return -1;
- * Parse comandline option "--video=" if available.
+ * @brief Find mode given within command line.
+ * Parse command line option "--video=" if available.
  *  expected format
  *  --video=<resX>x<resY>[-<bpp>]
  *  numbers <resX>, <resY> and <bpp> are decadic
  * @retval video mode number to be set
- *         -1 on parsing error or when no suitable mode found
+ * @retval -1 on parsing error or when no suitable mode found
 static uint16_t find_mode_using_cmdline(Mode_params *mode_list,
                                         uint8_t list_length)
@@ -278,11 +311,13 @@ static uint16_t find_mode_using_cmdline(Mode_params *mode_list,
     return -1;
- * returns mode number best fitting to monitor attached
+ * @brief Find mode number best fitting to monitor attached
 static uint16_t find_mode_using_EDID( Mode_params *mode_list,
diff --git a/c/src/lib/libbsp/i386/pc386/include/edid.h b/c/src/lib/libbsp/i386/pc386/include/edid.h
index fe6d7da..1120296 100644
--- a/c/src/lib/libbsp/i386/pc386/include/edid.h
+++ b/c/src/lib/libbsp/i386/pc386/include/edid.h
@@ -4,16 +4,16 @@
  * @brief VESA EDID definitions.
+ * This file contains definitions for constants related to
+ * VESA Extended Display Identification Data.
+ *         More information can be found at
+ *     <http://www.vesa.org/vesa-standards/free-standards/>
+ *         VESA public standards may be found at
+ *     <http://www.vesa.org/wp-content/uploads/2010/12/thankspublic.htm>
- * edid.h  - This file contains definitions for constants related to
- *           VESA Extended Display Identification Data.
- *          More information can be found at
- *      <http://www.vesa.org/vesa-standards/free-standards/>
- *          VESA public standards may be found at
- *      <http://www.vesa.org/wp-content/uploads/2010/12/thankspublic.htm>
  * Copyright (C) 2014  Jan Doležal (dolezj21 at fel.cvut.cz)
  *                     CTU in Prague.
diff --git a/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h b/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
index b82d3e7..d8bfd1b 100644
--- a/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
+++ b/c/src/lib/libbsp/i386/pc386/include/fb_vesa.h
@@ -3,12 +3,10 @@
- * @brief Definitioins for vesa based framebuffer drivers.
+ * @brief Headers specific for framebuffer drivers utilizing VESA VBE.
- * Headers specific for framebuffer drivers utilizing VESA VBE.
  *                     CTU in Prague.
@@ -35,15 +33,16 @@ extern "C" {
 /* ----- Prototypes ----- */
- * Returns information about graphic's controller in the infoBlock structure.
+ * @brief Returns information about graphic's controller in the \p info_block
+ * structure.
- * @param infoBlock pointer to the struct to be filled with
-                    controller information
- * @param queriedVBEVersion if >0x200 then video bios is asked to fill in
+ * @param[out] info_block pointer to the struct to be filled with
+ *                  controller information
+ * @param[in] queried_VBE_Version if >0x200 then video bios is asked to fill in
  *                          parameters which appeared with second version
  *                          of VBE.
- * @retval  register ax content as defined in VBE RETURN STATUS paragraph
- *          -1 error calling graphical bios
+ * @retval  ax register content as defined in VBE RETURN STATUS paragraph
+ * @retval  -1 error calling graphical bios
 uint32_t VBE_controller_information (
     VBE_vbe_info_block *info_block,
@@ -51,13 +50,14 @@ uint32_t VBE_controller_information (
- * Fills structure infoBlock with informations about selected mode in
- * modeNumber variable.
+ * @brief Fills structure \p info_block with informations about selected mode in
+ * \p mode_number variable.
- * @param infoBlock pointer to the struct to be filled with mode information
- * @param modeNumber detailes of this mode to be filled
+ *                        mode information
+ * @param[in] mode_number detailes of this mode to be filled
 uint32_t VBE_mode_information (
     VBE_mode_info_block *info_block,
@@ -65,13 +65,13 @@ uint32_t VBE_mode_information (
- * Sets graphics mode selected. If mode has refreshRateCtrl bit set, than the
- * infoBlock must be filled accordingly.
+ * @brief Sets graphics mode selected. If mode has refreshRateCtrl bit set, than
+ * the \p info_block must be filled accordingly.
- * @param modeNumber number of mode to be set
- * @param infoBlock pointer to struct containing refresh rate control info
+ * @param[in] mode_number number of mode to be set
+ * @param[in] info_block pointer to struct containing refresh rate control info
 uint32_t VBE_set_mode (
     uint16_t mode_number,
@@ -79,27 +79,27 @@ uint32_t VBE_set_mode (
- * Get currently set mode number.
+ * @brief Get currently set mode number.
- * @param modeNumber variable to be filled with current mode number
+ * @param[out] mode_number variable to be filled with current mode number
 uint32_t VBE_current_mode (
     uint16_t *mode_number
- * Gets information about display data channel implemented in the
+ * @brief Gets information about display data channel implemented in the
  * graphic's controller.
- * @param controllerUnitNumber
- * @param secondsToTransferEDIDBlock approximate time to transfer one EDID block
- *                                   rounded up to seconds
- * @param DDCLevelSupported after call contains DDC version supported and
+ * @param[in] controller_unit_number
+ * @param[out] seconds_to_transfer_EDID_block approximate time to transfer one
+ *                                      EDID block rounded up to seconds
+ * @param[out] DDC_level_supported contains DDC version supported and
  *                          screen blanking state during transfer
 uint32_t VBE_report_DDC_capabilities (
@@ -108,13 +108,14 @@ uint32_t VBE_report_DDC_capabilities (
- * Reads selected EDID block from display attached to controller's interface.
+ * @brief Reads selected EDID block from display attached to controller's
+ * interface.
- * @param EDIDBlockNumber block no. to be read from the display
- * @param buffer place to store block fetched from the display
+ * @param[in] EDID_block_number block no. to be read from the display
+ * @param[out] buffer place to store block fetched from the display
 uint32_t VBE_read_EDID (
diff --git a/c/src/lib/libbsp/i386/pc386/include/tblsizes.h b/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
index 6128d87..bd4e989 100644
--- a/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
+++ b/c/src/lib/libbsp/i386/pc386/include/tblsizes.h
@@ -7,7 +7,6 @@
- * Definitions related to the PC386 BSP.
  * This header file is also used in assembler modules.
diff --git a/c/src/lib/libbsp/i386/pc386/include/vbe3.h b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
index 811fc3d..06f614f 100644
--- a/c/src/lib/libbsp/i386/pc386/include/vbe3.h
+++ b/c/src/lib/libbsp/i386/pc386/include/vbe3.h
@@ -4,15 +4,15 @@
  * @brief VESA Bios Extension definitions.
+ * This file contains definitions for constants related to VBE.
+ *     <http://www.vesa.org/vesa-standards/free-standards/>.
+ *     <http://www.vesa.org/wp-content/uploads/2010/12/thankspublic.htm>.
- * vbe3.h  - This file contains definitions for constants related to VBE.
  *                     CTU in Prague.
@@ -37,343 +37,484 @@ extern "C" {
 /*  VESA BIOS EXTENSION (VBE) Core functions Standard
     Version: 3.0 Date: September 16, 1998               */
-/* VBE RETURN STATUS */
-/* AL == 4Fh: Function is supported */
-/* AL != 4Fh: Function is not supported */
+/** AL == 4Fh: Function is supported \n
+ *  AL != 4Fh: Function is not supported */
 #define VBE_functionSupported        0x4F
-/* AH == 00h: Function call successful */
+/** AH == 00h: Function call successful */
 #define VBE_callSuccessful           0x00
-/* AH == 01h: Function call failed */
+/** AH == 01h: Function call failed */
 #define VBE_callFailed               0x01
-/* AH == 02h: Function is not supported in the current hardware configuration */
+/** AH == 02h: Function is not supported in the current hardware configuration*/
 #define VBE_notSupportedInCurHWConf  0x02
-/* AH == 03h: Function call invalid in current video mode */
+/** AH == 03h: Function call invalid in current video mode */
 #define VBE_callInvalid              0x03
 /* VBE Mode Numbers */
-/* D0-D8 =  Mode number */
+/** D0-D8 =  Mode number */
 #define VBE_modeNumberMask         0x01FF
 #define VBE_modeNumberShift          0x00
-/* If D8 == 0, this is not a VESA defined VBE mode */
+/** If D8 == 0, this is not a VESA defined VBE mode \n
+    If D8 == 1, this is a VESA defined VBE mode */
 #define VBE_VESAmodeMask           0x0100
-/* If D8 == 1, this is a VESA defined VBE mode */
-/* D9-D12 =  Reserved by VESA for future expansion (= 0) */
 #define VBE_VESAmodeShift            0x08
-/* If D11 == 0, Use current BIOS default refresh rate */
+/* D9-D10 =  Reserved by VESA for future expansion (= 0) */
+/** If D11 == 0, Use current BIOS default refresh rate \n
+    If D11 == 1, Use user specified CRTC values for refresh rate */
 #define VBE_refreshRateCtrlMask    0x0800
-/* If D11 == 1, Use user specified CRTC values for refresh rate */
-/* D12-13 = Reserved for VBE/AF (must be 0) */
 #define VBE_refreshRateCtrlShift     0x0B
-/* If D14 == 0, Use Banked/Windowed Frame Buffer */
+/* D12-13 = Reserved for VBE/AF (must be 0) */
+/** If D14 == 0, Use Banked/Windowed Frame Buffer \n
+    If D14 == 1, Use Linear/Flat Frame Buffer */
 #define VBE_linearFlatFrameBufMask 0x4000
-/* If D14 == 1, Use Linear/Flat Frame Buffer */
 #define VBE_linearFlatFrameBufShift  0x0E
-/* If D15 == 0, Clear display memory */
+/** If D15 == 0, Clear display memory \n
+    If D15 == 1, Preserve display memory */
 #define VBE_preserveDispMemMask    0x8000
-/* If D15 == 1, Preserve display memory */
 #define VBE_preserveDispMemShift     0x0F
 /* Graphics modes */
-/* 15-bit mode, Resolution: 640x400,   Colors: 256  */
+/** 15-bit mode, Resolution: 640x400,   Colors: 256  */
 #define VBE_R640x400C256      0x100
-/* 15-bit mode, Resolution: 640x480,   Colors: 256  */
+/** 15-bit mode, Resolution: 640x480,   Colors: 256  */
 #define VBE_R640x480C256      0x101
-/* 15-bit mode, Resolution: 800x600,   Colors: 16   */
+/** 15-bit mode, Resolution: 800x600,   Colors: 16   */
 #define VBE_R800x600C16       0x102
-/* 7-bit mode,  Resolution: 800x600,   Colors: 16   */
+/** 7-bit mode,  Resolution: 800x600,   Colors: 16   */
 #define VBE_b7R800x600C16     0x6A
-/* 15-bit mode, Resolution: 800x600,   Colors: 256  */
+/** 15-bit mode, Resolution: 800x600,   Colors: 256  */
 #define VBE_R800x600C256      0x103
-/* 15-bit mode, Resolution: 1024x768,  Colors: 16   */
+/** 15-bit mode, Resolution: 1024x768,  Colors: 16   */
 #define VBE_R1024x768C16      0x104
-/* 15-bit mode, Resolution: 1024x768,  Colors: 256  */
+/** 15-bit mode, Resolution: 1024x768,  Colors: 256  */
 #define VBE_R1024x768C256     0x105
-/* 15-bit mode, Resolution: 1280x1024, Colors: 16   */
+/** 15-bit mode, Resolution: 1280x1024, Colors: 16   */
 #define VBE_R1280x1024C16     0x106
-/* 15-bit mode, Resolution: 1280x1024, Colors: 256  */
+/** 15-bit mode, Resolution: 1280x1024, Colors: 256  */
 #define VBE_R1280x1024C256    0x107
-/* 15-bit mode, Resolution: 320x200,   Colors: 32K   (1:5:5:5) */
+/** 15-bit mode, Resolution: 320x200,   Colors: 32K   (1:5:5:5) */
 #define VBE_R320x200C32K      0x10D
-/* 15-bit mode, Resolution: 320x200,   Colors: 64K   (5:6:5)   */
+/** 15-bit mode, Resolution: 320x200,   Colors: 64K   (5:6:5)   */
 #define VBE_R320x200C64K      0x10E
-/* 15-bit mode, Resolution: 320x200,   Colors: 16.8M (8:8:8)   */
+/** 15-bit mode, Resolution: 320x200,   Colors: 16.8M (8:8:8)   */
 #define VBE_R320x200C17M      0x10F
-/* 15-bit mode, Resolution: 640x480,   Colors: 32K   (1:5:5:5) */
+/** 15-bit mode, Resolution: 640x480,   Colors: 32K   (1:5:5:5) */
 #define VBE_R640x480C32K      0x110
-/* 15-bit mode, Resolution: 640x480,   Colors: 64K   (5:6:5)   */
+/** 15-bit mode, Resolution: 640x480,   Colors: 64K   (5:6:5)   */
 #define VBE_R640x480C64K      0x111
-/* 15-bit mode, Resolution: 640x480,   Colors: 16.8M (8:8:8)   */
+/** 15-bit mode, Resolution: 640x480,   Colors: 16.8M (8:8:8)   */
 #define VBE_R640x480C17M      0x112
-/* 15-bit mode, Resolution: 800x600,   Colors: 32K   (1:5:5:5) */
+/** 15-bit mode, Resolution: 800x600,   Colors: 32K   (1:5:5:5) */
 #define VBE_R800x600C32K      0x113
-/* 15-bit mode, Resolution: 800x600,   Colors: 64K   (5:6:5)   */
+/** 15-bit mode, Resolution: 800x600,   Colors: 64K   (5:6:5)   */
 #define VBE_R800x600C64K      0x114
-/* 15-bit mode, Resolution: 800x600,   Colors: 16.8M (8:8:8)   */
+/** 15-bit mode, Resolution: 800x600,   Colors: 16.8M (8:8:8)   */
 #define VBE_R800x600C17M      0x115
-/* 15-bit mode, Resolution: 1024x768,  Colors: 32K   (1:5:5:5) */
+/** 15-bit mode, Resolution: 1024x768,  Colors: 32K   (1:5:5:5) */
 #define VBE_R1024x768C32K     0x116
-/* 15-bit mode, Resolution: 1024x768,  Colors: 64K   (5:6:5)   */
+/** 15-bit mode, Resolution: 1024x768,  Colors: 64K   (5:6:5)   */
 #define VBE_R1024x768C64K     0x117
-/* 15-bit mode, Resolution: 1024x768,  Colors: 16.8M (8:8:8)   */
+/** 15-bit mode, Resolution: 1024x768,  Colors: 16.8M (8:8:8)   */
 #define VBE_R1024x768C17M     0x118
-/* 15-bit mode, Resolution: 1280x1024, Colors: 32K   (1:5:5:5) */
+/** 15-bit mode, Resolution: 1280x1024, Colors: 32K   (1:5:5:5) */
 #define VBE_R1280x1024C32K    0x119
-/* 15-bit mode, Resolution: 1280x1024, Colors: 64K   (5:6:5)   */
+/** 15-bit mode, Resolution: 1280x1024, Colors: 64K   (5:6:5)   */
 #define VBE_R1280x1024C64K    0x11A
-/* 15-bit mode, Resolution: 1280x1024, Colors: 16.8M (8:8:8)   */
+/** 15-bit mode, Resolution: 1280x1024, Colors: 16.8M (8:8:8)   */
 #define VBE_R1280x1024C17M    0x11B
 #define VBE_SpecialMode       0x81FF
 /* Text modes */
-#define VBE_C80R60            0x108   /* 15-bit mode, Columns: 80,  Rows: 60 */
-#define VBE_C132R25           0x109   /* 15-bit mode, Columns: 132, Rows: 25 */
-#define VBE_C132R43           0x10A   /* 15-bit mode, Columns: 132, Rows: 43 */
-#define VBE_C132R50           0x10B   /* 15-bit mode, Columns: 132, Rows: 50 */
-#define VBE_C132R60           0x10C   /* 15-bit mode, Columns: 132, Rows: 60 */
+#define VBE_C80R60            0x108 /**< 15-bit mode, Columns: 80,  Rows: 60 */
+#define VBE_C132R25           0x109 /**< 15-bit mode, Columns: 132, Rows: 25 */
+#define VBE_C132R43           0x10A /**< 15-bit mode, Columns: 132, Rows: 43 */
+#define VBE_C132R50           0x10B /**< 15-bit mode, Columns: 132, Rows: 50 */
+#define VBE_C132R60           0x10C /**< 15-bit mode, Columns: 132, Rows: 60 */
 /* VBE function numbers - passed in AX register */
-#define VBE_RetVBEConInf       0x4F00 /* Return VBE Controller Information */
-#define VBE_RetVBEModInf       0x4F01 /* Return VBE Mode Information */
-#define VBE_SetVBEMod          0x4F02 /* Set VBE Mode */
-#define VBE_RetCurVBEMod       0x4F03 /* Return Current VBE Mode */
-#define VBE_SavResSta          0x4F04 /* Save/Restore State */
-#define VBE_DisWinCon          0x4F05 /* Display Window Control */
-#define VBE_SetGetLogScaLinLen 0x4F06 /* Set/Get Logical Scan Line Length */
-#define VBE_SetGetDisSta       0x4F07 /* Set/Get Display Start */
-#define VBE_SetGetDACPalFor    0x4F08 /* Set/Get DAC Palette Format */
-#define VBE_SetGetPalDat       0x4F09 /* Set/Get Palette Data */
-#define VBE_RetVBEProModInt    0x4F0A /* Return VBE Protected Mode Interface */
-#define VBE_GetSetpixclo       0x4F0B /* Get/Set pixel clock */
-#define VBE_PowManExt          0x4F10 /* Power Management Extensions (PM) */
-#define VBE_FlaPanIntExt       0x4F11 /* Flat Panel Interface Extensions (FP) */
-#define VBE_AudIntExt          0x4F13 /* Audio Interface Extensions (AI) */
-#define VBE_OEMExt             0x4F14 /* OEM Extensions */
-#define VBE_DisDatCha          0x4F15 /* Display Data Channel (DDC),
-                                         Serial Control Interface (SCI) */
+/** VBE function - Return VBE Controller Information */
+#define VBE_RetVBEConInf       0x4F00
+/** VBE function - Return VBE Mode Information */
+#define VBE_RetVBEModInf       0x4F01
+/** VBE function - Set VBE Mode */
+#define VBE_SetVBEMod          0x4F02
+/** VBE function - Return Current VBE Mode */
+#define VBE_RetCurVBEMod       0x4F03
+/** VBE function - Save/Restore State */
+#define VBE_SavResSta          0x4F04
+/** VBE function - Display Window Control */
+#define VBE_DisWinCon          0x4F05
+/** VBE function - Set/Get Logical Scan Line Length */
+#define VBE_SetGetLogScaLinLen 0x4F06
+/** VBE function - Set/Get Display Start */
+#define VBE_SetGetDisSta       0x4F07
+/** VBE function - Set/Get DAC Palette Format */
+#define VBE_SetGetDACPalFor    0x4F08
+/** VBE function - Set/Get Palette Data */
+#define VBE_SetGetPalDat       0x4F09
+/** VBE function - Return VBE Protected Mode Interface */
+#define VBE_RetVBEProModInt    0x4F0A
+/** VBE function - Get/Set pixel clock */
+#define VBE_GetSetpixclo       0x4F0B
+/** VBE function - Power Management Extensions (PM) */
+#define VBE_PowManExt          0x4F10
+/** VBE function - Flat Panel Interface Extensions (FP) */
+#define VBE_FlaPanIntExt       0x4F11
+/** VBE function - Audio Interface Extensions (AI) */
+#define VBE_AudIntExt          0x4F13
+/** VBE function - OEM Extensions */
+#define VBE_OEMExt             0x4F14
+/** VBE function - Display Data Channel (DDC), Serial Control Interface (SCI) */
+#define VBE_DisDatCha          0x4F15
 /* VBE subfunction numbers - passed in BL register */
-#define VBE_RetVBESupSpeInf    0x00  /* Return VBE Supplemental
-                                        Specification Information */
+#define VBE_RetVBESupSpeInf    0x00  /**< Return VBE Supplemental
+                                      * Specification Information */
 /* *** Structures *** */
+ * @brief Far pointer as defined by VBE standard.
 typedef struct {
+    /** @brief Offset to segment described by \a selector. */
     uint16_t offset;
+    /** @brief Selector or Segment depending on whether this is used from 16bit
+        protected mode or from real mode. */
     uint16_t selector;
 } RTEMS_COMPILER_PACKED_ATTRIBUTE VBE_far_pointer;
+ * @brief Protected mode info block as defined by VBE standard.
 typedef struct {
-    uint8_t   Signature[4];    /*  PM Info Block Signature */
-    uint16_t  EntryPoint;      /*  Offset of PM entry point within BIOS */
-    uint16_t  PMInitialize;    /*  Offset of PM initialization entry point */
-    uint16_t  BIOSDataSel;     /*  Selector to BIOS data area emulation block */
-    uint16_t  A0000Sel;        /*  Selector to access A0000h physical mem */
-    uint16_t  B0000Sel;        /*  Selector to access B0000h physical mem */
-    uint16_t  B8000Sel;        /*  Selector to access B8000h physical mem */
-    uint16_t  CodeSegSel;      /*  Selector to access code segment as data */
-    uint8_t   InProtectMode;   /*  Set to 1 when in protected mode */
-    uint8_t   Checksum;        /*  Checksum byte for structure */
+    /** PM Info Block Signature */
+    uint8_t   Signature[4];
+    /** Offset of PM entry point within BIOS */
+    uint16_t  EntryPoint;
+    /** Offset of PM initialization entry point */
+    uint16_t  PMInitialize;
+    /** Selector to BIOS data area emulation block */
+    uint16_t  BIOSDataSel;
+    /** Selector to access A0000h physical memmory */
+    uint16_t  A0000Sel;
+    /** Selector to access B0000h physical memmory */
+    uint16_t  B0000Sel;
+    /** Selector to access B8000h physical memmory */
+    uint16_t  B8000Sel;
+    /** Selector to access code segment as data */
+    uint16_t  CodeSegSel;
+    /** Set to 1 when in protected mode */
+    uint8_t   InProtectMode;
+    /** Checksum byte for structure. Sum over all structure bytes gives 0. */
+    uint8_t   Checksum;
 } RTEMS_COMPILER_PACKED_ATTRIBUTE VBE_protected_mode_info_block;
-/* General VBE signature */
+/** General VBE signature */
 #define VBE_SIGNATURE "VESA"
-/* Signature for VBE 2.0 and higher */
+/** Signature for VBE 2.0 and higher */
 #define VBE20plus_SIGNATURE "VBE2"
-/* for STUB see VBE CORE FUNCTIONS VERSION 3.0 - Appendix 1 */
-#define VBE_END_OF_VideoModeList 0xFFFF
+/** for STUB see VBE CORE FUNCTIONS VERSION 3.0 - Appendix 1 */
 #define VBE_STUB_VideoModeList 0xFFFF
+#define VBE_END_OF_VideoModeList 0xFFFF
+ * @brief Information about VBE implementation.
 typedef struct {
-    uint8_t   VbeSignature[4];   /*  VBE Signature */
-    uint16_t  VbeVersion;        /*  VBE Version */
-    uint8_t  *OemStringPtr;      /*  VbeFarPtr to OEM String */
-    uint8_t   Capabilities[4];   /*  Capabilities of graphics controller */
-    uint32_t *VideoModePtr;      /*  VbeFarPtr to VideoModeList */
-    uint16_t  TotalMemory;       /*  Number of 64kb memory blocks    */
+    /** VBE Signature */
+    uint8_t   VbeSignature[4];
+    /** VBE Version */
+    uint16_t  VbeVersion;
+    /** VBE_far_pointer to OEM String */
+    uint8_t  *OemStringPtr;
+    /** Capabilities of graphics controller */
+    uint8_t   Capabilities[4];
+    /** VBE_far_pointer to VideoModeList */
+    uint32_t *VideoModePtr;
+    /** Number of 64kb memory blocks    */
+    uint16_t  TotalMemory;
     /*  Added for VBE 2.0+ */
-    uint16_t  OemSoftwareRev;    /*  VBE implementation Software revision */
-    uint8_t  *OemVendorNamePtr;  /*  VbeFarPtr to Vendor Name String */
-    uint8_t  *OemProductNamePtr; /*  VbeFarPtr to Product Name String */
-    uint8_t  *OemProductRevPtr;  /*  VbeFarPtr to Product Revision String */
-    uint8_t   Reserved[222];     /*  Reserved for VBE implementation scratch */
-    /*    area */
-    uint8_t   OemData[256];      /*  Data Area for OEM Strings */
+    /** VBE implementation Software revision */
+    uint16_t  OemSoftwareRev;
+    /** VBE_far_pointer to Vendor Name String */
+    uint8_t  *OemVendorNamePtr;
+    /** VBE_far_pointer to Product Name String */
+    uint8_t  *OemProductNamePtr;
+    /** VBE_far_pointer to Product Revision String */
+    uint8_t  *OemProductRevPtr;
+    /** Reserved for VBE implementation scratch */
+    uint8_t   Reserved[222];
+    /** Data Area for OEM Strings */
+    uint8_t   OemData[256];
 } RTEMS_COMPILER_PACKED_ATTRIBUTE VBE_vbe_info_block;
+ * @brief Describes graphic's mode parameter.
 typedef struct {
     /*  Mandatory information for all VBE revisions */
-    uint16_t  ModeAttributes;        /* mode attributes */
-    uint8_t   WinAAttributes;        /* window A attributes */
-    uint8_t   WinBAttributes;        /* window B attributes */
-    uint16_t  WinGranularity;        /* window granularity */
-    uint16_t  WinSize;               /* window size */
-    uint16_t  WinASegment;           /* window A start segment */
-    uint16_t  WinBSegment;           /* window B start segment */
-    uint32_t *WinFuncPtr;            /* real mode pointer to window function */
-    uint16_t  BytesPerScanLine;      /* bytes per scan line */
+    /** mode attributes */
+    uint16_t  ModeAttributes;
+    /** window A attributes */
+    uint8_t   WinAAttributes;
+    /** window B attributes */
+    uint8_t   WinBAttributes;
+    /** window granularity */
+    uint16_t  WinGranularity;
+    /** window size */
+    uint16_t  WinSize;
+    /** window A start segment */
+    uint16_t  WinASegment;
+    /** window B start segment */
+    uint16_t  WinBSegment;
+    /** real mode pointer to window function */
+    uint32_t *WinFuncPtr;
+    /** bytes per scan line */
+    uint16_t  BytesPerScanLine;
     /*  Mandatory information for VBE 1.2 and above */
-    uint16_t  XResolution;           /* horizontal resolution in px or chars */
-    uint16_t  YResolution;           /* vertical resolution in px or chars */
-    uint8_t   XCharSize;             /* character cell width in pixels */
-    uint8_t   YCharSize;             /* character cell height in pixels */
-    uint8_t   NumberOfPlanes;        /* number of memory planes */
-    uint8_t   BitsPerPixel;          /* bits per pixel */
-    uint8_t   NumberOfBanks;         /* number of banks */
-    uint8_t   MemoryModel;           /* memory model type */
-    uint8_t   BankSize;              /* bank size in KB */
-    uint8_t   NumberOfImagePages;    /* number of images */
-    uint8_t   Reserved0;             /* reserved for page function */
+    /** horizontal resolution in px or chars */
+    uint16_t  XResolution;
+    /** vertical resolution in px or chars */
+    uint16_t  YResolution;
+    /** character cell width in pixels */
+    uint8_t   XCharSize;
+    /** character cell height in pixels */
+    uint8_t   YCharSize;
+    /** number of memory planes */
+    uint8_t   NumberOfPlanes;
+    uint8_t   BitsPerPixel;
+    /** number of banks */
+    uint8_t   NumberOfBanks;
+    /** memory model type */
+    uint8_t   MemoryModel;
+    /** bank size in KB */
+    uint8_t   BankSize;
+    /** number of images */
+    uint8_t   NumberOfImagePages;
+    /** reserved for page function */
+    uint8_t   Reserved0;
     /*  Direct Color fields (required for direct/6 and YUV/7 memory models) */
-    uint8_t   RedMaskSize;           /* size of direct color red mask in bits */
-    uint8_t   RedFieldPosition;      /* bit position of lsb of red mask */
-    uint8_t   GreenMaskSize;         /* size of direct color green mask in b */
-    uint8_t   GreenFieldPosition;    /* bit position of lsb of green mask */
-    uint8_t   BlueMaskSize;          /* size of direct color blue mask in b */
-    uint8_t   BlueFieldPosition;     /* bit position of lsb of blue mask */
-    uint8_t   RsvdMaskSize;          /* size of direct color reserved mask */
-    uint8_t   RsvdFieldPosition;     /* bit position of lsb of reserved mask */
-    uint8_t   DirectColorModeInfo;   /* direct color mode attributes */
+    /** size of direct color red mask in bits */
+    uint8_t   RedMaskSize;
+    /** bit position of lsb of red mask */
+    uint8_t   RedFieldPosition;
+    /** size of direct color green mask in b */
+    uint8_t   GreenMaskSize;
+    /** bit position of lsb of green mask */
+    uint8_t   GreenFieldPosition;
+    /** size of direct color blue mask in b */
+    uint8_t   BlueMaskSize;
+    /** bit position of lsb of blue mask */
+    uint8_t   BlueFieldPosition;
+    /** size of direct color reserved mask */
+    uint8_t   RsvdMaskSize;
+    /** bit position of lsb of reserved mask */
+    uint8_t   RsvdFieldPosition;
+    /** direct color mode attributes */
+    uint8_t   DirectColorModeInfo;
     /*  Mandatory information for VBE 2.0 and above */
-    uint32_t *PhysBasePtr;           /* physical address for
-                                        flat memory frame buffer */
-    uint32_t  Reserved1;             /* Reserved - always set to 0 */
-    uint16_t  Reserved2;             /* Reserved - always set to 0 */
+    /** physical address for flat memory frame buffer */
+    uint32_t *PhysBasePtr;
+    /** Reserved - always set to 0 */
+    uint32_t  Reserved1;
+    uint16_t  Reserved2;
     /*  Mandatory information for VBE 3.0 and above */
-    uint16_t  LinBytesPerScanLine;   /* bytes per scan line for linear modes */
-    uint8_t   BnkNumberOfImagePages; /* number of images for banked modes */
-    uint8_t   LinNumberOfImagePages; /* number of images for linear modes */
+    /** bytes per scan line for linear modes */
+    uint16_t  LinBytesPerScanLine;
+    /** number of images for banked modes */
+    uint8_t   BnkNumberOfImagePages;
+    /** number of images for linear modes */
+    uint8_t   LinNumberOfImagePages;
         /* linear modes */
-    uint8_t   LinRedMaskSize;        /* size of direct color red mask */
-    uint8_t   LinRedFieldPosition;   /* bit position of lsb of red mask */
-    uint8_t   LinGreenMaskSize;      /* size of direct color green mask  */
-    uint8_t   LinGreenFieldPosition; /* bit position of lsb of green mask */
-    uint8_t   LinBlueMaskSize;       /* size of direct color blue mask  */
-    uint8_t   LinBlueFieldPosition;  /* bit position of lsb of blue mask */
-    uint8_t   LinRsvdMaskSize;       /* size of direct color reserved mask */
-    uint8_t   LinRsvdFieldPosition;  /* bit position of lsb of reserved mask */
-    uint32_t  MaxPixelClock;         /* maximum pixel clock
-                                        (in Hz) for graphics mode */
-    uint8_t   Reserved3[189];        /* remainder of ModeInfoBlock */
+    /** size of direct color red mask */
+    uint8_t   LinRedMaskSize;
+    uint8_t   LinRedFieldPosition;
+    /** size of direct color green mask  */
+    uint8_t   LinGreenMaskSize;
+    uint8_t   LinGreenFieldPosition;
+    /** size of direct color blue mask  */
+    uint8_t   LinBlueMaskSize;
+    uint8_t   LinBlueFieldPosition;
+    uint8_t   LinRsvdMaskSize;
+    uint8_t   LinRsvdFieldPosition;
+    /** maximum pixel clock (in Hz) for graphics mode */
+    uint32_t  MaxPixelClock;
+    /** remainder of VBE_mode_info_block */
+    uint8_t   Reserved3[189];
 } RTEMS_COMPILER_PACKED_ATTRIBUTE VBE_mode_info_block;
+ * @brief Describes monitor synchronization.
 typedef struct {
-    uint16_t  HorizontalTotal;       /* Horizontal total in pixels */
-    uint16_t  HorizontalSyncStart;   /* Horizontal sync start in pixels */
-    uint16_t  HorizontalSyncEnd;     /* Horizontal sync end in pixels */
-    uint16_t  VerticalTotal;         /* Vertical total in lines */
-    uint16_t  VerticalSyncStart;     /* Vertical sync start in lines */
-    uint16_t  VerticalSyncEnd;       /* Vertical sync end in lines */
-    uint8_t   Flags;                 /* Flags (Interlaced, Double Scan etc) */
-    uint32_t  PixelClock;            /* Pixel clock in units of Hz */
-    uint16_t  RefreshRate;           /* Refresh rate in units of 0.01 Hz */
-    uint8_t   Reserved[40];          /* remainder of ModeInfoBlock */
+    /** Horizontal total in pixels */
+    uint16_t  HorizontalTotal;
+    /** Horizontal sync start in pixels */
+    uint16_t  HorizontalSyncStart;
+    /** Horizontal sync end in pixels */
+    uint16_t  HorizontalSyncEnd;
+    /** Vertical total in lines */
+    uint16_t  VerticalTotal;
+    /** Vertical sync start in lines */
+    uint16_t  VerticalSyncStart;
+    /** Vertical sync end in lines */
+    uint16_t  VerticalSyncEnd;
+    /** Flags (Interlaced, Double Scan etc) */
+    uint8_t   Flags;
+    /** Pixel clock in units of Hz */
+    uint32_t  PixelClock;
+    /** Refresh rate in units of 0.01 Hz */
+    uint16_t  RefreshRate;
+    uint8_t   Reserved[40];
 } RTEMS_COMPILER_PACKED_ATTRIBUTE VBE_CRTC_info_block;
+ * @brief Describes palette entry.
 typedef struct {
-    uint8_t   Blue;                  /* Blue channel value (6 or 8 bits) */
-    uint8_t   Green;                 /* Green channel value (6 or 8 bits) */
-    uint8_t   Red;                   /* Red channel value(6 or 8 bits) */
-    uint8_t   Alignment;             /* DWORD alignment byte (unused) */
+    /** Blue channel value (6 or 8 bits) */
+    uint8_t   Blue;
+    /** Green channel value (6 or 8 bits) */
+    uint8_t   Green;
+    /** Red channel value(6 or 8 bits) */
+    uint8_t   Red;
+    /** DWORD alignment byte (unused) */
+    uint8_t   Alignment;
 } RTEMS_COMPILER_PACKED_ATTRIBUTE VBE_palette_entry;
+ * @brief Supplemental VBE info block.
 typedef struct {
-    uint8_t   SupVbeSignature[7];    /* Supplemental VBE Signature */
-    uint16_t  SupVbeVersion;         /* Supplemental VBE Version */
-    uint8_t   SupVbeSubFunc[8];      /* Bitfield of supported subfunctions */
-    uint16_t  OemSoftwareRev;        /* OEM Software revision */
-    uint8_t   Reserved[221];         /* Reserved for description
-                                        strings and future */
-    /*  expansion */
+    /** Supplemental VBE Signature */
+    uint8_t   SupVbeSignature[7];
+    /** Supplemental VBE Version */
+    uint16_t  SupVbeVersion;
+    /** Bitfield of supported subfunctions */
+    uint8_t   SupVbeSubFunc[8];
+    /** OEM Software revision */
+    /** Reserved for description strings and future expansion */
+    uint8_t   Reserved[221];
 } RTEMS_COMPILER_PACKED_ATTRIBUTE VBE_supplemental_vbe_info_block;
-/* VbeInfoBlock Capabilities */
-/*  D0 = 0  DAC is fixed width, with 6 bits per primary color */
-/*     = 1 DAC width is switchable to 8 bits per primary color */
+/* VBE_vbe_info_block Capabilities */
+/** VBE Info Block - Capabilities\n
+    D0 = 0  DAC is fixed width, with 6 bits per primary color \n
+    D0 = 1 DAC width is switchable to 8 bits per primary color */
 #define VBE_DACswitchableMask     0x0001
-/*  D1 = 0 Controller is VGA compatible */
-/*     = 1 Controller is not VGA compatible */
+    D1 = 0 Controller is VGA compatible \n
+    D1 = 1 Controller is not VGA compatible */
 #define VBE_notVGAcompatibleMask  0x0002
-/*  D2 = 0 Normal RAMDAC operation */
-/*     = 1 When programming large blocks of information to the RAMDAC,
+    D2 = 0 Normal RAMDAC operation \n
+    D2 = 1 When programming large blocks of information to the RAMDAC,
             use the blank bit in Function 09h. */
 #define VBE_specialRAMDACopMask   0x0004
-/*  D3 = 0 No hardware stereoscopic signaling support */
-/*     = 1 Hardware stereoscopic signaling supported by controller */
+    D3 = 0 No hardware stereoscopic signaling support \n
+    D3 = 1 Hardware stereoscopic signaling supported by controller */
 #define VBE_hwStereoscopicMask    0x0008
-/*  D4 = 0 Stereo signaling supported via external VESA stereo connector */
-/*     = 1 Stereo signaling supported via VESA EVC connector */
+    D4 = 0 Stereo signaling supported via external VESA stereo connector \n
+    D4 = 1 Stereo signaling supported via VESA EVC connector */
 #define VBE_supportEVCconnMask    0x0010
 /*  D5-31 = Reserved */
-/* ModeInfoBlock ModeAttributes */
-/*  D0 =  Mode supported by hardware configuration */
-/*   0 =  Mode not supported in hardware */
-/*   1 =  Mode supported in hardware */
+/* VBE_mode_info_block ModeAttributes */
+/** Mode Info Block - Mode Attributes\n
+    D0 =  Mode supported by hardware configuration.
+     0 =  Mode not supported in hardware\n
+     1 =  Mode supported in hardware */
 #define VBE_modSupInHWMask        0x0001
 /*  D1 =  1 (Reserved) */
-/*  D2 =  TTY Output functions supported by BIOS */
-/*   0 =  TTY Output functions not supported by BIOS */
-/*   1 =  TTY Output functions supported by BIOS */
+    D2 =  TTY Output functions supported by BIOS.
+     0 =  TTY Output functions not supported by BIOS\n
+     1 =  TTY Output functions supported by BIOS */
 #define VBE_TTYOutSupByBIOSMask   0x0004
-/*  D3 =  Monochrome/color mode (see note below) */
-/*   0 =  Monochrome mode */
-/*   1 =  Color mode */
+    D3 =  Monochrome/color mode (see note below).
+     0 =  Monochrome mode\n
+     1 =  Color mode */
 #define VBE_ColorModeMask         0x0008
-/*  D4 =  Mode type */
-/*   0 =  Text mode */
-/*   1 =  Graphics mode */
+    D4 =  Mode type.
+     0 =  Text mode\n
+     1 =  Graphics mode */
 #define VBE_GraphicsModeMask      0x0010
-/*  D5 =  VGA compatible mode */
-/*   0 =  Yes */
-/*   1 =  No */
+    D5 =  VGA compatible mode.
+     0 =  Yes\n
+     1 =  No */
 #define VBE_VGACompModeMask       0x0020
-/*  D6 =  VGA compatible windowed memory mode is available */
-/*   0 =  Yes */
-/*   1 =  No */
+    D6 =  VGA compatible windowed memory mode is available.
+     0 =  Yes\n
+     1 =  No */
 #define VBE_VGACompWinMemModeMask 0x0040
-/*  D7 =  Linear frame buffer mode is available */
-/*   0 =  No */
-/*   1 =  Yes */
+    D7 =  Linear frame buffer mode is available.
+     0 =  No\n
+     1 =  Yes */
 #define VBE_LinFraBufModeAvaiMask 0x0080
-/*  D8 =  Double scan mode is available */
-/*   0 =  No */
-/*   1 =  Yes */
+    D8 =  Double scan mode is available.
+     0 =  No\n
+     1 =  Yes */
 #define VBE_DblScnModeAvaiMask    0x0100
-/*  D9 =  Interlaced mode is available */
-/*   0 =  No */
-/*   1 =  Yes */
+    D9 =  Interlaced mode is available.
+     0 =  No\n
+     1 =  Yes */
 #define VBE_InterlModeAvaiMask    0x0200
-/*  D10 =  Hardware triple buffering support */
-/*   0 =  No */
-/*   1 =  Yes */
+    D10 =  Hardware triple buffering support.
+     0 =  No\n
+     1 =  Yes */
 #define VBE_HWTripBufSupMask      0x0400
-/*  D11 =  Hardware stereoscopic display support */
-/*   0 =  No */
-/*   1 =  Yes */
+    D11 =  Hardware stereoscopic display support.
+     0 =  No\n
+     1 =  Yes */
 #define VBE_HWSterDispSupMask     0x0800
-/*  D12 =  Dual display start address support */
-/*   0 =  No */
-/*   1 =  Yes */
+    D12 =  Dual display start address support.
+     0 =  No\n
+     1 =  Yes */
 #define VBE_DualDispStAdrSupMask  0x1000
 /*  D13-D15 =  Reserved */
-/* ModeInfoBlock WinXAttributes */
-/*  D0 =  Relocatable window(s) supported */
-/*   0 =  Single non-relocatable window only */
-/*   1 =  Relocatable window(s) are supported */
+/* VBE_mode_info_block WinXAttributes */
+/** D0 =  Relocatable window(s) supported.
+     0 =  Single non-relocatable window only\n
+     1 =  Relocatable window(s) are supported */
 #define VBE_RelocWinSupMask       0x01
-/*  D1 =  Window readable */
-/*   0 =  Window is not readable */
-/*   1 =  Window is readable */
+/** D1 =  Window readable.
+     0 =  Window is not readable\n
+     1 =  Window is readable */
 #define VBE_WinReadableMask       0x02
-/*  D2 =  Window writeable */
-/*   0 =  Window is not writeable */
-/*   1 =  Window is writeable */
+/** D2 =  Window writeable.
+     0 =  Window is not writeable\n
+     1 =  Window is writeable */
 #define VBE_WinWritableMask       0x04
 /*  D3-D7 =  Reserved */
-/* ModeInfoBlock MemoryModel */
+/* VBE_mode_info_block MemoryModel */
 #define VBE_TextMode              0x00
 #define VBE_CGAGraphics           0x01
 #define VBE_HerculesGraphics      0x02
@@ -385,32 +526,36 @@ typedef struct {
     /* 0x08-0x0F Reserved, to be defined by VESA */
     /* 0x10-0xFF To be defined by OEM */
-/* ModeInfoBlock DirectColorModeInfo */
-/*  D0 =  Color ramp is fixed/programmable */
-/*   0 =  Color ramp is fixed */
-/*   1 =  Color ramp is programmable */
+/* VBE_mode_info_block DirectColorModeInfo */
+/** D0 =  Color ramp is fixed/programmable.
+     0 =  Color ramp is fixed\n
+     1 =  Color ramp is programmable */
 #define VBE_ColRampProgMask       0x01
-/*  D1 =  Bits in Rsvd field are usable/reserved */
-/*   0 =  Bits in Rsvd field are reserved */
-/*   1 =  Bits in Rsvd field are usable by the application */
+/** D1 =  Bits in Rsvd field are usable/reserved.
+     0 =  Bits in Rsvd field are reserved\n
+     1 =  Bits in Rsvd field are usable by the application */
 #define VBE_RsvdBitsUsableMask    0x02
-/* CRTCInfoBlock Flags */
-/*  D0 =  Double Scan Mode Enable */
-/*   0 =  Graphics mode is not double scanned */
-/*   1 =  Graphics mode is double scanned */
+/* VBE_CRTC_info_block Flags */
+/** CRTC Info Block - Flags\n
+    D0 =  Double Scan Mode Enable.
+     0 =  Graphics mode is not double scanned\n
+     1 =  Graphics mode is double scanned */
 #define VBE_GrModeDblScanMask     0x01
-/*  D1 =  Interlaced Mode Enable */
-/*   0 =  Graphics mode is non-interlaced */
-/*   1 =  Graphics mode is interlaced */
+    D1 =  Interlaced Mode Enable.
+     0 =  Graphics mode is non-interlaced\n
+     1 =  Graphics mode is interlaced */
 #define VBE_GrModeInterlMask      0x02
-/*  D2 =  Horizontal sync polarity */
-/*   0 =  Horizontal sync polarity is positive (+) */
-/*   1 =  Horizontal sync polarity is negative (-) */
+    D2 =  Horizontal sync polarity.
+     0 =  Horizontal sync polarity is positive (+)\n
+     1 =  Horizontal sync polarity is negative (-) */
 #define VBE_HorSncPolNegMask      0x04
-/*  D3 =  Vertical sync polarity */
-/*   0 =  Vertical sync polarity is positive (+) */
-/*   1 =  Vertical sync polarity is negative (-) */
+    D3 =  Vertical sync polarity.
+     0 =  Vertical sync polarity is positive (+)\n
+     1 =  Vertical sync polarity is negative (-) */
 #define VBE_VerSncPolNegMask      0x08
@@ -418,17 +563,19 @@ typedef struct {
     Version: 1.1 November 18, 1999                      */
 /* VBE/DDC subfunction numbers - passed in BL register */
-#define VBEDDC_Capabilities    0x0   /* Report VBE/DDC Capabilities */
-#define VBEDDC_ReadEDID        0x1   /* Read EDID */
+/** VBE/DDC subfunction - Report VBE/DDC Capabilities */
+#define VBEDDC_Capabilities    0x0
+/** VBE/DDC subfunction - Read EDID */
+#define VBEDDC_ReadEDID        0x1
 /* DDC Capabilities */
 /* DDC level supported - returned in BL register */
-/* 0 - DDC1 not supported; 1 - DDC1 supported */
+/** 0 - DDC1 not supported; 1 - DDC1 supported */
 #define VBEDDC_1SupportedMask  0x1
-/* 0 - DDC2 not supported; 1 - DDC2 supported */
+/** 0 - DDC2 not supported; 1 - DDC2 supported */
 #define VBEDDC_2SupportedMask  0x2
-/* 0 - Screen not blanked during data transfer;
-   1 - Screen blanked during data transfer */
+/** 0 - Screen not blanked during data transfer\n
+    1 - Screen blanked during data transfer */
 #define VBEDDC_scrBlnkDatTrMs  0x4
@@ -436,20 +583,31 @@ typedef struct {
     Version: 1.0 Revision: 2 Date: July 2, 1997         */
 /* VBE/SCI subfunction numbers - passed in BL register */
-#define VBESCI_ReportCapabil   0x10  /* Report VBE/SCI Capabilities */
-#define VBESCI_BegSCLSDACtrl   0x11  /* Begin SCL/SDA control */
-#define VBESCI_EndSCLSDACtrl   0x12  /* End SCL/SDA control */
-#define VBESCI_WrtSCLClkLine   0x13  /* Write SCL clock line */
-#define VBESCI_WrtSDADatLine   0x14  /* Write SDA data line */
-#define VBESCI_RdySCLClkLine   0x15  /* Read SCL clock line */
-#define VBESCI_RdySDADatLine   0x16  /* Read SDA data line */
+/** VBE/SCI subfunction - Report VBE/SCI Capabilities */
+#define VBESCI_ReportCapabil   0x10
+/** VBE/SCI subfunction - Begin SCL/SDA control */
+#define VBESCI_BegSCLSDACtrl   0x11
+/** VBE/SCI subfunction - End SCL/SDA control */
+#define VBESCI_EndSCLSDACtrl   0x12
+/** VBE/SCI subfunction - Write SCL clock line */
+#define VBESCI_WrtSCLClkLine   0x13
+/** VBE/SCI subfunction - Write SDA data line */
+#define VBESCI_WrtSDADatLine   0x14
+/** VBE/SCI subfunction - Read SCL clock line */
+#define VBESCI_RdySCLClkLine   0x15
+/** VBE/SCI subfunction - Read SDA data line */
+#define VBESCI_RdySDADatLine   0x16
 /* SCI Capabilities */
 /* I2C level supported - returned in BL register */
-#define VBESCI_capSCLwrtMask   0x1   /* Can write to SCL clock line */
-#define VBESCI_capSDAwrtMask   0x2   /* Can write to SDA data line */
-#define VBESCI_capSCLrdyMask   0x4   /* Can read from SCL clock line */
-#define VBESCI_capSDArdyMask   0x8   /* Can read from SDA data line */
+/** Can write to SCL clock line */
+#define VBESCI_capSCLwrtMask   0x1
+/** Can write to SDA data line */
+#define VBESCI_capSDAwrtMask   0x2
+/** Can read from SCL clock line */
+#define VBESCI_capSCLrdyMask   0x4
+/** Can read from SDA data line */
+#define VBESCI_capSDArdyMask   0x8
 #ifdef __cplusplus
diff --git a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
index af5cf1e..6836af3 100644
--- a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
+++ b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.c
@@ -1,20 +1,28 @@
- *  Realmode interrupt call implementation.
+ * @file realmode_int.c
+ * @ingroup i386_shared
+ * @brief Real mode interrupt call implementation
 #include <bsp/realmode_int.h>
 #include <rtems/score/cpu.h>
+ * offsets to \a i386_realmode_interrupt_registers declared in realmode_int.h
+ * used in inline assmbler for better readability
 #define IR_EAX_OFF      "0x00"
 #define IR_EBX_OFF      "0x04"
 #define IR_ECX_OFF      "0x08"
@@ -26,25 +34,45 @@
 #define IR_FS_OFF       "0x1C"
 #define IR_GS_OFF       "0x1E"
+ * offsets to \a rm_int_regs_bkp_param
 #define BKP_ESP_OFF     "0x20"
 #define BKP_SS_OFF      "0x24"
 #define BKP_DS_OFF      "0x26"
 #define RM_ENTRY        "0x28"
 #define PM_ENTRY        "0x2C"
-/* parameters, results, backup values accessible in real mode */
+ * @brief parameters, results, backup values accessible in real mode
+ * @note Struct members not necessarily used in C. This serves also as
+ *       layout of memory and it is used within inline assembler.
 typedef struct {
     i386_realmode_interrupt_registers inoutregs;
+    /** spot for back up of protected mode stack pointer */
     uint32_t pm_esp_bkp;
+    /** spot for back up of protected mode stack selector */
     uint16_t pm_ss_bkp;
+    /** spot for back up of protected mode data selector */
     uint16_t ds_bkp;
+    /** spot for setting up long indirect jump offset
+        to real mode from 16bit protected mode */
     uint16_t rm_entry;
+    /** spot for setting up long indirect jump segment
     uint16_t rm_code_segment;
+    /** returning offset for long indirect jump back
+        to 32bit protected mode */
     uint32_t pm_entry;
+    /** returning selector for long indirect jump back
     uint16_t pm_code_selector;
-    /* if modifying update offset definitions as well */
+    /* if this struct is to be modified update offset definitions as well */
 } RTEMS_COMPILER_PACKED_ATTRIBUTE rm_int_regs_bkp_param;
+/* offsets to \a pm_bkp_and_param */
 #define BKP_IDTR_LIM    "0x00"
 #define BKP_IDTR_BASE   "0x02"
 #define BKP_ES_OFF      "0x06"
@@ -55,18 +83,35 @@ typedef struct {
 #define RM_SS           "0x14"
 #define RM_SP           "0x16"
 #define RM_DS           "0x18"
-/* backup values, pointers/parameters accessible in protected mode */
+ * @brief backup values, pointers/parameters accessible in protected mode
 typedef struct {
+    /** spot for backup protected mode interrupt descriptor table register */
     uint16_t idtr_lim_bkp;
+    /** @see idtr_lim_bkp */
     uint32_t idtr_base_bkp;
+    /** spot to backup of ES register value in 32bit protected mode */
     uint16_t es_bkp;
+    /** spot to backup of FS register value in 32bit protected mode */
     uint16_t fs_bkp;
+    /** spot to backup of GS register value in 32bit protected mode */
     uint16_t gs_bkp;
+    /** values for indirect jump to 16bit protected mode */
     uint32_t rml_entry;
+    /** @see rml_entry */
     uint16_t rml_code_selector;
+    /** data selector for 16bit protected mode */
     uint16_t rml_data_selector;
+    /** values determinig location of real mode stack */
     uint16_t rm_stack_segment;
+    /** @see rm_stack_segment */
     uint16_t rm_stack_pointer;
+    /** data segment for real mode */
     uint16_t rm_data_segment;
 } RTEMS_COMPILER_PACKED_ATTRIBUTE pm_bkp_and_param;
@@ -112,10 +157,14 @@ static __DP_TYPE descsPrepared = __DP_NO;
 static uint16_t rml_code_dsc_index = 0;
 static uint16_t rml_data_dsc_index = 0;
- * Prepares real-mode like descriptors to be used for switching
+ * @brief Prepares real-mode like descriptors to be used for switching
  * to real mode.
+ * Descriptors will be placed to the GDT.
+ * @param[in] base32 32-bit physical address to be used as base for 16-bit
+ *               protected mode descriptors
  * @retval __DP_YES descriptors are prepared
  * @retval __DP_FAIL descriptors allocation failed (GDT too small)
diff --git a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
index a0216ea..6f77ec9 100644
--- a/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
+++ b/c/src/lib/libbsp/i386/shared/realmode_int/realmode_int.h
@@ -4,14 +4,14 @@
  * @brief Definitioins supporting real mode interrupt calls.
+ * Interface allows calling given interrupt number with content of the
+ * registers defined. For passing or receiving higher amounts of the data
+ * there is a buffer accessible from real mode available. Real mode pointer
+ * to this buffer is passed to the interrupt in the registers.
- *  Interface allows calling given interrupt number with content of the
- *  registers defined. For passing or receiving higher amounts of the data
- *  there is a buffer accessible from real mode available. Real mode pointer
- *  to this buffer is passed to the interrupt in the registers.
  *                     CTU in Prague.
@@ -36,7 +36,11 @@ extern "C" {
 /* number of interrupt servicing video functions */
 #define INTERRUPT_NO_VIDEO_SERVICES 0x10
-typedef struct { /* used for passing parameters, fetching results and preserving values */
+ * @brief Used for passing and retrieving registers content to/from real mode
+ * interrupt call.
+typedef struct {
     uint32_t reg_eax;
     uint32_t reg_ebx;
     uint32_t reg_ecx;
@@ -50,6 +54,8 @@ typedef struct { /* used for passing parameters, fetching results and preserving
 } RTEMS_COMPILER_PACKED_ATTRIBUTE i386_realmode_interrupt_registers;
+ * @brief Returns buffer and its size usable with real mode interrupt call.
  * Provides position to real mode buffer. It is buffer
  * accessible from real mode context - it is located below
  * address ~0x100000 in order for it to be accessible
@@ -57,22 +63,25 @@ typedef struct { /* used for passing parameters, fetching results and preserving
  * and through this get bigger portion of an information to/from
  * interrupt service routine than just by using register.
- * @param size pointer to variable, where the size of buffer
- *        will be filled
+ * @param[out] size pointer to variable, where the size of buffer
+ *             will be filled
  * @retval pointer to buffer
 extern void *i386_get_default_rm_buffer(uint16_t *size);
+ * @brief Call to real mode interrupt with specified int NO and processor
+ * registers.
  * This function allows calling interrupts in real mode and to set processor
  * registers as desired before interrupt call is made and to retrieve the
  * registers content after call was made.
- * @param interruptNumber interrupt number to be called
- * @param ir pointer to structure containing registers to be passed to interrupt
- *        and to retrieve register content after call was made.
+ * @param[in] interrupt_number interrupt number to be called
+ * @param[in] ir pointer to structure containing registers to be passed to
+ *            interrupt and to retrieve register content after call was made.
  * @retval  0 call failed (GDT too small or pagin is on)
- *          1 call successful
+ * @retval  1 call successful
 extern int i386_real_interrupt_call(
     uint8_t interrupt_number,
diff --git a/c/src/lib/libcpu/i386/cpu.h b/c/src/lib/libcpu/i386/cpu.h
index 23a82de..0242e27 100644
--- a/c/src/lib/libcpu/i386/cpu.h
+++ b/c/src/lib/libcpu/i386/cpu.h
@@ -1,5 +1,7 @@
- * cpu.h  - This file contains definitions for data structure related
+ * @file cpu.h
+ *          This file contains definitions for data structure related
  *          to Intel system programming. More information can be found
  *	    on Intel site and more precisely in the following book :
@@ -241,7 +243,9 @@ extern int i386_get_idt_config (rtems_raw_irq_global_settings** config);
  * See page 11.12 Figure 11-8.
+ * @brief describes one entry of Global/Local Descriptor Table
 typedef struct {
   unsigned int limit_15_0 		: 16;
   unsigned int base_address_15_0	: 16;
@@ -272,34 +276,36 @@ extern void i386_set_GDTR (segment_descriptors*,
                            uint16_t limit);
- * C callable function:
- * Puts global descriptor @sd to the global descriptor table on index
- * @segment_selector_index
+ * @brief Allows to set a GDT entry.
+ * Puts global descriptor \p sd to the global descriptor table on index
+ * \p segment_selector_index
+ * @param[in] segment_selector_index index to GDT entry
+ * @param[in] sd structure to be coppied to given \p segment_selector in GDT
  * @retval  0 FAILED out of GDT range or index is 0, which is not valid
  *                   index in GDT
- *          1 SUCCESS
+ * @retval  1 SUCCESS
 extern uint32_t i386_raw_gdt_entry (uint16_t segment_selector_index,
                                segment_descriptors* sd);
- * fills @sd with provided @base in appropriate fields of @sd
+ * @brief fills \p sd with provided \p base in appropriate fields of \p sd
- * @param base 32-bit address to be set as descriptor's base
- * @param sd descriptor being filled with @base
+ * @param[in] base 32-bit address to be set as descriptor's base
+ * @param[out] sd descriptor being filled with \p base
 extern void i386_fill_segment_desc_base (uint32_t base,
- * fills @sd with provided @limit in appropriate fields of @sd
- * also influences granularity bit
+ * @brief fills \p sd with provided \p limit in appropriate fields of \p sd
+ * sets granularity bit if necessary
- * @param limit 32-bit value representing number of limit bytes
- * @param sd descriptor being filled with @limit
+ * @param[in] limit 32-bit value representing number of limit bytes
+ * @param[out] sd descriptor being filled with \p limit
 extern void i386_fill_segment_desc_limit (uint32_t limit,
@@ -312,37 +318,40 @@ extern uint32_t i386_set_gdt_entry (uint16_t segment_selector,
                                     uint32_t limit);
- * C callable function returns next empty descriptor in GDT.
+ * @brief Returns next empty descriptor in GDT.
+ * Number of descriptors that can be returned depends on \a GDT_SIZE
  * @retval  0 FAILED GDT is full
- *          <1;65535> segment_selector number as index to GDT
+ * @retval  <1;65535> segment_selector number as index to GDT
 extern uint16_t i386_next_empty_gdt_entry (void);
- * Copies GDT entry at index @segment_selector to structure
- * pointed to by @struct_to_fill
+ * @brief Copies GDT entry at index \p segment_selector to structure
+ * pointed to by \p struct_to_fill
- * @param  segment_selector index to GDT table for specifying descriptor to copy
+ * @param[in] segment_selector index to GDT table specifying descriptor to copy
+ * @param[out] struct_to_fill pointer to memory where will be descriptor coppied
  * @retval  0 FAILED segment_selector out of GDT range
- *          <1;65535> retrieved segment_selector
+ * @retval  <1;65535> retrieved segment_selector
 extern uint16_t i386_cpy_gdt_entry (uint16_t segment_selector,
                                     segment_descriptors* struct_to_fill);
- * Returns pointer to GDT table at index given by @segment_selector
+ * @brief Returns pointer to GDT table at index given by \p segment_selector
- * @param   segment_selector index to GDT table for specifying descriptor to get
+ * @param[in] sgmnt_selector index to GDT table for specifying descriptor to get
  * @retval  NULL FAILED segment_selector out of GDT range
- *          pointer to GDT table at @segment_selector
+ * @retval  pointer to GDT table at \p segment_selector
 extern segment_descriptors* i386_get_gdt_entry (uint16_t sgmnt_selector);
- * Extracts base address from GDT entry pointed to by @gdt_entry
+ * @brief Extracts base address from GDT entry pointed to by \p gdt_entry
- * @param  gdt_entry pointer to entry from which base should be retrieved
+ * @param[in]  gdt_entry pointer to entry from which base should be retrieved
  * @retval base address from GDT entry
 RTEMS_INLINE_ROUTINE void* i386_base_gdt_entry (segment_descriptors* gdt_entry)
@@ -353,9 +362,9 @@ RTEMS_INLINE_ROUTINE void* i386_base_gdt_entry (segment_descriptors* gdt_entry)
- * Extracts limit in bytes from GDT entry pointed to by @gdt_entry
+ * @brief Extracts limit in bytes from GDT entry pointed to by \p gdt_entry
- * @param  gdt_entry pointer to entry from which limit should be retrieved
+ * @param[in]  gdt_entry pointer to entry from which limit should be retrieved
  * @retval limit value in bytes from GDT entry
 extern uint32_t i386_limit_gdt_entry (segment_descriptors* gdt_entry);
diff --git a/cpukit/score/cpu/i386/cpu_asm.S b/cpukit/score/cpu/i386/cpu_asm.S
index f3ef4e2..45079a6 100644
--- a/cpukit/score/cpu/i386/cpu_asm.S
+++ b/cpukit/score/cpu/i386/cpu_asm.S
@@ -334,9 +334,9 @@ SYM (i386_Physical_to_logical):
  *     uint16_t *offset
- *  Fills segment:offest realmode pointer counted from thirty-two bit physical
+ *  Fills segment:offest real mode pointer counted from thirty-two bit physical
  *  address.
- *  Returns 0 if unconvertible, 1 if successfuly converted.
+ *  Returns 0 if inconvertible, 1 if successfuly converted.
 .set PHYS_PTR_ARG,   4
diff --git a/cpukit/score/cpu/i386/rtems/score/i386.h b/cpukit/score/cpu/i386/rtems/score/i386.h
index 926627d..875526a 100644
--- a/cpukit/score/cpu/i386/rtems/score/i386.h
+++ b/cpukit/score/cpu/i386/rtems/score/i386.h
@@ -185,10 +185,14 @@ void *i386_Physical_to_logical(
   void           *address
- *  i386_Real_to_physical
+ * @brief Converts real mode pointer {segment, offset} to physical address.
+ * i386_Real_to_physical
- *  Converts real mode pointer {segment, offset} to physical address.
+ * @param[in] segment used with \p offset to compute physical address
+ * @param[in] offset used with \p segment to compute physical address
+ * @retval    physical address
 RTEMS_INLINE_ROUTINE void *i386_Real_to_physical(
     uint16_t segment,
@@ -197,19 +201,24 @@ RTEMS_INLINE_ROUTINE void *i386_Real_to_physical(
     return (void *)(((uint32_t)segment<<4)+offset);
- *  i386_Physical_to_real
- *  Retreives real mode pointer elements {segmnet, offset} from physical address
- *  Function returns the highest segment (base) address possible.
- *  Example:    input   address - 0x4B3A2
- *              output  segment - 0x4B3A
- *                      offset  - 0x2
- *              input   address - 0x10F12E
- *              output  segment - 0xFFFF
- *                      offset  - 0xF13E
+ * @brief Retreives real mode pointer elements {segmnet, offset} from
+ * physical address.
+ * i386_Physical_to_real
+ * Function returns the highest segment (base) address possible.
+ * Example:    input   address - 0x4B3A2
+ *             output  segment - 0x4B3A
+ *                     offset  - 0x2
+ *             input   address - 0x10F12E
+ *             output  segment - 0xFFFF
+ *                     offset  - 0xF13E
- *  return  0 address not convertible, must be less than 0x10FFEF
- *          1 segment and offset extracted
+ * @param[in]  address address to be converted, must be less than 0x10FFEF
+ * @param[out] segment segment computed from \p address
+ * @param[out] offset offset computed from \p address
+ * @retval  0 address not convertible
+ * @retval  1 segment and offset extracted
 int i386_Physical_to_real(
   void *address,
1.9.1
