[PATCH] Correct a race condition between the e500 core decrementer wrapping and the tick interrupt being handled
Fri Dec 12 07:02:14 UTC 2014
On 12/12/14 03:18, Nick Withers wrote:
> On Wed, 2014-12-10 at 08:42 +0100, Sebastian Huber wrote:
>> On 10/12/14 02:53, Nick Withers wrote:
>>> On Wed, 2014-12-03 at 08:09 +0100, Sebastian Huber wrote:
>>>> Hello Nick,
>>>> to disable TCR[ARE] is not the right fix.  You have to check the
>>>> TSR[DIS] register in the nanoseconds extension.  See for example
>>>> lpc-clock-config.c for an example.
>>> Hi Sebastian,
>>> Thanks for your help, 'fraid I need to lean on you a little more...
>>> I don't understand how the proposed solution (or that in
>>> lpc-clock-config.c) can work properly in the case where the nanoseconds
>>> extension could be queried multiple times with an interrupt lock held
>>> (which I believe disables interrupts), preventing the tick from being
>>> incremented, as I believe happens in spnsext01.
>>> lpc-clock-config.c's lpc_clock_nanoseconds_since_last_tick(), if I'm
>>> understanding it correctly, says "Ah, there's an interrupt pending, so
>>> we need to add another tick period to our current timer value". Cool
>>> bananas.
>> Yes, this is exactly how it works.
>>> But what if it's called again with the same interrupt still
>>> pending? The timer counter may have wrapped again and we could return an
>>> earlier time.
>>> ...Couldn't we? What am I missing?
>>> Cheers :-)
>> If you disable interrupts for more than one clock tick interval, then
>> you have a bigger problem than a non-monotonic uptime.
> Yeah, that's probably fair...
>> If you disable the auto-reload, then the decrementer stops, so you have
>> a time freeze.
> I suppose that didn't worry me as much as non-monotonic time. Probably
> because I'm a selfish so-and-so and not personally writing a real-time
> application with strict periodic tasking requirements (and don't
> particularly care about the uptime drifting) :-P
> A new patch is attached, thanks for your help and guidance!
> It's a little more convoluted than might be necessary because I wasn't
> confident that every relevant BSP's Clock_Decrementer_value (some of
> which are set at run-time) was small enough not to overflow the uint32_t
> tmp variable in intermediate calculations if I just straight-up doubled
> the potential range of values it might need to hold (with the extra
> clock tick period that might now be returned). It potentially adds
> another run-time division this way, though. I could just use a
> uint64_t...?
Other nanoseconds extensions use a 64-bit multiplication to solve this
issue.  It is quite fast in contrast to a 64-bit division which is a no-go.
> P.S.: For my education (because noone has anything better to do,
> right?)... Is there a more general solution? Maybe servicing the tick
> increment in the nanoseconds call if an interrupt's been generated (is
> servicing an interrupt out-of-band "usually" legitimate across
> architectures / PICs?) but deferring e.g. scheduling 'til interrupts're
> re-enabled?
> If not, I guess it should be guaranteeable / assumable that interrupts
> should never be blocked for longer than x cycles (when users can't
> disable them themselves)?
> Would the FreeBSD clock code you mentioned earlier handle it any better?
Yes, there is a better solution: the FreeBSD timecounter.  We currently
try to get some budget to port this to RTEMS and update all BSPs
providing the nanoseconds extension.
> P.P.S.: Clock_driver_nanoseconds_since_last_tick() also seems broken in
> the non-Book-E case if the decrementer value is (one's complement)
> negative
The decrementer based clock tick is broken in general since it doesn't
respect the priorities of the interrupt controller.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
