[PATCH] Teach rtems_tarfs_load() about symlinks
Nick Withers
nick.withers at anu.edu.au
Wed Dec 10 05:34:06 UTC 2014
On Wed, 2014-12-03 at 08:23 +0100, Sebastian Huber wrote:
> On 03/12/14 07:07, Nick Withers wrote:
> > Anyone be interested in committing this?
> > On Fri, 2014-03-07 at 14:37 +1100, Nick Withers wrote:
> > > > Hi all,
> > > > The attached patch teaches rtems_tarfs_load() about symlinks, as well as
> > > > making it fail if it encounters an unsupported tar file entry type
> > > > (e.g., hard links) rather than silently ignoring the 512 B block.
> > > > It tries to be consistent with the existing code which doesn't e.g.
> > > > check tar string field NUL termination or printf() on error.
> > -- Nick Withers Embedded Systems Programmer Department of Nuclear
> > Physics, Research School of Physics and Engineering The Australian
> > National University (CRICOS: 00120C)
> > rtems_tarfs_load_symlinks.patch
> > >From 165b5fd7e0c2d5042a69d209a360522f80697d71 Mon Sep 17 00:00:00 2001
> > From: Nick Withers <nick.withers at anu.edu.au>
> > Date: Fri, 7 Mar 2014 14:23:30 +1100
> > Subject: [PATCH] Teach rtems_tarfs_load() about symlinks
> > rtems_tarfs_load() will now also fail if it encounters unsupported tar file entry types (e.g., hard links)
> I am not sure if this should now fail if it encounters an unsupported
> tar file entry. This may crash applications that worked for a long
> time.
Here's a version that doesn't fail like this.
<Discussion>
Personally, I'd much rather it did (for example, as I recall, there's
nothing to say that an unsupported entry only occupies one block, so you
could be stuffed anyway) and would think it would be an obvious failure
if you're checking the return code. If you're not, I have no sympathy
for you :-P
I also think that people porting an existing app to RTEMS 4.11 should be
a) not releasing until RTEMS 4.11 itself is finalised OR accepting the
potential for breakage working off off the moving HEAD target and b)
testing thoroughly.
But hey - I don't have to deal with upset users!
</Discussion>
Nick Withers
Department of Nuclear Physics, Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141210/3f0cc7a5/attachment-0001.bin>
