Mutex obtain with timeout
Thu Dec 18 15:38:22 UTC 2014
On December 18, 2014 5:18:31 AM PST, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>Hello,
>I work currently on concepts to implement mutex objects with SMP aware
>locking protocols.  Currently this is MrsP [1] and OMIP [2]. The
>implementation should use fine grained locking.  It turned out that the
>support for timeout makes the implementations much more complicated.
>With timeouts you can tear a resource dependency tree into two
>sub-trees
>at arbitrary positions and this makes traversal difficult (you can cut
>off the way back).
>Is there a valid use case for a mutex obtain operation with a timeout
>in
>case the locking protocol aims to provide bounded wait times?  We can
>probably also assume that the critical section has a bounded execution
>time.
I don't know if there is or not. It is close to Christmas but I can try to email Burns and Wellings. I have met them both a few times and they gave usually been quick to answer.
Or we could send Hesham to their office hours .. Lol
>[1] A. Burns , A. J. Wellings, A Schedulability Compatible
>Multiprocessor Resource Sharing Protocol -- MrsP, Proceedings of the
>2013 25th Euromicro Conference on Real-Time Systems, p.282-291, July
>09-12, 2013
>[2] Björn B. Brandenburg, A Fully Preemptive Multiprocessor Semaphore
>Protocol for Latency-Sensitive Real-Time Applications, Proceedings of
>the 2013 25th Euromicro Conference on Real-Time Systems, p.292-302,
>July
>09-12, 2013
>Sebastian Huber, embedded brains GmbH
>Address : Dornierstr. 4, D-82178 Puchheim, Germany
>Phone   : +49 89 189 47 41-16
>Fax     : +49 89 189 47 41-09
>E-Mail  : sebastian.huber at embedded-brains.de
>PGP     : Public key available on request.
>Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>_______________________________________________
>devel mailing list
>devel at rtems.org
>http://lists.rtems.org/mailman/listinfo/devel
--joel
