[PATCH] doc: add some red-black tree documentation
Fri Dec 19 17:10:18 UTC 2014
When I try to build the doc with this, I get
./chains.texi:862: Next reference to nonexistent `Red-Black Trees'
./timespec.texi:8: Prev reference to nonexistent `Red-Black Trees
Documentation for the Red-Black Tree Directives'
gmake[1]: *** [c_user.info] Error 1
Probably some problem in the Makefile.am setup?
-Gedare
On Fri, Dec 19, 2014 at 12:06 PM, Gedare Bloom <gedare at rtems.org> wrote:
> closes #2059
>  doc/user/Makefile.am | 13 +++++---
>  doc/user/rbtree.t    | 92 ++++++++++++++++++++++++++++++++++++++++++++++++++++
>  2 files changed, 101 insertions(+), 4 deletions(-)
>  create mode 100644 doc/user/rbtree.t
> diff --git a/doc/user/Makefile.am b/doc/user/Makefile.am
> index e774319..cd8b5f3 100644
> --- a/doc/user/Makefile.am
> +++ b/doc/user/Makefile.am
> @@ -14,8 +14,8 @@ GENERATED_FILES = overview.texi concepts.texi datatypes.texi init.texi \
>      task.texi intr.texi clock.texi timer.texi sem.texi msg.texi event.texi \
>      signal.texi part.texi region.texi dpmem.texi io.texi fatal.texi \
>      schedule.texi rtmon.texi barrier.texi bsp.texi userext.texi conf.texi \
> -    mp.texi stackchk.texi cpuuse.texi object.texi chains.texi timespec.texi \
> -    cbs.texi dirstat.texi smp.texi
> +    mp.texi stackchk.texi cpuuse.texi object.texi chains.texi rbtree.texi \
> +    timespec.texi cbs.texi dirstat.texi smp.texi
>  COMMON_FILES += $(top_srcdir)/common/cpright.texi
> @@ -186,10 +186,15 @@ object.texi: object.t
>  chains.texi: chains.t
>         $(BMENU2) -p "Object Services OBJECT_GET_CLASS_INFORMATION - Obtain Class Information" \
>             -u "Top" \
> +           -n "Red-Black Trees" < $< > $@
> +rbtree.texi: rbtree.t
> +       $(BMENU2) -p "Chains Prepend a Node" \
> +           -u "Top" \
>             -n "Timespec Helpers" < $< > $@
>  timespec.texi: timespec.t
> -       $(BMENU2) -p "Chains Prepend a Node" \
> +       $(BMENU2) -p "Red-Black Trees Documentation for the Red-Black Tree Directives" \
>             -u "Top" \
>             -n "Constant Bandwidth Server Scheduler API" < $< > $@
> @@ -205,7 +210,7 @@ dirstat.texi: dirstat.t
>  EXTRA_DIST = bsp.t cbs.t clock.t chains.t concepts.t cpuuse.t datatypes.t conf.t \
>      dpmem.t event.t fatal.t init.t intr.t io.t mp.t msg.t overview.t \
> -    part.t region.t rtmon.t sem.t schedule.t signal.t stackchk.t \
> +    part.t rbtree.t region.t rtmon.t sem.t schedule.t signal.t stackchk.t \
>      task.t timer.t userext.t dirstat.t $(TXT_FILES) $(PNG_FILES) $(EPS_IMAGES) \
>      $(noinst_DATA)
> diff --git a/doc/user/rbtree.t b/doc/user/rbtree.t
> new file mode 100644
> index 0000000..c90065b
> --- /dev/null
> +++ b/doc/user/rbtree.t
> @@ -0,0 +1,92 @@
> + at c
> + at c Copyright 2014 Gedare Bloom.
> + at c All rights reserved.
> + at chapter Red-Black Trees
> + at cindex rbtrees
> + at section Introduction
> +The Red-Black Tree API is an interface to the SuperCore (score) rbtree
> +implementation. Within RTEMS, red-black trees are used when a binary search
> +tree is needed, including dynamic priority thread queues and non-contiguous
> +heap memory. The Red-Black Tree API provided by RTEMS is:
> + at itemize @bullet
> + at c build_id
> + at item @code{@value{DIRPREFIX}rtems_rbtree_node} - Red-Black Tree node embedded in another struct
> + at item @code{@value{DIRPREFIX}rtems_rbtree_control} - Red-Black Tree control node for an entire tree
> + at item @code{@value{DIRPREFIX}rtems_rbtree_initialize} - initialize the red-black tree with nodes
> + at item @code{@value{DIRPREFIX}rtems_rbtree_initialize_empty} - initialize the red-black tree as empty
> + at item @code{@value{DIRPREFIX}rtems_rbtree_set_off_tree} - Clear a node's links
> + at item @code{@value{DIRPREFIX}rtems_rbtree_root} - Return the red-black tree's root node
> + at item @code{@value{DIRPREFIX}rtems_rbtree_min} - Return the red-black tree's minimum node
> + at item @code{@value{DIRPREFIX}rtems_rbtree_max} - Return the red-black tree's maximum node
> + at item @code{@value{DIRPREFIX}rtems_rbtree_left} - Return a node's left child node
> + at item @code{@value{DIRPREFIX}rtems_rbtree_right} - Return a node's right child node
> + at item @code{@value{DIRPREFIX}rtems_rbtree_parent} - Return a node's parent node
> + at item @code{@value{DIRPREFIX}rtems_rbtree_are_nodes_equal} - Are the node's equal ?
> + at item @code{@value{DIRPREFIX}rtems_rbtree_is_empty} - Is the red-black tree empty ?
> + at item @code{@value{DIRPREFIX}rtems_rbtree_is_min} - Is the Node the minimum in the red-black tree ?
> + at item @code{@value{DIRPREFIX}rtems_rbtree_is_max} - Is the Node the maximum in the red-black tree ?
> + at item @code{@value{DIRPREFIX}rtems_rbtree_is_root} - Is the Node the root of the red-black tree ?
> + at item @code{@value{DIRPREFIX}rtems_rbtree_find} - Find the node with a matching key in the red-black tree
> + at item @code{@value{DIRPREFIX}rtems_rbtree_predecessor} - Return the in-order predecessor of a node.
> + at item @code{@value{DIRPREFIX}rtems_rbtree_successor} - Return the in-order successor of a node.
> + at item @code{@value{DIRPREFIX}rtems_rbtree_extract} - Remove the node from the red-black tree
> + at item @code{@value{DIRPREFIX}rtems_rbtree_get_min} - Remove the minimum node from the red-black tree
> + at item @code{@value{DIRPREFIX}rtems_rbtree_get_max} - Remove the maximum node from the red-black tree
> + at item @code{@value{DIRPREFIX}rtems_rbtree_peek_min} - Returns the minimum node from the red-black tree
> + at item @code{@value{DIRPREFIX}rtems_rbtree_peek_max} - Returns the maximum node from the red-black tree
> + at item @code{@value{DIRPREFIX}rtems_rbtree_find_control} - Returns the control node of a red-black tree given a node in the tree.
> + at item @code{@value{DIRPREFIX}rtems_rbtree_insert} - Add the node to the red-black tree
> + at end itemize
> + at section Background
> +The Red-Black Trees API is a thin layer above the SuperCore Red-Black Trees
> +implementation. A Red-Black Tree is defined by a control node with pointers to
> +the root, minimum, and maximum nodes in the tree. Each node in the tree
> +consists of a parent pointer, two children pointers, and a color attribute.  A
> +tree is parameterized as either unique, meaning identical keys are rejected, or
> +not, in which case duplicate keys are allowed.
> +Users must provide a comparison functor that gets passed to functions that need
> +to compare nodes. In addition, no internal synchronization is offered within
> +the red-black tree implementation, thus users must ensure at most one thread
> +accesses a red-black tree instance at a time.
> + at subsection Nodes
> +A red-black tree is made up from nodes that orginate from a red-black tree control
> +object. A node is of type @code{@value{DIRPREFIX}rtems_rbtree_node}. The node
> +is designed to be part of a user data structure. To obtain the encapsulating
> +structure users can use the @code{RTEMS_CONTAINER_OF} macro.
> +The node can be placed anywhere within the user's structure and the macro will
> +calculate the structure's address from the node's address.
> + at subsection Controls
> +A red-black tree is rooted with a control object. Red-Black Tree control
> +provide the user with access to the nodes on the red-black tree.  The
> +implementation does not require special checks for manipulating the root of the
> +red-black tree. To accomplish this the
> + at code{@value{DIRPREFIX}rtems_rbtree_control} structure is treated as a
> + at code{@value{DIRPREFIX}rtems_rbtree_node} structure with a @code{NULL} parent
> +and left child pointing to the root.
> + at section Operations
> +Examples for using the red-black trees
> +can be found in the testsuites/sptests/sprbtree01/init.c file.
> + at section Directives
> + at subsection Documentation for the Red-Black Tree Directives
> + at cindex rbtree doc
> +Source documentation for the Red-Black Tree API can be found in the
> +generated Doxygen output for cpukit/sapi.
> 1.8.3.1
