Reducing RTEMS size to <32KB to fit in Epiphany local memories
Marcos Díaz marcos.diaz at tallertechnologies.com
Wed Dec 17 17:49:07 UTC 2014
But that test doesn't use c++ nor use exceptions, but you will see this
problem if you do a objdump over the binaries.
On Wed, Dec 17, 2014 at 2:47 PM, Daniel Gutson <
daniel.gutson at tallertechnologies.com> wrote:
> Maybe it's worth to mention the 20k or so EH-related buffers?
> I think they go away when building the STL without EH and RTTI support,
> right?
> On Wed, Dec 17, 2014 at 2:44 PM, Marcos Díaz <
> marcos.diaz at tallertechnologies.com> wrote:
>> That particular test I could see it uses like four tasks. The problem we
>> had in the past is that the predefined size for the stack for each task was
>> set to 4k for our architecture (arm cortex m3). We proposed a patch in
>> order to make the default stack size for each bsp configurable. Im not sure
>> if it has been submitted
>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> #define CONFIGURE_MAXIMUM_TASKS             4
>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> #define CONFIGURE_EXTRA_TASK_STACKS         (3 * RTEMS_MINIMUM_STACK_SIZE)
>> #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> this is extracted from the "system.h" file of ticker test.
>> If your objective is to have that test working, i suggest to tune the
>> minimum stack size in this file.
>> If you want to know a little more, I suggest that you make a objdump and
>> see what global objects are using more RAM and where did they come from.
>> On Wed, Dec 17, 2014 at 1:36 PM, Daniel Gutson <
>>> We were able to downsize RTEMS to about 9k for the LPC1768.
>>> Marcos, could you give a hint?
>>> On Wed, Dec 17, 2014 at 1:34 PM, Joel Sherrill <
>>> joel.sherrill at oarcorp.com> wrote:
>>>> On December 17, 2014 8:00:50 AM PST, Hesham Moustafa <
>>>> heshamelmatary at gmail.com> wrote:
>>>> >Hi all,
>>>> >I am working on reducing RTEMS size to fit into <32KB as every Epiphay
>>>> >core has only 32KB of local memory. I was able to get hello and
>>>> >minimum samples with aggressive size reduction by manually removing
>>>> >un-needed code. Currently I only use libcsupport, sapi, score, rtems
>>>> >built for cpukit only, and for each, some source code files were
>>>> >removed. No IO, no FS, no barrier, event, managers are included.
>>>> Our minimum is where it is because no one has provided lower
>>>> requirements. Some of the things you dropped out could be addressed by
>>>> initialization being more like a constructor table that is automatically
>>>> built based on dependencies. This was/is the sequenced initialization
>>>> project. I don't know the state of it.
>>>> Try turning on per section methods and data like the SPARC bsps. This
>>>> saves memory.
>>>> Defining which features are part of 'nanoRTEMS' is a big part of this.
>>>> Then those requirements can drive dropping things not covered by sequenced
>>>> initialization and finer tuning.
>>>> Using printk saves a lot of memory.
>>>> >And I
>>>> >added -Os flag. However when building ticker, the .text area overflows
>>>> >the 32KB local memory by about 8KB.
>>>> >The question is, what are the very basic mandatory sources/libraries
>>>> >and/or managers that are enough to build ticker?
>>>> Some of that is stack size in ticker. Look at the ticker variants in
>>>> examples-v2
>>>> >Regards,
>>>> >Hesham
>>>> >_______________________________________________
>>>> >devel mailing list
>>>> >devel at rtems.org
>>>> >http://lists.rtems.org/mailman/listinfo/devel
>>>> --joel
>>>> devel mailing list
>>>> devel at rtems.org
>>> Daniel F. Gutson
>>> Chief Engineering Officer, SPD
>>> San Lorenzo 47, 3rd Floor, Office 5
>>> Córdoba, Argentina
>>> Phone:   +54 351 4217888 / +54 351 4218211
>>> Skype:    dgutson
>>> LinkedIn: http://ar.linkedin.com/in/danielgutson
>> <http://www.tallertechnologies.com>
>> Marcos Díaz
>> Software Engineer
>> Córdoba, Argentina
>> Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
>> Skype: markdiaz22
> Daniel F. Gutson
> Córdoba, Argentina
> Skype:    dgutson
Marcos Díaz
Software Engineer
Córdoba, Argentina
Skype: markdiaz22
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141217/04460b04/attachment-0002.html>
