[PATCH] rtems: Change GCC vendor message
Thu Dec 4 13:03:31 UTC 2014
Drop the GCC version since this is already part of the normal GCC
version message.  Drop the release number from the RSB since the Git
commit identifies the RSB version uniquely.  Use a "Name Version, ..."
pattern.
 rtems/config/rtems-base.bset | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/rtems/config/rtems-base.bset b/rtems/config/rtems-base.bset
index 704d66f..1c4b724 100644
--- a/rtems/config/rtems-base.bset
+++ b/rtems/config/rtems-base.bset
@@ -15,7 +15,7 @@ package: rtems-%{rtems_version}-%{_target}-%{release}
 # Project custom message
-%define gcc_version_message RTEMS %{rtems_version}-RSB-%{_sbgit_id}-%{release},gcc-%{gcc_version}/newlib-%{newlib_version}
+%define gcc_version_message RTEMS %{rtems_version}, RSB %{_sbgit_id}, Newlib %{newlib_version}
 # Pick up the RTEMS URLs.
1.8.4.5
