[PATCH v2] libmisc: More useful default configuration
Thu Dec 4 07:35:37 UTC 2014
On 4/12/2014 6:31 pm, Sebastian Huber wrote:
>> Ah of course. Why not move the bspinit.c one into the cpukit and use
>> that rather than add another copy ?
> Should we really initialize the network by default?
No and I feel that should do from bspinit.c.
>>> If you look at the README file in the
>>> dummy directory, then I am not sure if we should rename this file.
>> It also says it should never run and your commit comment says
>> otherwise. This has been confusing me.
> Ok, is someone using this dummy.c as described in this README?  I think
> this dummy.c file name very confusing, but I don't want to break
> existing scripts in the wild.
Many things have changed and the README does clearly state its intent.
It was added to allow configure to link as being cross-compiled the
results are never run.
