[PATCH] Add GPIO, I2C and SPI support for the RPi BSP
Alan Cudmore
alan.cudmore at gmail.com
Mon Dec 15 20:19:41 UTC 2014
Is the ARM Zync BSP using the new i2c API?
I was looking through the BSP and did not see how it is initialized.
Also, the current libi2c supports SPI. Does anyone see a problem with using
libi2c for SPI and the new i2c API for i2c?
Finally, will new i2c drivers go in libchip, or in cpukit/dev ?
Thanks,
Alan
On Wed, Dec 10, 2014 at 7:41 PM, Andre Marques <
andre.lousa.marques at gmail.com> wrote:
> On 12/10/14 22:36, Chris Johns wrote:
>> On 11/12/2014 5:27 am, Alan Cudmore wrote:
>>> Andre,
>>> Thanks for submitting this. I think we need one minor change:
>>> Could you remove the include and the call to init the mcp23008 driver?
>>> After your code is in the tree, I will propose a patch to allow
>>> execution of application specific driver init functions that can be
>>> called from the BSP i2c and SPI driver init functions.
>> Is the I2C code for the new I2C API or the old one ?
>> Chris
> It still uses the old API (libi2c) for both i2c and spi.
> --André Marques
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141215/2bad7b98/attachment-0002.html>
