[PATCH 2/2] doc: Clarify rate-monotonic statistics
Fri Dec 12 14:22:16 UTC 2014
On 12/12/14 15:10, Joel Sherrill wrote:
> On December 12, 2014 8:04:39 AM CST, Sebastian Huber<sebastian.huber at embedded-brains.de>  wrote:
>> >doc/user/rtmon.t | 18 ++++++++++++++----
>> >1 file changed, 14 insertions(+), 4 deletions(-)
>> >diff --git a/doc/user/rtmon.t b/doc/user/rtmon.t
>> >index 7786e76..92f6b0b 100644
>> >--- a/doc/user/rtmon.t
>> >+++ b/doc/user/rtmon.t
>> >@@ -52,10 +52,10 @@ A clock tick is required to support the
>> >functionality provided by this manager.
>> >@subsection Period Statistics
>> >-This manager maintains a set of statistics on each period.  These
>> >-statistics are reset implictly at period creation time and may be
>> >-reset or obtained at any time by the application.  The following
>> >-is a list of the information kept:
>> >+This manager maintains a set of statistics on each period object.
>> >These
>> >+statistics are reset implictly at period creation time and may be
>> >reset or
>> >+obtained at any time by the application.  The following is a list of
>> >the
>> >+information kept:
> I am not spotting the language change in this.
From
to
>> >@itemize @bullet
>> >@item @code{owner}
>> >@@ -93,6 +93,16 @@ during executions of the periodic loop.
>> >@end itemize
>> >+Each period is divided into two consecutive phases.  The period starts
>> >with the
>> >+active phase of the task and is followed by the inactive phase of the
>> >task.  In
>> >+the inactive phase the task is blocked and waits for the start of the
>> >next
>> >+period.  The inactive phase is skipped in case of a period miss.  The
>> >wall time
>> >+includes the time during the active phase of the task on which the
>> >task is not
>> >+executing on a processor.  The task may be blocked waiting for a
>> >resource or a
>> >+higher priority task executes instead.  In case the wall time exceeds
> The or a phrase seems like it cod be worded better.
Sorry, what do you mean?
>> >the
>> >+period time, then this is a period miss.  So the gap between the
>> >maximum wall
>> >+time and the period time is the safety margin between a period miss or
>> >success.
> Don't use So.
> I wouldn't call it a safety margin. Just a margin.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
