Updating Open Projects and GSOC
Sun Dec 14 13:44:51 UTC 2014
On December 13, 2014 9:47:00 PM CST, Gedare Bloom <gedare at rtems.org> wrote:
>I'd like to see RTEMS compile with LLVM  / clang. This would go a long
>way toward improving our static analysis capabilities. The project
>should get RTEMS compiling, and add support in RSB for it.
I added basic RTEMS target support to LLVM a few years ago. Eliminating the use of bsp_specs is the big hurdle
>I'm lukewarm on Coverity-Newlib. The other projects seem alright. I'll
>try to take a stab at the Open Projects page in the near future, after
>I can give some more thought to good projects.
Not gsoc worthy. Just on the to do list. I almost have it working but can't quite get the Coverity set up correct.
As a gsoc project, I would like coverage testing on newlib using glibc and any BSD libc tests we can leverage.
>-Gedare
>On Sat, Dec 13, 2014 at 10:58 AM, Joel Sherrill
><joel.sherrill at oarcorp.com> wrote:
>> Hi
>> Google Summer of Code 2014 has wrapped up and the 2015
>> edition is already committed to by Google. I would
>> like folks to take a little while to update pages
>> and add any new ideas. A few off my wish list in no
>> particular order:
>> + More Pi peripherals
>>   - includes TCP/IP over USB
>> + BeagleBoard Ethernet
>> + rtems-tester support for more simulators
>> + complete rtems-tester coverage support
>>   - started in ESA SOCIS
>> + more RSB recipes
>>   - specifically eliminate RTEMS Addon Packages
>>     and as much of the Graphics Toolkit as possible
>>     with RSB recipes
>> + Monkey HTTPD port
>> + capture engine, trace wrapper generator, and
>>   LTTng integration via CTF. Allows visualization
>>   of timelines
>> + Coverity runs on newlib. I started this but can't
>>   get it to work so far. :(
>> I am sure there are other ideas. Please add to the
>> list and help write them up.
>> --joel
>> devel mailing list
>> devel at rtems.org
Sent from my Android device with K-9 Mail. Please excuse my brevity.
