[PATCH 1/2] RTEMS: Rename ARM target config files
Mon Dec 15 09:23:48 UTC 2014
Now that we only have the EABI configuration for RTEMS rename the files
to match the pattern used for the other RTEMS targets.
This patch should be applied to GCC mainline.  I do not have write
access, so in case this gets approved, please commit it for me.
gcc/ChangeLog
2014-12-15  Sebastian Huber  <sebastian.huber at embedded-brains.de>
	* config/arm/t-rtems-eabi: Rename to...
	* config/arm/t-rtems: ...this.
	* config/arm/rtems-eabi.h: Rename to...
	* config/arm/rtems.h: ...this.
	* config.gcc (arm*-*-rtems*): Reflect changes above.
 gcc/config.gcc              |   4 +-
 gcc/config/arm/rtems-eabi.h |  29 --------
 gcc/config/arm/rtems.h      |  29 ++++++++
 gcc/config/arm/t-rtems      | 167 ++++++++++++++++++++++++++++++++++++++++++++
 gcc/config/arm/t-rtems-eabi | 167 --------------------------------------------
 5 files changed, 198 insertions(+), 198 deletions(-)
 delete mode 100644 gcc/config/arm/rtems-eabi.h
 create mode 100644 gcc/config/arm/rtems.h
 create mode 100644 gcc/config/arm/t-rtems
 delete mode 100644 gcc/config/arm/t-rtems-eabi
diff --git a/gcc/config.gcc b/gcc/config.gcc
index 8541274..e49bcbd 100644
--- a/gcc/config.gcc
+++ b/gcc/config.gcc
@@ -1057,8 +1057,8 @@ arm*-*-eabi* | arm*-*-symbianelf* | arm*-*-rtems*)
 	  use_gcc_stdint=wrap
 	arm*-*-rtems*)
-	  tm_file="${tm_file} rtems.h arm/rtems-eabi.h newlib-stdint.h"
-	  tmake_file="${tmake_file} arm/t-bpabi arm/t-rtems-eabi"
+	  tm_file="${tm_file} rtems.h arm/rtems.h newlib-stdint.h"
+	  tmake_file="${tmake_file} arm/t-bpabi arm/t-rtems"
 	arm*-*-symbianelf*)
 	  tm_file="${tm_file} arm/symbian.h"
diff --git a/gcc/config/arm/rtems-eabi.h b/gcc/config/arm/rtems-eabi.h
deleted file mode 100644
index 4bdcf0d..0000000
--- a/gcc/config/arm/rtems-eabi.h
+++ /dev/null
@@ -1,29 +0,0 @@
-/* Definitions for RTEMS based ARM systems using EABI.
-   Copyright (C) 2011-2014 Free Software Foundation, Inc.
-   This file is part of GCC.
-   GCC is free software; you can redistribute it and/or modify it
-   under the terms of the GNU General Public License as published
-   by the Free Software Foundation; either version 3, or (at your
-   option) any later version.
-   GCC is distributed in the hope that it will be useful, but WITHOUT
-   ANY WARRANTY; without even the implied warranty of MERCHANTABILITY
-   or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public
-   License for more details.
-   You should have received a copy of the GNU General Public License
-   along with GCC; see the file COPYING3.  If not see
-   <http://www.gnu.org/licenses/>.  */
-#define HAS_INIT_SECTION
-#undef TARGET_OS_CPP_BUILTINS
-#define TARGET_OS_CPP_BUILTINS()		\
-    do {					\
-	builtin_define ("__rtems__");		\
-	builtin_define ("__USE_INIT_FINI__");	\
-	builtin_assert ("system=rtems");	\
-	TARGET_BPABI_CPP_BUILTINS();    	\
-    } while (0)
diff --git a/gcc/config/arm/rtems.h b/gcc/config/arm/rtems.h
new file mode 100644
index 0000000..4bdcf0d
--- /dev/null
+++ b/gcc/config/arm/rtems.h
@@ -0,0 +1,29 @@
+/* Definitions for RTEMS based ARM systems using EABI.
+   Copyright (C) 2011-2014 Free Software Foundation, Inc.
+   This file is part of GCC.
+   GCC is free software; you can redistribute it and/or modify it
+   under the terms of the GNU General Public License as published
+   by the Free Software Foundation; either version 3, or (at your
+   option) any later version.
+   GCC is distributed in the hope that it will be useful, but WITHOUT
+   ANY WARRANTY; without even the implied warranty of MERCHANTABILITY
+   or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public
+   License for more details.
+   You should have received a copy of the GNU General Public License
+   along with GCC; see the file COPYING3.  If not see
+   <http://www.gnu.org/licenses/>.  */
+#define HAS_INIT_SECTION
+#undef TARGET_OS_CPP_BUILTINS
+#define TARGET_OS_CPP_BUILTINS()		\
+    do {					\
+	builtin_define ("__rtems__");		\
+	builtin_define ("__USE_INIT_FINI__");	\
+	builtin_assert ("system=rtems");	\
+	TARGET_BPABI_CPP_BUILTINS();    	\
+    } while (0)
diff --git a/gcc/config/arm/t-rtems b/gcc/config/arm/t-rtems
index 0000000..92c4dcb
--- /dev/null
+++ b/gcc/config/arm/t-rtems
@@ -0,0 +1,167 @@
+# Custom RTEMS EABI multilibs
+MULTILIB_OPTIONS  = mbig-endian mthumb march=armv6-m/march=armv7-a/march=armv7-r/march=armv7-m mfpu=neon/mfpu=vfpv3-d16/mfpu=fpv4-sp-d16 mfloat-abi=hard
+MULTILIB_DIRNAMES = eb thumb armv6-m armv7-a armv7-r armv7-m neon vfpv3-d16 fpv4-sp-d16 hard
+# Enumeration of multilibs
+MULTILIB_EXCEPTIONS =
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv6-m/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv6-m/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv6-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv6-m/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-a/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-a/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-a/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-a/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-r/mfpu=neon/mfloat-abi=hard
+# MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-r/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-r/mfpu=vfpv3-d16
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-r/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-r/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-m/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-m/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-m/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mthumb/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv6-m/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv6-m/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv6-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv6-m/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-a/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-a/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-a/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-a/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-r/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-r/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-r/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-r/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-m/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-m/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-m/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mbig-endian/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/march=armv6-m/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/march=armv6-m/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/march=armv6-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/march=armv6-m/mfloat-abi=hard
+# MULTILIB_EXCEPTIONS += mthumb/march=armv6-m
+# MULTILIB_EXCEPTIONS += mthumb/march=armv7-a/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/march=armv7-a/mfpu=neon
+MULTILIB_EXCEPTIONS += mthumb/march=armv7-a/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/march=armv7-a/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/march=armv7-a/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/march=armv7-r/mfpu=neon/mfloat-abi=hard
+# MULTILIB_EXCEPTIONS += mthumb/march=armv7-r/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/march=armv7-r/mfpu=vfpv3-d16
+MULTILIB_EXCEPTIONS += mthumb/march=armv7-r/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/march=armv7-r/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/march=armv7-m/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/march=armv7-m/mfpu=vfpv3-d16/mfloat-abi=hard
+# MULTILIB_EXCEPTIONS += mthumb/march=armv7-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/march=armv7-m/mfpu=fpv4-sp-d16
+MULTILIB_EXCEPTIONS += mthumb/march=armv7-m/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mthumb/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv6-m/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv6-m/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv6-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv6-m/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv7-a/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv7-a/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv7-a/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv7-a/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv7-r/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv7-r/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv7-r/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv7-r/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv7-m/mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv7-m/mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv7-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += march=armv7-m/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mfpu=neon/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mfpu=vfpv3-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mfpu=fpv4-sp-d16/mfloat-abi=hard
+MULTILIB_EXCEPTIONS += mfloat-abi=hard
diff --git a/gcc/config/arm/t-rtems-eabi b/gcc/config/arm/t-rtems-eabi
index 92c4dcb..0000000
--- a/gcc/config/arm/t-rtems-eabi
+++ /dev/null
@@ -1,167 +0,0 @@
-# Custom RTEMS EABI multilibs
-MULTILIB_OPTIONS  = mbig-endian mthumb march=armv6-m/march=armv7-a/march=armv7-r/march=armv7-m mfpu=neon/mfpu=vfpv3-d16/mfpu=fpv4-sp-d16 mfloat-abi=hard
-MULTILIB_DIRNAMES = eb thumb armv6-m armv7-a armv7-r armv7-m neon vfpv3-d16 fpv4-sp-d16 hard
-# Enumeration of multilibs
-MULTILIB_EXCEPTIONS =
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv6-m/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv6-m/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv6-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv6-m/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-a/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-a/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-a/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-a/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-r/mfpu=neon/mfloat-abi=hard
-# MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-r/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-r/mfpu=vfpv3-d16
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-r/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-r/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-m/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-m/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/march=armv7-m/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mthumb/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv6-m/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv6-m/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv6-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv6-m/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-a/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-a/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-a/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-a/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-r/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-r/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-r/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-r/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-m/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-m/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/march=armv7-m/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mbig-endian/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/march=armv6-m/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/march=armv6-m/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/march=armv6-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/march=armv6-m/mfloat-abi=hard
-# MULTILIB_EXCEPTIONS += mthumb/march=armv6-m
-# MULTILIB_EXCEPTIONS += mthumb/march=armv7-a/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/march=armv7-a/mfpu=neon
-MULTILIB_EXCEPTIONS += mthumb/march=armv7-a/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/march=armv7-a/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/march=armv7-a/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/march=armv7-r/mfpu=neon/mfloat-abi=hard
-# MULTILIB_EXCEPTIONS += mthumb/march=armv7-r/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/march=armv7-r/mfpu=vfpv3-d16
-MULTILIB_EXCEPTIONS += mthumb/march=armv7-r/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/march=armv7-r/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/march=armv7-m/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/march=armv7-m/mfpu=vfpv3-d16/mfloat-abi=hard
-# MULTILIB_EXCEPTIONS += mthumb/march=armv7-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/march=armv7-m/mfpu=fpv4-sp-d16
-MULTILIB_EXCEPTIONS += mthumb/march=armv7-m/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mthumb/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv6-m/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv6-m/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv6-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv6-m/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv7-a/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv7-a/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv7-a/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv7-a/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv7-r/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv7-r/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv7-r/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv7-r/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv7-m/mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv7-m/mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv7-m/mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += march=armv7-m/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mfpu=neon/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mfpu=vfpv3-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mfpu=fpv4-sp-d16/mfloat-abi=hard
-MULTILIB_EXCEPTIONS += mfloat-abi=hard
1.8.4.5
