[PATCH v2] RTEMS: Add e6500 multilibs for PowerPC
Sebastian Huber
Mon Dec 15 12:14:57 UTC 2014
Use 32-bit instructions only since currenlty there is no demand for a
larger address space. Provide one multilib with FPU and AltiVec support
and one without.
This patch should be applied to GCC 4.9 and mainline. I do not have
write access, so in case this gets approved, please commit it for me.
v2: Move MULTILIB_OPTIONS += m32 to right position in the file.
gcc/ChangeLog
2014-12-15 Sebastian Huber <sebastian.huber at embedded-brains.de>
* config/rs6000/t-rtems: Add e6500 multilibs.
gcc/config/rs6000/t-rtems | 13 +++++++++----
1 file changed, 9 insertions(+), 4 deletions(-)
diff --git a/gcc/config/rs6000/t-rtems b/gcc/config/rs6000/t-rtems
index e935947..eadda0d 100644
--- a/gcc/config/rs6000/t-rtems
+++ b/gcc/config/rs6000/t-rtems
@@ -24,14 +24,17 @@ MULTILIB_MATCHES =
MULTILIB_EXCEPTIONS =
MULTILIB_REQUIRED =
-MULTILIB_OPTIONS += mcpu=403/mcpu=505/mcpu=603e/mcpu=604/mcpu=860/mcpu=7400/mcpu=8540
-MULTILIB_DIRNAMES += m403 m505 m603e m604 m860 m7400 m8540
+MULTILIB_OPTIONS += mcpu=403/mcpu=505/mcpu=603e/mcpu=604/mcpu=860/mcpu=7400/mcpu=8540/mcpu=e6500
+MULTILIB_DIRNAMES += m403 m505 m603e m604 m860 m7400 m8540 me6500
+MULTILIB_OPTIONS += m32
+MULTILIB_DIRNAMES += m32
MULTILIB_OPTIONS += msoft-float/mfloat-gprs=double
MULTILIB_DIRNAMES += nof gprsdouble
-MULTILIB_OPTIONS += mno-spe
-MULTILIB_DIRNAMES += nospe
+MULTILIB_OPTIONS += mno-spe/mno-altivec
+MULTILIB_DIRNAMES += nospe noaltivec
MULTILIB_MATCHES += ${MULTILIB_MATCHES_ENDIAN}
MULTILIB_MATCHES += ${MULTILIB_MATCHES_SYSV}
@@ -72,3 +75,5 @@ MULTILIB_REQUIRED += mcpu=8540
MULTILIB_REQUIRED += mcpu=8540/msoft-float/mno-spe
MULTILIB_REQUIRED += mcpu=8540/mfloat-gprs=double
MULTILIB_REQUIRED += mcpu=860
+MULTILIB_REQUIRED += mcpu=e6500/m32
+MULTILIB_REQUIRED += mcpu=e6500/m32/msoft-float/mno-altivec
1.8.4.5
