[rtems commit] nfsclient: Avoid __FILE__ and __LINE__
Gedare Bloom
gedare at rtems.org
Fri Dec 5 13:49:04 UTC 2014
Should we avoid these macros in general, and say so in coding conventions?
On Fri, Dec 5, 2014 at 7:10 AM, Sebastian Huber <sebh at rtems.org> wrote:
> Module: rtems
> Branch: master
> Commit: b657ea4d33ca47d1bf714906ecc4073c1441c620
> Changeset: http://git.rtems.org/rtems/commit/?id=b657ea4d33ca47d1bf714906ecc4073c1441c620
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date: Fri Dec 5 13:05:34 2014 +0100
> The __FILE__ prevents reproducible builds.
> cpukit/libfs/src/nfsclient/src/rpcio.c | 4 +---
> 1 file changed, 1 insertion(+), 3 deletions(-)
> diff --git a/cpukit/libfs/src/nfsclient/src/rpcio.c b/cpukit/libfs/src/nfsclient/src/rpcio.c
> index 07bd9a3..286caa7 100644
> --- a/cpukit/libfs/src/nfsclient/src/rpcio.c
> +++ b/cpukit/libfs/src/nfsclient/src/rpcio.c
> @@ -1348,9 +1348,7 @@ rtems_status_code status;
> fprintf(stderr,"RPCIO XACT timed out; waking up requestor\n");
> #endif
> if ( rtems_event_send(xact->requestor, RTEMS_RPC_EVENT) ) {
> - rtems_panic("RPCIO PANIC file %s line: %i, requestor id was 0x%08x",
> - __FILE__,
> - __LINE__,
> + rtems_panic("RPCIO PANIC: requestor id was 0x%08x",
> xact->requestor);
> vc mailing list
> vc at rtems.org
> http://lists.rtems.org/mailman/listinfo/vc
