[PATCH] Delete CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
Sebastian Huber
Mon Dec 15 13:21:05 UTC 2014
This define was superfluous, undocumented and used inconsistently.
cpukit/libi2c/libi2c.h | 5 ++---
cpukit/libmisc/dummy/default-configuration.c | 1 -
testsuites/fstests/fsbdpart01/init.c | 2 --
testsuites/fstests/fsdosfsformat01/init.c | 2 --
testsuites/fstests/fsdosfsname01/init.c | 2 --
testsuites/fstests/fsdosfssync01/init.c | 2 --
testsuites/fstests/fsdosfswrite01/init.c | 2 --
testsuites/fstests/fsfseeko01/init.c | 2 --
testsuites/fstests/fsimfsgeneric01/init.c | 2 --
testsuites/fstests/fsrofs01/init.c | 1 -
testsuites/fstests/imfs_support/fs_support.c | 1 -
testsuites/fstests/jffs2_support/fs_support.c | 1 -
testsuites/fstests/mdosfs_support/fs_support.c | 1 -
testsuites/fstests/mimfs_support/fs_support.c | 1 -
testsuites/fstests/mrfs_support/fs_support.c | 1 -
testsuites/libtests/block01/init.c | 1 -
testsuites/libtests/block02/init.c | 2 --
testsuites/libtests/block03/init.c | 2 --
testsuites/libtests/block04/init.c | 2 --
testsuites/libtests/block05/init.c | 2 --
testsuites/libtests/block06/init.c | 2 --
testsuites/libtests/block07/init.c | 1 -
testsuites/libtests/block09/init.c | 2 --
testsuites/libtests/block10/init.c | 2 --
testsuites/libtests/block11/init.c | 1 -
testsuites/libtests/block12/init.c | 2 --
testsuites/libtests/block13/init.c | 2 --
testsuites/libtests/block14/init.c | 2 --
testsuites/libtests/block15/init.c | 2 --
testsuites/libtests/block16/init.c | 2 --
testsuites/libtests/block17/init.c | 2 --
testsuites/libtests/crypt01/init.c | 2 --
testsuites/libtests/devfs03/init.c | 1 -
testsuites/libtests/deviceio01/init.c | 2 --
testsuites/libtests/dl01/init.c | 1 -
testsuites/libtests/dl02/init.c | 1 -
testsuites/libtests/exit01/init.c | 2 --
testsuites/libtests/exit02/init.c | 2 --
testsuites/libtests/flashdisk01/init.c | 1 -
testsuites/libtests/ftp01/init.c | 1 -
testsuites/libtests/i2c01/init.c | 2 --
testsuites/libtests/md501/init.c | 2 --
testsuites/libtests/mghttpd01/init.c | 2 --
testsuites/libtests/monitor02/system.h | 1 -
testsuites/libtests/newlib01/init.c | 2 --
testsuites/libtests/pwdgrp01/init.c | 2 --
testsuites/libtests/pwdgrp02/init.c | 2 --
testsuites/libtests/sha/init.c | 2 --
testsuites/libtests/shell01/init.c | 2 --
testsuites/libtests/sparsedisk01/init.c | 1 -
testsuites/libtests/syscall01/init.c | 2 --
testsuites/libtests/tar01/init.c | 1 -
testsuites/libtests/tar02/init.c | 1 -
testsuites/libtests/utf8proc01/init.c | 2 --
testsuites/psxtests/psx13/main.c | 1 -
testsuites/psxtests/psxaio01/system.h | 1 -
testsuites/psxtests/psxaio02/system.h | 1 -
testsuites/psxtests/psxaio03/system.h | 1 -
testsuites/psxtests/psxchroot01/main.c | 1 -
testsuites/psxtests/psxfchx01/init.c | 1 -
testsuites/psxtests/psxfile01/main.c | 1 -
testsuites/psxtests/psxfile02/init.c | 1 -
testsuites/psxtests/psxmount/main.c | 1 -
testsuites/psxtests/psxpasswd01/init.c | 1 -
testsuites/psxtests/psxpasswd02/init.c | 1 -
testsuites/psxtests/psxpipe01/init.c | 1 -
testsuites/psxtests/psxrdwrv/main.c | 1 -
testsuites/psxtests/psxreaddir/main.c | 1 -
testsuites/psxtests/psxstat/main.c | 1 -
testsuites/samples/fileio/system.h | 2 --
testsuites/samples/loopback/init.c | 1 -
testsuites/sptests/spcache01/init.c | 2 --
testsuites/sptests/spcontext01/init.c | 2 --
testsuites/sptests/spfifo01/init.c | 2 --
testsuites/sptests/spfifo02/init.c | 1 -
testsuites/sptests/spfifo03/init.c | 1 -
testsuites/sptests/spfifo04/init.c | 1 -
testsuites/sptests/spfifo05/init.c | 1 -
testsuites/sptests/spheapprot/init.c | 2 --
testsuites/sptests/spinternalerror02/init.c | 2 --
testsuites/sptests/spmkdir/init.c | 2 --
testsuites/sptests/spmrsp01/init.c | 2 --
testsuites/sptests/spnsext01/init.c | 2 --
testsuites/sptests/spprofiling01/init.c | 2 --
testsuites/sptests/spresource01/init.c | 2 --
testsuites/sptests/spscheduler01/init.c | 2 --
testsuites/sptests/spsem03/init.c | 2 --
testsuites/sptests/spthreadlife01/init.c | 2 --
88 files changed, 2 insertions(+), 138 deletions(-)
diff --git a/cpukit/libi2c/libi2c.h b/cpukit/libi2c/libi2c.h
index 1432746..27bf94c 100644
--- a/cpukit/libi2c/libi2c.h
+++ b/cpukit/libi2c/libi2c.h
@@ -204,9 +204,8 @@ typedef struct rtems_libi2c_bus_ops_
* (i.e., libi2c) and the minor number encodes a bus# and a i2c address.
* The name will be registered in the filesystem (parent
- * directories must exist, also IMFS filesystem must exist see
- * CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM). It may be NULL in which case
- * the library will pick a default.
+ * directories must exist, also IMFS filesystem must exist). It may be NULL in
+ * which case the library will pick a default.
* RETURNS: bus # (>=0) or -1 on error (errno set).
diff --git a/cpukit/libmisc/dummy/default-configuration.c b/cpukit/libmisc/dummy/default-configuration.c
index ff04a74..ae7ad61 100644
--- a/cpukit/libmisc/dummy/default-configuration.c
+++ b/cpukit/libmisc/dummy/default-configuration.c
@@ -88,7 +88,6 @@ static void Init( rtems_task_argument arg )
#define CONFIGURE_UNIFIED_WORK_AREAS
#define CONFIGURE_UNLIMITED_OBJECTS
#define CONFIGURE_STACK_CHECKER_ENABLED
-#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 8
#define CONFIGURE_MAXIMUM_DRIVERS 16
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 32
diff --git a/testsuites/fstests/fsbdpart01/init.c b/testsuites/fstests/fsbdpart01/init.c
index 48dab62..9dd47b1 100644
--- a/testsuites/fstests/fsbdpart01/init.c
+++ b/testsuites/fstests/fsbdpart01/init.c
@@ -230,8 +230,6 @@ size_t rtems_ramdisk_configuration_size = 1;
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 13
#define CONFIGURE_MAXIMUM_TASKS 2
#define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
diff --git a/testsuites/fstests/fsdosfsformat01/init.c b/testsuites/fstests/fsdosfsformat01/init.c
index 976dc9c..4ee2bc9 100644
--- a/testsuites/fstests/fsdosfsformat01/init.c
+++ b/testsuites/fstests/fsdosfsformat01/init.c
@@ -488,8 +488,6 @@ static void Init( rtems_task_argument arg )
/* one active file + stdin + stdout + stderr + device file when mounted */
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 5
#define CONFIGURE_FILESYSTEM_DOSFS
#define CONFIGURE_MAXIMUM_TASKS 1
diff --git a/testsuites/fstests/fsdosfsname01/init.c b/testsuites/fstests/fsdosfsname01/init.c
index d57c653..c5af7fc 100644
--- a/testsuites/fstests/fsdosfsname01/init.c
+++ b/testsuites/fstests/fsdosfsname01/init.c
@@ -1314,8 +1314,6 @@ size_t rtems_ramdisk_configuration_size = RTEMS_ARRAY_SIZE(rtems_ramdisk_configu
#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
/* 2 RAM disk device files + 2 mount_dir + stdin + stdout + stderr +
diff --git a/testsuites/fstests/fsdosfssync01/init.c b/testsuites/fstests/fsdosfssync01/init.c
index b0022e9..6e6caf7 100644
--- a/testsuites/fstests/fsdosfssync01/init.c
+++ b/testsuites/fstests/fsdosfssync01/init.c
@@ -162,8 +162,6 @@ size_t rtems_ramdisk_configuration_size = 1;
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
diff --git a/testsuites/fstests/fsdosfswrite01/init.c b/testsuites/fstests/fsdosfswrite01/init.c
index e1a4ca5..9ca1a2a 100644
--- a/testsuites/fstests/fsdosfswrite01/init.c
+++ b/testsuites/fstests/fsdosfswrite01/init.c
@@ -276,8 +276,6 @@ static void Init( rtems_task_argument arg )
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
/* 1 device file for blkstats + 1 file for writing + 1 mount_dir + stdin + stdout + stderr + device file when mounted */
diff --git a/testsuites/fstests/fsfseeko01/init.c b/testsuites/fstests/fsfseeko01/init.c
index 686d0d3..ef92d10 100644
--- a/testsuites/fstests/fsfseeko01/init.c
+++ b/testsuites/fstests/fsfseeko01/init.c
@@ -93,8 +93,6 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4
#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
diff --git a/testsuites/fstests/fsimfsgeneric01/init.c b/testsuites/fstests/fsimfsgeneric01/init.c
index 40f0aed..0c04b9c 100644
--- a/testsuites/fstests/fsimfsgeneric01/init.c
+++ b/testsuites/fstests/fsimfsgeneric01/init.c
@@ -501,8 +501,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/fstests/fsrofs01/init.c b/testsuites/fstests/fsrofs01/init.c
index 199ffde..cd1dcc4 100644
--- a/testsuites/fstests/fsrofs01/init.c
+++ b/testsuites/fstests/fsrofs01/init.c
@@ -175,7 +175,6 @@ size_t rtems_ramdisk_configuration_size = 1;
#define CONFIGURE_FILESYSTEM_RFS
diff --git a/testsuites/fstests/imfs_support/fs_support.c b/testsuites/fstests/imfs_support/fs_support.c
index e853690..966b01f 100644
--- a/testsuites/fstests/imfs_support/fs_support.c
+++ b/testsuites/fstests/imfs_support/fs_support.c
@@ -38,7 +38,6 @@ test_shutdown_filesystem (void)
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#define CONFIGURE_MAXIMUM_TASKS 10
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 40
#define CONFIGURE_INIT_TASK_STACK_SIZE (16 * 1024)
#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS 1
diff --git a/testsuites/fstests/jffs2_support/fs_support.c b/testsuites/fstests/jffs2_support/fs_support.c
index 1ff010d..b882412 100644
--- a/testsuites/fstests/jffs2_support/fs_support.c
+++ b/testsuites/fstests/jffs2_support/fs_support.c
@@ -146,7 +146,6 @@ void test_shutdown_filesystem(void)
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_FILESYSTEM_JFFS2
diff --git a/testsuites/fstests/mdosfs_support/fs_support.c b/testsuites/fstests/mdosfs_support/fs_support.c
index 8d01e9c..8119db6 100644
--- a/testsuites/fstests/mdosfs_support/fs_support.c
+++ b/testsuites/fstests/mdosfs_support/fs_support.c
@@ -87,7 +87,6 @@ void test_shutdown_filesystem(void)
#define CONFIGURE_MAXIMUM_SEMAPHORES RTEMS_DOSFS_SEMAPHORES_PER_INSTANCE
#define CONFIGURE_MAXIMUM_DRIVERS 10
diff --git a/testsuites/fstests/mimfs_support/fs_support.c b/testsuites/fstests/mimfs_support/fs_support.c
index 894d8f8..5a50d82 100644
--- a/testsuites/fstests/mimfs_support/fs_support.c
+++ b/testsuites/fstests/mimfs_support/fs_support.c
@@ -53,7 +53,6 @@ test_shutdown_filesystem (void)
diff --git a/testsuites/fstests/mrfs_support/fs_support.c b/testsuites/fstests/mrfs_support/fs_support.c
index a1b9a87..90c4fa9 100644
--- a/testsuites/fstests/mrfs_support/fs_support.c
+++ b/testsuites/fstests/mrfs_support/fs_support.c
@@ -66,7 +66,6 @@ test_shutdown_filesystem (void)
diff --git a/testsuites/libtests/block01/init.c b/testsuites/libtests/block01/init.c
index 9e10830..b7eaa2b 100644
--- a/testsuites/libtests/block01/init.c
+++ b/testsuites/libtests/block01/init.c
@@ -252,7 +252,6 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/libtests/block02/init.c b/testsuites/libtests/block02/init.c
index 055eaed..f53dacc 100644
--- a/testsuites/libtests/block02/init.c
+++ b/testsuites/libtests/block02/init.c
@@ -199,8 +199,6 @@ static rtems_task Init(rtems_task_argument argument)
#define CONFIGURE_MAXIMUM_TASKS 3
#define CONFIGURE_MAXIMUM_DRIVERS 3
diff --git a/testsuites/libtests/block03/init.c b/testsuites/libtests/block03/init.c
index 7aa3b7f..1da59f0 100644
--- a/testsuites/libtests/block03/init.c
+++ b/testsuites/libtests/block03/init.c
@@ -186,8 +186,6 @@ static rtems_task Init(rtems_task_argument argument)
#define CONFIGURE_MAXIMUM_DRIVERS 2
diff --git a/testsuites/libtests/block04/init.c b/testsuites/libtests/block04/init.c
index cfef560..6731556 100644
--- a/testsuites/libtests/block04/init.c
+++ b/testsuites/libtests/block04/init.c
@@ -158,8 +158,6 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/libtests/block05/init.c b/testsuites/libtests/block05/init.c
index 15290c1..59889cc 100644
--- a/testsuites/libtests/block05/init.c
+++ b/testsuites/libtests/block05/init.c
@@ -516,8 +516,6 @@ static rtems_task Init(rtems_task_argument argument)
#define CONFIGURE_MAXIMUM_TASKS 4
#define CONFIGURE_MAXIMUM_DRIVERS 4
diff --git a/testsuites/libtests/block06/init.c b/testsuites/libtests/block06/init.c
index 514ea8b..2234034 100644
--- a/testsuites/libtests/block06/init.c
+++ b/testsuites/libtests/block06/init.c
@@ -1850,8 +1850,6 @@ static rtems_task Init(rtems_task_argument argument)
#define CONFIGURE_BDBUF_TASK_STACK_SIZE BDBUF_TEST_STACK_SIZE
#define CONFIGURE_MAXIMUM_TASKS (1 + BDBUF_TEST_TASKS)
diff --git a/testsuites/libtests/block07/init.c b/testsuites/libtests/block07/init.c
index 3417f51..f34e412 100644
--- a/testsuites/libtests/block07/init.c
+++ b/testsuites/libtests/block07/init.c
@@ -261,7 +261,6 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/libtests/block09/init.c b/testsuites/libtests/block09/init.c
index 584beb4..6d156ce 100644
--- a/testsuites/libtests/block09/init.c
+++ b/testsuites/libtests/block09/init.c
@@ -234,8 +234,6 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/libtests/block10/init.c b/testsuites/libtests/block10/init.c
index fc5030a..61889ab 100644
--- a/testsuites/libtests/block10/init.c
+++ b/testsuites/libtests/block10/init.c
@@ -476,8 +476,6 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/libtests/block11/init.c b/testsuites/libtests/block11/init.c
index 0704dad..4d19d19 100644
--- a/testsuites/libtests/block11/init.c
+++ b/testsuites/libtests/block11/init.c
@@ -430,7 +430,6 @@ static rtems_task Init(rtems_task_argument argument)
{ .initialization_entry = invalid_initialize, \
.control_entry = invalid_control }
diff --git a/testsuites/libtests/block12/init.c b/testsuites/libtests/block12/init.c
index 1825de3..5b74977 100644
--- a/testsuites/libtests/block12/init.c
+++ b/testsuites/libtests/block12/init.c
@@ -142,8 +142,6 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_BDBUF_BUFFER_MAX_SIZE 1
#define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE BLOCK_COUNT
diff --git a/testsuites/libtests/block13/init.c b/testsuites/libtests/block13/init.c
index 14aaa21..82c9b3a 100644
--- a/testsuites/libtests/block13/init.c
+++ b/testsuites/libtests/block13/init.c
@@ -230,8 +230,6 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS 3
#define CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY 1
diff --git a/testsuites/libtests/block14/init.c b/testsuites/libtests/block14/init.c
index f96a115..01d2f5e 100644
--- a/testsuites/libtests/block14/init.c
+++ b/testsuites/libtests/block14/init.c
@@ -210,8 +210,6 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS 1
diff --git a/testsuites/libtests/block15/init.c b/testsuites/libtests/block15/init.c
index 45dda5b..19d30d1 100644
--- a/testsuites/libtests/block15/init.c
+++ b/testsuites/libtests/block15/init.c
@@ -174,8 +174,6 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE (BLOCK_COUNT * BLOCK_SIZE)
#define CONFIGURE_BDBUF_MAX_WRITE_BLOCKS MAX_WRITE_BLOCKS
diff --git a/testsuites/libtests/block16/init.c b/testsuites/libtests/block16/init.c
index 9b32e05..c7d4148 100644
--- a/testsuites/libtests/block16/init.c
+++ b/testsuites/libtests/block16/init.c
#define CONFIGURE_BDBUF_BUFFER_MAX_SIZE 8
#define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE 8
diff --git a/testsuites/libtests/block17/init.c b/testsuites/libtests/block17/init.c
index 55d0f6d..384cb95 100644
--- a/testsuites/libtests/block17/init.c
+++ b/testsuites/libtests/block17/init.c
@@ -45,8 +45,6 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS (64UL * 1024UL)
diff --git a/testsuites/libtests/crypt01/init.c b/testsuites/libtests/crypt01/init.c
index 487aa2c..57983dc 100644
--- a/testsuites/libtests/crypt01/init.c
+++ b/testsuites/libtests/crypt01/init.c
@@ -247,8 +247,6 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
diff --git a/testsuites/libtests/devfs03/init.c b/testsuites/libtests/devfs03/init.c
index 85b2fa0..147deeb 100644
--- a/testsuites/libtests/devfs03/init.c
+++ b/testsuites/libtests/devfs03/init.c
@@ -92,7 +92,6 @@ rtems_task Init(
#define CONFIGURE_FILESYSTEM_DEVFS
diff --git a/testsuites/libtests/deviceio01/init.c b/testsuites/libtests/deviceio01/init.c
index c3dd67a..519719d 100644
--- a/testsuites/libtests/deviceio01/init.c
+++ b/testsuites/libtests/deviceio01/init.c
@@ -80,8 +80,6 @@ rtems_task Init(
#include <rtems/confdefs.h>
/* end of file */
diff --git a/testsuites/libtests/dl01/init.c b/testsuites/libtests/dl01/init.c
index 4af0b9b..9fbdaa5 100644
--- a/testsuites/libtests/dl01/init.c
+++ b/testsuites/libtests/dl01/init.c
@@ -65,7 +65,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/dl02/init.c b/testsuites/libtests/dl02/init.c
index bcb76c4..59f339a 100644
--- a/testsuites/libtests/dl02/init.c
+++ b/testsuites/libtests/dl02/init.c
diff --git a/testsuites/libtests/exit01/init.c b/testsuites/libtests/exit01/init.c
index c60c1f4..6fbad6b 100644
--- a/testsuites/libtests/exit01/init.c
+++ b/testsuites/libtests/exit01/init.c
@@ -107,8 +107,6 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_INITIAL_EXTENSIONS \
{ .fatal = fatal_extension }, \
diff --git a/testsuites/libtests/exit02/init.c b/testsuites/libtests/exit02/init.c
index 13e78f4..88e0874 100644
--- a/testsuites/libtests/exit02/init.c
+++ b/testsuites/libtests/exit02/init.c
@@ -85,8 +85,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/flashdisk01/init.c b/testsuites/libtests/flashdisk01/init.c
index f37f526..01b0329 100644
--- a/testsuites/libtests/flashdisk01/init.c
+++ b/testsuites/libtests/flashdisk01/init.c
@@ -341,7 +341,6 @@ uint32_t rtems_flashdisk_configuration_size = FLASHDISK_CONFIG_COUNT;
diff --git a/testsuites/libtests/ftp01/init.c b/testsuites/libtests/ftp01/init.c
index b0c20a2..0668e6c 100644
--- a/testsuites/libtests/ftp01/init.c
+++ b/testsuites/libtests/ftp01/init.c
@@ -234,7 +234,6 @@ static rtems_task Init(rtems_task_argument argument)
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 14
#define CONFIGURE_FILESYSTEM_FTPFS
diff --git a/testsuites/libtests/i2c01/init.c b/testsuites/libtests/i2c01/init.c
index 20059af..908802f 100644
--- a/testsuites/libtests/i2c01/init.c
+++ b/testsuites/libtests/i2c01/init.c
@@ -636,8 +636,6 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 7
diff --git a/testsuites/libtests/md501/init.c b/testsuites/libtests/md501/init.c
index d545b1c..124c2d7 100644
--- a/testsuites/libtests/md501/init.c
+++ b/testsuites/libtests/md501/init.c
@@ -245,8 +245,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/mghttpd01/init.c b/testsuites/libtests/mghttpd01/init.c
index 9f28570..233ec6e 100644
--- a/testsuites/libtests/mghttpd01/init.c
+++ b/testsuites/libtests/mghttpd01/init.c
@@ -270,8 +270,6 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_FILESYSTEM_IMFS
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 16
diff --git a/testsuites/libtests/monitor02/system.h b/testsuites/libtests/monitor02/system.h
index 3323610..f9aebdd 100644
--- a/testsuites/libtests/monitor02/system.h
+++ b/testsuites/libtests/monitor02/system.h
@@ -45,7 +45,6 @@ void Get_all_counters( void );
#define CONFIGURE_EXTRA_TASK_STACKS \
(6 * (3 * RTEMS_MINIMUM_STACK_SIZE)) /* our tasks */ + \
diff --git a/testsuites/libtests/newlib01/init.c b/testsuites/libtests/newlib01/init.c
index a1443d6..0361607 100644
--- a/testsuites/libtests/newlib01/init.c
+++ b/testsuites/libtests/newlib01/init.c
@@ -296,8 +296,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/pwdgrp01/init.c b/testsuites/libtests/pwdgrp01/init.c
index 86f8e90..bc37367 100644
--- a/testsuites/libtests/pwdgrp01/init.c
+++ b/testsuites/libtests/pwdgrp01/init.c
@@ -160,8 +160,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/pwdgrp02/init.c b/testsuites/libtests/pwdgrp02/init.c
index 8f79502..ebc8d0b 100644
--- a/testsuites/libtests/pwdgrp02/init.c
+++ b/testsuites/libtests/pwdgrp02/init.c
@@ -165,8 +165,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/sha/init.c b/testsuites/libtests/sha/init.c
index d08bbc8..797eec7 100644
--- a/testsuites/libtests/sha/init.c
+++ b/testsuites/libtests/sha/init.c
@@ -178,8 +178,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/shell01/init.c b/testsuites/libtests/shell01/init.c
index bbfa36e..b7ec2d1 100644
--- a/testsuites/libtests/shell01/init.c
+++ b/testsuites/libtests/shell01/init.c
@@ -173,8 +173,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/libtests/sparsedisk01/init.c b/testsuites/libtests/sparsedisk01/init.c
index a13dde8..7c556cd 100644
--- a/testsuites/libtests/sparsedisk01/init.c
+++ b/testsuites/libtests/sparsedisk01/init.c
@@ -430,7 +430,6 @@ static void Init( rtems_task_argument arg )
diff --git a/testsuites/libtests/syscall01/init.c b/testsuites/libtests/syscall01/init.c
index 8440d76..bfffa0e 100644
--- a/testsuites/libtests/syscall01/init.c
+++ b/testsuites/libtests/syscall01/init.c
@@ -127,8 +127,6 @@ static rtems_device_driver open_driver_open(
#define CONFIGURE_APPLICATION_EXTRA_DRIVERS OPEN_DRIVER
diff --git a/testsuites/libtests/tar01/init.c b/testsuites/libtests/tar01/init.c
index f1403de..8ff107e 100644
--- a/testsuites/libtests/tar01/init.c
+++ b/testsuites/libtests/tar01/init.c
@@ -123,7 +123,6 @@ rtems_task Init(
diff --git a/testsuites/libtests/tar02/init.c b/testsuites/libtests/tar02/init.c
index 29bc529..ebf87f8 100644
--- a/testsuites/libtests/tar02/init.c
+++ b/testsuites/libtests/tar02/init.c
@@ -80,7 +80,6 @@ rtems_task Init(
diff --git a/testsuites/libtests/utf8proc01/init.c b/testsuites/libtests/utf8proc01/init.c
index fd27451..fda1444 100644
--- a/testsuites/libtests/utf8proc01/init.c
+++ b/testsuites/libtests/utf8proc01/init.c
@@ -262,8 +262,6 @@ static void Init ( rtems_task_argument arg )
diff --git a/testsuites/psxtests/psx13/main.c b/testsuites/psxtests/psx13/main.c
index 395c31b..62541bb 100644
--- a/testsuites/psxtests/psx13/main.c
+++ b/testsuites/psxtests/psx13/main.c
@@ -36,7 +36,6 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxaio01/system.h b/testsuites/psxtests/psxaio01/system.h
index 2bb81a6..91a8658 100644
--- a/testsuites/psxtests/psxaio01/system.h
+++ b/testsuites/psxtests/psxaio01/system.h
@@ -19,7 +19,6 @@ void *POSIX_Init (void *argument);
#define CONFIGURE_MAXIMUM_TASKS 20
#define CONFIGURE_MAXIMUM_SEMAPHORES 20
diff --git a/testsuites/psxtests/psxaio02/system.h b/testsuites/psxtests/psxaio02/system.h
index 7d6c752..4137251 100644
--- a/testsuites/psxtests/psxaio02/system.h
+++ b/testsuites/psxtests/psxaio02/system.h
diff --git a/testsuites/psxtests/psxaio03/system.h b/testsuites/psxtests/psxaio03/system.h
index 92ae0aa..fbea6f0 100644
--- a/testsuites/psxtests/psxaio03/system.h
+++ b/testsuites/psxtests/psxaio03/system.h
@@ -20,7 +20,6 @@ void *POSIX_Init (void *argument);
diff --git a/testsuites/psxtests/psxchroot01/main.c b/testsuites/psxtests/psxchroot01/main.c
index 5eeeebc..6dcb307 100644
--- a/testsuites/psxtests/psxchroot01/main.c
+++ b/testsuites/psxtests/psxchroot01/main.c
@@ -29,7 +29,6 @@ rtems_task Init(
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 10
diff --git a/testsuites/psxtests/psxfchx01/init.c b/testsuites/psxtests/psxfchx01/init.c
index a6716b8..89a0d06 100644
--- a/testsuites/psxtests/psxfchx01/init.c
+++ b/testsuites/psxtests/psxfchx01/init.c
@@ -220,7 +220,6 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxfile01/main.c b/testsuites/psxtests/psxfile01/main.c
index 4972cc2..a6ad029 100644
--- a/testsuites/psxtests/psxfile01/main.c
+++ b/testsuites/psxtests/psxfile01/main.c
@@ -33,7 +33,6 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxfile02/init.c b/testsuites/psxtests/psxfile02/init.c
index d06a745..fe74fec 100644
--- a/testsuites/psxtests/psxfile02/init.c
+++ b/testsuites/psxtests/psxfile02/init.c
@@ -144,7 +144,6 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxmount/main.c b/testsuites/psxtests/psxmount/main.c
index c6479cb..2e32a29 100644
--- a/testsuites/psxtests/psxmount/main.c
+++ b/testsuites/psxtests/psxmount/main.c
@@ -31,7 +31,6 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxpasswd01/init.c b/testsuites/psxtests/psxpasswd01/init.c
index 4553ca3..eb96e28 100644
--- a/testsuites/psxtests/psxpasswd01/init.c
+++ b/testsuites/psxtests/psxpasswd01/init.c
@@ -180,7 +180,6 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxpasswd02/init.c b/testsuites/psxtests/psxpasswd02/init.c
index da4f2b4..7090c94 100644
--- a/testsuites/psxtests/psxpasswd02/init.c
+++ b/testsuites/psxtests/psxpasswd02/init.c
@@ -222,7 +222,6 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxpipe01/init.c b/testsuites/psxtests/psxpipe01/init.c
index 145cf81..59dfe5b 100644
--- a/testsuites/psxtests/psxpipe01/init.c
+++ b/testsuites/psxtests/psxpipe01/init.c
@@ -102,7 +102,6 @@ rtems_task Init(
diff --git a/testsuites/psxtests/psxrdwrv/main.c b/testsuites/psxtests/psxrdwrv/main.c
index 2e2d309..32a5fa9 100644
--- a/testsuites/psxtests/psxrdwrv/main.c
+++ b/testsuites/psxtests/psxrdwrv/main.c
diff --git a/testsuites/psxtests/psxreaddir/main.c b/testsuites/psxtests/psxreaddir/main.c
index a76838d..90880b0 100644
--- a/testsuites/psxtests/psxreaddir/main.c
+++ b/testsuites/psxtests/psxreaddir/main.c
diff --git a/testsuites/psxtests/psxstat/main.c b/testsuites/psxtests/psxstat/main.c
index 310ac3d..19ed8d4 100644
--- a/testsuites/psxtests/psxstat/main.c
+++ b/testsuites/psxtests/psxstat/main.c
diff --git a/testsuites/samples/fileio/system.h b/testsuites/samples/fileio/system.h
index a99c36d..3a70ce8 100644
--- a/testsuites/samples/fileio/system.h
+++ b/testsuites/samples/fileio/system.h
@@ -53,8 +53,6 @@ rtems_task Init(
#endif
* XXX: these values are higher than needed...
diff --git a/testsuites/samples/loopback/init.c b/testsuites/samples/loopback/init.c
index 8819561..7ac376f 100644
--- a/testsuites/samples/loopback/init.c
+++ b/testsuites/samples/loopback/init.c
@@ -25,7 +25,6 @@ const char rtems_test_name[] = "LOOPBACK";
#define CONFIGURE_MICROSECONDS_PER_TICK 10000
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 50
#define CONFIGURE_INIT_TASK_STACK_SIZE (10*1024)
#define CONFIGURE_INIT_TASK_PRIORITY 50
diff --git a/testsuites/sptests/spcache01/init.c b/testsuites/sptests/spcache01/init.c
index 8ed3dbe..973fa79 100644
--- a/testsuites/sptests/spcache01/init.c
+++ b/testsuites/sptests/spcache01/init.c
@@ -472,8 +472,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spcontext01/init.c b/testsuites/sptests/spcontext01/init.c
index 1380267..039dd63 100644
--- a/testsuites/sptests/spcontext01/init.c
+++ b/testsuites/sptests/spcontext01/init.c
@@ -219,8 +219,6 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_TIMERS 1
diff --git a/testsuites/sptests/spfifo01/init.c b/testsuites/sptests/spfifo01/init.c
index a978006..0e0f678 100644
--- a/testsuites/sptests/spfifo01/init.c
+++ b/testsuites/sptests/spfifo01/init.c
@@ -61,8 +61,6 @@ rtems_task Init(rtems_task_argument not_used)
diff --git a/testsuites/sptests/spfifo02/init.c b/testsuites/sptests/spfifo02/init.c
index b08443a..3cb6062 100644
--- a/testsuites/sptests/spfifo02/init.c
+++ b/testsuites/sptests/spfifo02/init.c
@@ -213,7 +213,6 @@ rtems_task Init(
#define CONFIGURE_FIFOS_ENABLED
#define CONFIGURE_MAXIMUM_FIFOS 1
diff --git a/testsuites/sptests/spfifo03/init.c b/testsuites/sptests/spfifo03/init.c
index 72e9f62..198ba54 100644
--- a/testsuites/sptests/spfifo03/init.c
+++ b/testsuites/sptests/spfifo03/init.c
@@ -205,7 +205,6 @@ rtems_task Init(
diff --git a/testsuites/sptests/spfifo04/init.c b/testsuites/sptests/spfifo04/init.c
index 3ed9f41..aeb4f06 100644
--- a/testsuites/sptests/spfifo04/init.c
+++ b/testsuites/sptests/spfifo04/init.c
@@ -99,7 +99,6 @@ rtems_task Init(
diff --git a/testsuites/sptests/spfifo05/init.c b/testsuites/sptests/spfifo05/init.c
index 9f369e0..8537154 100644
--- a/testsuites/sptests/spfifo05/init.c
+++ b/testsuites/sptests/spfifo05/init.c
@@ -260,7 +260,6 @@ rtems_task Init(
diff --git a/testsuites/sptests/spheapprot/init.c b/testsuites/sptests/spheapprot/init.c
index e7a77fd..114abeb 100644
--- a/testsuites/sptests/spheapprot/init.c
+++ b/testsuites/sptests/spheapprot/init.c
@@ -140,8 +140,6 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index 3302a2c..5d1d26f 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -86,8 +86,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spmkdir/init.c b/testsuites/sptests/spmkdir/init.c
index 1d12f6e..6b016e3 100644
--- a/testsuites/sptests/spmkdir/init.c
+++ b/testsuites/sptests/spmkdir/init.c
@@ -109,8 +109,6 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/sptests/spmrsp01/init.c b/testsuites/sptests/spmrsp01/init.c
index d8da787..d5acb0a 100644
--- a/testsuites/sptests/spmrsp01/init.c
+++ b/testsuites/sptests/spmrsp01/init.c
@@ -312,8 +312,6 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_MAXIMUM_SEMAPHORES 1
#define CONFIGURE_MAXIMUM_MRSP_SEMAPHORES 1
diff --git a/testsuites/sptests/spnsext01/init.c b/testsuites/sptests/spnsext01/init.c
index b9c8877..89f0b8f 100644
--- a/testsuites/sptests/spnsext01/init.c
+++ b/testsuites/sptests/spnsext01/init.c
@@ -81,8 +81,6 @@ static rtems_task Init(rtems_task_argument argument)
diff --git a/testsuites/sptests/spprofiling01/init.c b/testsuites/sptests/spprofiling01/init.c
index a0e7ce3..afbe2c7 100644
--- a/testsuites/sptests/spprofiling01/init.c
+++ b/testsuites/sptests/spprofiling01/init.c
@@ -140,8 +140,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spresource01/init.c b/testsuites/sptests/spresource01/init.c
index 9877066..7b1dd47 100644
--- a/testsuites/sptests/spresource01/init.c
+++ b/testsuites/sptests/spresource01/init.c
@@ -306,8 +306,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spscheduler01/init.c b/testsuites/sptests/spscheduler01/init.c
index bcb656d..31a0ec8 100644
--- a/testsuites/sptests/spscheduler01/init.c
+++ b/testsuites/sptests/spscheduler01/init.c
@@ -289,8 +289,6 @@ static void Init(rtems_task_argument arg)
diff --git a/testsuites/sptests/spsem03/init.c b/testsuites/sptests/spsem03/init.c
index cf1e48b..e64a04d 100644
--- a/testsuites/sptests/spsem03/init.c
+++ b/testsuites/sptests/spsem03/init.c
diff --git a/testsuites/sptests/spthreadlife01/init.c b/testsuites/sptests/spthreadlife01/init.c
index f400516..db22859 100644
--- a/testsuites/sptests/spthreadlife01/init.c
+++ b/testsuites/sptests/spthreadlife01/init.c
@@ -386,8 +386,6 @@ static void Init(rtems_task_argument arg)
1.8.4.5
