[PATCH] libmisc: More useful default configuration
Thu Dec 4 08:39:56 UTC 2014
The dummy.c was a de-facto default configuration.  Rename it to
default-configuration.c.  Use unlimited objects and the stack checker.
This makes it easier for new RTEMS users which will likely use this file
if they just work with the usual main() function as the application
entry point.  Provide proper arguments for main() using the BSP command
line.  Add spare user extensions and drivers.
Do not initialize the network by default.  Delete bspinit.c.
 c/src/lib/libbsp/Makefile.am                       |   2 +-
 c/src/lib/libbsp/i386/pc386/Makefile.am            |   1 -
 c/src/lib/libbsp/m68k/mcf5235/Makefile.am          |   2 +-
 c/src/lib/libbsp/shared/bspinit.c                  |  98 -------------------
 c/src/lib/libbsp/sparc/erc32/Makefile.am           |   1 -
 c/src/lib/libbsp/sparc/leon2/Makefile.am           |   1 -
 c/src/lib/libbsp/sparc/leon3/Makefile.am           |   2 +-
 cpukit/libmisc/Makefile.am                         |   5 +-
 cpukit/libmisc/dummy/README                        |  23 -----
 cpukit/libmisc/dummy/default-configuration.c       | 105 +++++++++++++++++++++
 cpukit/libmisc/dummy/dummy.c                       |  38 --------
 testsuites/libtests/Makefile.am                    |   1 +
 testsuites/libtests/configure.ac                   |   1 +
 testsuites/libtests/defaultconfig01/Makefile.am    |  19 ++++
 .../libtests/defaultconfig01/defaultconfig01.doc   |  11 +++
 .../libtests/defaultconfig01/defaultconfig01.scn   |   2 +
 testsuites/libtests/defaultconfig01/init.c         |  59 ++++++++++++
 17 files changed, 202 insertions(+), 169 deletions(-)
 delete mode 100644 c/src/lib/libbsp/shared/bspinit.c
 delete mode 100644 cpukit/libmisc/dummy/README
 create mode 100644 cpukit/libmisc/dummy/default-configuration.c
 delete mode 100644 cpukit/libmisc/dummy/dummy.c
 create mode 100644 testsuites/libtests/defaultconfig01/Makefile.am
 create mode 100644 testsuites/libtests/defaultconfig01/defaultconfig01.doc
 create mode 100644 testsuites/libtests/defaultconfig01/defaultconfig01.scn
 create mode 100644 testsuites/libtests/defaultconfig01/init.c
diff --git a/c/src/lib/libbsp/Makefile.am b/c/src/lib/libbsp/Makefile.am
index ac64f37..3cab4d7 100644
--- a/c/src/lib/libbsp/Makefile.am
+++ b/c/src/lib/libbsp/Makefile.am
@@ -6,7 +6,7 @@ DIST_SUBDIRS = @libbsp_cpu_subdir@
 EXTRA_DIST = MERGE.PROCEDURE bsp.am
 # shared
-EXTRA_DIST += shared/bootcard.c shared/bspclean.c shared/bspinit.c \
+EXTRA_DIST += shared/bootcard.c shared/bspclean.c \
     shared/bsplibc.c shared/bsppost.c shared/console-polled.c \
     shared/console.c shared/gnatinstallhandler.c shared/sbrk.c \
     shared/tod.c
diff --git a/c/src/lib/libbsp/i386/pc386/Makefile.am b/c/src/lib/libbsp/i386/pc386/Makefile.am
index 391bfa9..42b0279 100644
--- a/c/src/lib/libbsp/i386/pc386/Makefile.am
+++ b/c/src/lib/libbsp/i386/pc386/Makefile.am
@@ -147,7 +147,6 @@ libbsp_a_SOURCES += ../../i386/shared/irq/idt.c
 libbsp_a_SOURCES += ../../i386/shared/irq/irq.c
 libbsp_a_SOURCES += ../../i386/shared/irq/irq_init.c
 libbsp_a_SOURCES += ../../shared/bootcard.c
-libbsp_a_SOURCES += ../../shared/bspinit.c
 libbsp_a_SOURCES += ../../shared/sbrk.c
 libbsp_a_SOURCES += startup/ldsegs.S
 libbsp_a_SOURCES += ../../i386/shared/irq/irq_asm.S
diff --git a/c/src/lib/libbsp/m68k/mcf5235/Makefile.am b/c/src/lib/libbsp/m68k/mcf5235/Makefile.am
index f24d830..e551d29 100644
--- a/c/src/lib/libbsp/m68k/mcf5235/Makefile.am
+++ b/c/src/lib/libbsp/m68k/mcf5235/Makefile.am
@@ -32,7 +32,7 @@ libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsppredriverhook.c \
     startup/bspgetcpuclockspeed.c ../../shared/bsppretaskinghook.c \
     ../../shared/bspgetworkarea.c startup/init5235.c startup/bspstart.c \
     ../../shared/bootcard.c ../../shared/sbrk.c ../../shared/setvec.c \
-    ../../shared/gnatinstallhandler.c ../../shared/bspinit.c \
+    ../../shared/gnatinstallhandler.c \
     startup/copyvectors.c
 # clock
 libbsp_a_SOURCES += clock/clock.c ../../../shared/clockdrv_shell.h
diff --git a/c/src/lib/libbsp/shared/bspinit.c b/c/src/lib/libbsp/shared/bspinit.c
deleted file mode 100644
index b524389..0000000
--- a/c/src/lib/libbsp/shared/bspinit.c
+++ /dev/null
@@ -1,98 +0,0 @@
- *  COPYRIGHT (c) 1989-2009.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#include <stdlib.h>
-#include <string.h>
-#include <bsp.h>
-#include <bsp/bootcard.h>
-#ifdef RTEMS_NETWORKING
-  #include <rtems/rtems_bsdnet.h>
-#endif
- *  Necessary prototypes
-rtems_task Init (rtems_task_argument arg);
-int main (int argc, char* argv[]);
- * This routine calls main from a confdefs.h default Init task
- * set up. The bootcard will provide the task argument as
- * command line string (ASCIIZ).
-  const char* boot_cmdline = *((const char**) arg);
-  char*       cmdline = 0;
-  char*       command;
-  int         argc = 0;
-  char**      argv = NULL;
-  int         result = -124;
-  if (boot_cmdline) {
-    cmdline = malloc (strlen (boot_cmdline) + 1);
-    if (cmdline) {
-      strcpy (cmdline, boot_cmdline);
-      command = cmdline;
-       * Break the line up into arguments with "" being ignored.
-      while (true) {
-        command = strtok (command, " \t\r\n");
-        if (command == NULL)
-          break;
-        argc++;
-        command = '\0';
-       * If there are arguments, allocate enough memory for the argv
-       * array to be passed into main().
-       * NOTE: If argc is 0, then argv will be NULL.
-      argv = calloc (argc, sizeof (char*));
-      if (argv) {
-        int a;
-        argv[0] = command;
-        for (a = 1; a < argc; a++) {
-          command += strlen (command) + 1;
-          argv[a] = command;
-      } else
-        argc = 0;
-  rtems_bsdnet_initialize_network ();
-#endif
-  result = main (argc, argv);
-  free (argv);
-  free (cmdline);
-  exit (result);
- * By making this a weak alias and a user can provide there own.
-void Init (rtems_task_argument arg) __attribute__ ((weak));
diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
index 00e398b..c99d2fb 100644
--- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
+++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
@@ -36,7 +36,6 @@ libbsp_a_SOURCES += ../../sparc/shared/bsppretaskinghook.c
 libbsp_a_SOURCES += ../../shared/bsppost.c
 libbsp_a_SOURCES += ../../shared/bspstart.c
 libbsp_a_SOURCES += startup/setvec.c
 libbsp_a_SOURCES += startup/spurious.c
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index ac6f327..d1e3817 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -57,7 +57,6 @@ libbsp_a_SOURCES += ../../shared/sbrk.c
 libbsp_a_SOURCES += startup/bspidle.c
 libbsp_a_SOURCES += startup/bspdelay.c
 libbsp_a_SOURCES += ../../sparc/shared/startup/early_malloc.c
 libbsp_a_SOURCES += ../../sparc/shared/startup/bsp_fatal_exit.c
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index c5c9b77..c894095 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -39,7 +39,7 @@ libbsp_a_SOURCES += ../../shared/bsplibc.c \
     ../../sparc/shared/startup/bspgetworkarea.c ../../shared/sbrk.c \
     startup/setvec.c \
     startup/spurious.c startup/bspidle.S startup/bspdelay.c \
-    ../../shared/bspinit.c ../../sparc/shared/startup/early_malloc.c
+    ../../sparc/shared/startup/early_malloc.c
 libbsp_a_SOURCES += startup/cpucounter.c
 libbsp_a_SOURCES += startup/bsp_fatal_halt.c
diff --git a/cpukit/libmisc/Makefile.am b/cpukit/libmisc/Makefile.am
index 209b46d..8fc208f 100644
--- a/cpukit/libmisc/Makefile.am
+++ b/cpukit/libmisc/Makefile.am
@@ -35,11 +35,8 @@ noinst_LIBRARIES += libdevnull.a
 libdevnull_a_SOURCES = devnull/devnull.c devnull/devnull.h \
     devnull/devzero.c devnull/devzero.h
-## dummy
-EXTRA_DIST += dummy/README
 noinst_LIBRARIES += libdummy.a
-libdummy_a_SOURCES = dummy/dummy.c dummy/dummy-networking.c
+libdummy_a_SOURCES = dummy/default-configuration.c dummy/dummy-networking.c
 ## dumpbuf
 noinst_LIBRARIES += libdumpbuf.a
diff --git a/cpukit/libmisc/dummy/README b/cpukit/libmisc/dummy/README
index 03bb308..0000000
--- a/cpukit/libmisc/dummy/README
+++ /dev/null
@@ -1,23 +0,0 @@
-dummy.rel
-A relocatible objects which contains a dummy configuration for RTEMS.
-Helps linking standard c-program code with RTEMS, which shall *not* be run
-on a target, such as configure script code fragments generated by autoconf's
-AC_TRY_LINK.
-Example:
-tar xzvf somepkg.tar.gz
-cd somepkg
-LDFLAGS=/usr/local/rtems/<cpu>-rtems/<bsp>/lib/dummy.rel \
-CC="<cpu>-rtems-gcc \
--B/usr/local/rtems/<cpu>-rtems/<bsp>/lib/ -specs bsp_specs -qrtems" \
-CC_FOR_BUILD="gcc" \
-configure --host=<cpu>-rtems --build=i686-pc-linux-gnu
-make
-History:
-Starting dummy.c with a copy of rtems-19990528/c/src/tests/samples/minimum/init.c
diff --git a/cpukit/libmisc/dummy/default-configuration.c b/cpukit/libmisc/dummy/default-configuration.c
new file mode 100644
index 0000000..ff04a74
--- /dev/null
+++ b/cpukit/libmisc/dummy/default-configuration.c
@@ -0,0 +1,105 @@
+ *  Default configuration file
+ *  COPYRIGHT (c) 1989-2008.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <stdlib.h>
+#include <rtems.h>
+int main( int argc, char **argv );
+static void Init( rtems_task_argument arg )
+  const char *boot_cmdline = *((const char **) arg);
+  char       *cmdline = NULL;
+  int         argc = 0;
+  char      **argv = NULL;
+  int         result;
+  if ( boot_cmdline != NULL ) {
+    size_t n = strlen( boot_cmdline ) + 1;
+    cmdline = malloc( n );
+    if ( cmdline != NULL ) {
+      char* command;
+      memcpy( cmdline, boot_cmdline, n);
+      command = cmdline;
+       * Break the line up into arguments with "" being ignored.
+      while ( true ) {
+        command = strtok( command, " \t\r\n" );
+        if ( command == NULL )
+          break;
+        ++argc;
+        command = '\0';
+       * If there are arguments, allocate enough memory for the argv
+       * array to be passed into main().
+       * NOTE: If argc is 0, then argv will be NULL.
+      argv = calloc( argc, sizeof( *argv ) );
+      if ( argv != NULL ) {
+        int a;
+        argv[ 0 ] = command;
+        for ( a = 1; a < argc; ++a ) {
+          command += strlen( command ) + 1;
+          argv[ a ] = command;
+      } else {
+        argc = 0;
+  result = main( argc, argv );
+  free( argv );
+  free( cmdline );
+  exit( result );
+/* configuration information */
+/* This is enough to get a basic main() up. */
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_UNIFIED_WORK_AREAS
+#define CONFIGURE_UNLIMITED_OBJECTS
+#define CONFIGURE_STACK_CHECKER_ENABLED
+#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 8
+#define CONFIGURE_MAXIMUM_DRIVERS 16
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 32
+/* Include basic device drivers needed to call delays */
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_DISABLE_BSP_SETTINGS
+#define CONFIGURE_INIT
+#include <rtems/confdefs.h>
diff --git a/cpukit/libmisc/dummy/dummy.c b/cpukit/libmisc/dummy/dummy.c
index 839a556..0000000
--- a/cpukit/libmisc/dummy/dummy.c
+++ /dev/null
@@ -1,38 +0,0 @@
- *  Dummy configuration file
- *  COPYRIGHT (c) 1989-2008.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <rtems.h>
-int main( int, char **, char **);
-/* configuration information */
-/* This is enough to get a basic main() up. */
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_MAXIMUM_TASKS 10
-#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
-#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
-#define CONFIGURE_INIT_TASK_ENTRY_POINT   (void *)main
-/* Include basic device drivers needed to call delays */
-#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_DISABLE_BSP_SETTINGS
-#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index 4f22ac8..ed773c4 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -1,6 +1,7 @@
 ACLOCAL_AMFLAGS = -I ../aclocal
 _SUBDIRS = POSIX
+_SUBDIRS += defaultconfig01
 _SUBDIRS += pwdgrp02
 _SUBDIRS += shell01
 _SUBDIRS += pwdgrp01
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index 53a017b..39e518f 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -67,6 +67,7 @@ AM_CONDITIONAL(DLTESTS,[test x"$TEST_LIBDL" = x"yes"])
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile
+defaultconfig01/Makefile
 pwdgrp02/Makefile
 shell01/Makefile
 pwdgrp01/Makefile
diff --git a/testsuites/libtests/defaultconfig01/Makefile.am b/testsuites/libtests/defaultconfig01/Makefile.am
index 0000000..ffa894ab
--- /dev/null
+++ b/testsuites/libtests/defaultconfig01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = defaultconfig01
+defaultconfig01_SOURCES = init.c
+dist_rtems_tests_DATA = defaultconfig01.scn defaultconfig01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(defaultconfig01_OBJECTS)
+LINK_LIBS = $(defaultconfig01_LDLIBS)
+defaultconfig01$(EXEEXT): $(defaultconfig01_OBJECTS) $(defaultconfig01_DEPENDENCIES)
+	@rm -f defaultconfig01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/libtests/defaultconfig01/defaultconfig01.doc b/testsuites/libtests/defaultconfig01/defaultconfig01.doc
index 0000000..5322453
--- /dev/null
+++ b/testsuites/libtests/defaultconfig01/defaultconfig01.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: defaultconfig01
+directives:
+  - main()
+concepts:
+  - Make sure the default configuration works.
diff --git a/testsuites/libtests/defaultconfig01/defaultconfig01.scn b/testsuites/libtests/defaultconfig01/defaultconfig01.scn
index 0000000..6f140ea
--- /dev/null
+++ b/testsuites/libtests/defaultconfig01/defaultconfig01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST DEFAULTCONFIG 1 ***
+*** END OF TEST DEFAULTCONFIG 1 ***
diff --git a/testsuites/libtests/defaultconfig01/init.c b/testsuites/libtests/defaultconfig01/init.c
index 0000000..21c326d
--- /dev/null
+++ b/testsuites/libtests/defaultconfig01/init.c
@@ -0,0 +1,59 @@
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+  #include "config.h"
+#endif
+#include <stdio.h>
+#include <bsp.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "DEFAULTCONFIG 1";
+static void install_bsp_extension(void)
+#ifdef BSP_INITIAL_EXTENSION
+  static const rtems_extensions_table bsp_ext = BSP_INITIAL_EXTENSION;
+  rtems_status_code sc;
+  rtems_id id;
+  sc = rtems_extension_create(
+    rtems_build_name('B', 'S', 'P', ' '),
+    &bsp_ext,
+    &id
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+#endif
+int main(int argc, char **argv)
+  int i;
+  TEST_BEGIN();
+  install_bsp_extension();
+  for (i = 0; i < argc; ++i) {
+    printf("argv[%i] = %s\n", i, argv[i]);
+  TEST_END();
+  return 0;
1.8.4.5
