[PATCH 3/3] doxygen: expand specified compiler macros to empty string, so they are ignored by doxygen
Thu Dec 4 03:26:01 UTC 2014
These 3 OK by me. I'll try to commit tomorrow if no one complains.
-Gedare
On Wed, Dec 3, 2014 at 6:56 PM, Jan Dolezal <dolezj21 at fel.cvut.cz> wrote:
>  cpukit/Doxyfile.in | 7 ++++---
>  1 file changed, 4 insertions(+), 3 deletions(-)
> diff --git a/cpukit/Doxyfile.in b/cpukit/Doxyfile.in
> index 4a6ee55..e4b681f 100644
> --- a/cpukit/Doxyfile.in
> +++ b/cpukit/Doxyfile.in
> @@ -1267,13 +1267,13 @@ ENABLE_PREPROCESSING   = YES
>  # compilation will be performed. Macro expansion can be done in a controlled
>  # way by setting EXPAND_ONLY_PREDEF to YES.
> -MACRO_EXPANSION        = NO
> +MACRO_EXPANSION        = YES
>  # If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES
>  # then the macro expansion is limited to the macros specified with the
>  # PREDEFINED and EXPAND_AS_DEFINED tags.
> -EXPAND_ONLY_PREDEF     = NO
> +EXPAND_ONLY_PREDEF     = YES
>  # If the SEARCH_INCLUDES tag is set to YES (the default) the includes files
>  # in the INCLUDE_PATH (see below) will be search if a #include is found.
> @@ -1305,7 +1305,8 @@ PREDEFINED             = FALSE=0 \
>                           CPU_USE_GENERIC_BITFIELD_DATA=0 \
>                           __attribute__(x)= \
>                           RTEMS_COMPILER_NO_RETURN_ATTRIBUTE= \
> -                         RTEMS_COMPILER_DEPRECATED_ATTRIBUTE=
> +                         RTEMS_COMPILER_DEPRECATED_ATTRIBUTE= \
> +                         RTEMS_COMPILER_PACKED_ATTRIBUTE=
>  # If the MACRO_EXPANSION and EXPAND_ONLY_PREDEF tags are set to YES then
>  # this tag can be used to specify a list of macro names that should be expanded.
> 1.9.1
> devel mailing list
> devel at rtems.org
