Mutex obtain with timeout
Sebastian Huber
Thu Dec 18 13:18:31 UTC 2014
Hello,
I work currently on concepts to implement mutex objects with SMP aware
locking protocols. Currently this is MrsP [1] and OMIP [2]. The
implementation should use fine grained locking. It turned out that the
support for timeout makes the implementations much more complicated.
With timeouts you can tear a resource dependency tree into two sub-trees
at arbitrary positions and this makes traversal difficult (you can cut
off the way back).
Is there a valid use case for a mutex obtain operation with a timeout in
case the locking protocol aims to provide bounded wait times? We can
probably also assume that the critical section has a bounded execution time.
[1] A. Burns , A. J. Wellings, A Schedulability Compatible
Multiprocessor Resource Sharing Protocol -- MrsP, Proceedings of the
2013 25th Euromicro Conference on Real-Time Systems, p.282-291, July
09-12, 2013
[2] Björn B. Brandenburg, A Fully Preemptive Multiprocessor Semaphore
Protocol for Latency-Sensitive Real-Time Applications, Proceedings of
the 2013 25th Euromicro Conference on Real-Time Systems, p.292-302, July
09-12, 2013
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
