[PATCH] grspw: descriptor tables no longer statically allocated
Wed Dec 24 03:08:07 UTC 2014
This is a patch proposed for PR 1761
[https://devel.rtems.org/ticket/1761]. Comment if OK or not.
On Tue, Dec 23, 2014 at 10:05 PM, Gedare Bloom <gedare at rtems.org> wrote:
> From: Daniel Ramirez <javamonn at gmail.com>
>  c/src/lib/libbsp/sparc/shared/spw/grspw.c | 14 +++++++-------
>  1 file changed, 7 insertions(+), 7 deletions(-)
> diff --git a/c/src/lib/libbsp/sparc/shared/spw/grspw.c b/c/src/lib/libbsp/sparc/shared/spw/grspw.c
> index b311500..d3eb9b9 100644
> --- a/c/src/lib/libbsp/sparc/shared/spw/grspw.c
> +++ b/c/src/lib/libbsp/sparc/shared/spw/grspw.c
> @@ -84,6 +84,7 @@
>  #include <assert.h>
>  #include <ctype.h>
>  #include <rtems/bspIo.h>
> +#include <rtems/malloc.h>
>  #include <ambapp.h>
>  #include <grlib.h>
>  #include <grspw.h>
> @@ -149,8 +150,6 @@ typedef struct {
>  #define BUFMEM_PER_LINK (SPACEWIRE_TXBUFS_NR*(SPACEWIRE_TXD_SIZE+SPACEWIRE_TXH_SIZE) + SPACEWIRE_RXBUFS_NR*SPACEWIRE_RXPCK_SIZE)
> -#define SPW_ALIGN(p,c) ((((unsigned int)(p))+((c)-1))&~((c)-1))
>  typedef struct {
>     /* configuration parameters */
>     spw_config config;
> @@ -190,9 +189,6 @@ typedef struct {
>  #ifdef GRSPW_STATIC_MEM
>     unsigned int membase, memend, mem_bdtable;
> -#else
> -   char _rxtable[SPACEWIRE_BDTABLE_SIZE*2];
> -   char _txtable[SPACEWIRE_BDTABLE_SIZE*2];
>  #endif
>     LEON3_SPACEWIRE_Regs_Map *regs;
> @@ -1383,8 +1379,8 @@ static int grspw_hw_init(GRSPW_DEV *pDev) {
>          pDev->rx = (SPACEWIRE_RXBD *) pDev->mem_bdtable;
>          pDev->tx = (SPACEWIRE_RXBD *) pDev->mem_bdtable + SPACEWIRE_BDTABLE_SIZE;
>  #else
> -        pDev->rx = (SPACEWIRE_RXBD *) SPW_ALIGN(&pDev->_rxtable, SPACEWIRE_BDTABLE_SIZE);
> -        pDev->tx = (SPACEWIRE_TXBD *) SPW_ALIGN(&pDev->_txtable, SPACEWIRE_BDTABLE_SIZE);
> +        pDev->rx = (SPACEWIRE_RXBD *) rtems_heap_allocate_aligned_with_boundry( SPACEWIRE_BDTABLE_SIZE, 1024, 0 );
> +        pDev->tx = (SPACEWIRE_TXBD *) rtems_heap_allocate_aligned_with_boundry( SPACEWIRE_BDTABLE_SIZE, 1024, 0 );
>  #endif
>          SPACEWIRE_DBG("hw_init [minor %i]\n", pDev->minor);
> @@ -1425,6 +1421,10 @@ static void grspw_hw_reset(GRSPW_DEV *pDev)
>          SPW_STATUS_WRITE(pDev, SPW_STATUS_TO | SPW_STATUS_CE | SPW_STATUS_ER | SPW_STATUS_DE | SPW_STATUS_PE |
>                           SPW_STATUS_WE | SPW_STATUS_IA | SPW_STATUS_EE); /*clear status*/
>          SPW_CTRL_WRITE(pDev, SPW_CTRL_LINKSTART); /*start link core*/
> +        #ifndef GRSPW_STATIC_MEM
> +                free(pDev->rx);
> +                free(pDec->tx);
> +        #endif
>  static void grspw_hw_read_config(GRSPW_DEV *pDev)
> 1.8.3.1
