RTEMS SMP configuration
    Hesham Moustafa
    heshamelmatary at gmail.com
    Sat Dec  6 20:56:01 UTC 2014
Hi,
Thanks Joel and Gedare. I found it a bit tricky as I had to add
epiphany to (hidden) aclocal/enable-smp.m4 files at c/src, cpukit and
the root directory. It now builds and compiles fine, and actually I
can send some SMP messages to RTEMS on another core, but the current
status of SMP/epiphany port is in its very early stages, and need more
work.
Regards,
Hesham
On Fri, Dec 5, 2014 at 10:31 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On December 5, 2014 2:40:59 PM CST, Hesham Moustafa <heshamelmatary at gmail.com> wrote:
>>On Fri, Dec 5, 2014 at 8:36 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>> Look for where the undefined functions exist and see what guards in
>>> the build system or the source code itself might be precluding them
>>> from your build.
>>Most of SMP files are guarded with HAS_SMP and RTEMS_SMP. I always run
>>boostrap -p and bootstrap after every change and configure/build
>>again.
>>> Make sure you re-bootstrap and re-configure a clean build, as old
>>> files might cause problems.
> Reference the SPARC leon3 bsp and keep good notes. They can be vetted against documentation or become it.
> The SMP wiki page may have hints as well.
>>> -Gedare
>>> On Fri, Dec 5, 2014 at 3:09 PM, Hesham Moustafa
>>>> It seems like adding an entry for epiphany at aclocal/enable-smp.m4
>>is
>>>> not enough, I still get the same error, any hints?
>>>> On Fri, Dec 5, 2014 at 6:03 PM, Hesham Moustafa
>>>>> I had to add epiphany to the list RTEMS CPUs that support SMP at
>>>>> On Fri, Dec 5, 2014 at 5:06 PM, Hesham Moustafa
>>>>>> Hi,
>>>>>> Should I add anything other than --enable-smp at configuration
>>line
>>>>>> and RTEMS_CHECK_SMP
>>>>>> AM_CONDITIONAL(HAS_SMP,[test "$rtems_cv_HAS_SMP" = "yes"])
>>>>>> to bsp configure.ac file to make the building system collects SMP
>>>>>> files (e.g, smpimpl.h). I always get undefined reference to some
>>SMP
>>>>>> functions like _SMP_Send_message although I am including
>>>>>> <rtems/score/smpimpl.h>
>>>>>> Thanks,
>>>>>> Hesham
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
>>devel mailing list
>>devel at rtems.org
> --joel
