Reducing RTEMS size to <32KB to fit in Epiphany local memories
Marcos Díaz marcos.diaz at tallertechnologies.com
Thu Dec 18 18:40:23 UTC 2014
On Thu, Dec 18, 2014 at 6:34 AM, Hesham Moustafa <heshamelmatary at gmail.com>
wrote:
> Hi all,
> Thanks for all your helpful replies. I actually tried all the solution
> you mentioned: used printk, low-ticker (from example-v2), disabled
> newlib reentrancy (part of low-ticker configuration). I managed to get
> <32KB ticker with GCC optimization enabled (-Os), but I got some
> exceptions during initialization, however, the same code built without
> optimization (-O0) runs OK, but it's about 80KB.
> Marcos and Daniel, it's surprising that you got 9KB RTEMS, how did you
> do this (without the application optimizations and stacks) what APIs,
> managers, and CPUKIT code did you use, and what others did you give
> up?
My bad, since we were having problems with using RTEMS in an environment
with 32kb of RAM but with much more ROM, I though you had the same problem.
That size was of the used RAM (data, vector and bss sections) not of the
total used space.
Sorry about that.
> Sebastian, the 32KB is for both code and data. Although there is 32MB
> external memory, it's very slow compared with local memories. The idea
> of getting rid of workspace appeals to me. Does this include
> discarding malloc, heap stuff? And how can this be done?
> Thanks,
> Hesham
> On Thu, Dec 18, 2014 at 7:58 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > Hello,
> > is this 32KiB for code and data?
> > You should also disable the Newlib reentrancy:
> > #define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
> > Try to add:
> > CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
> > LDFLAGS = -Wl,--gc-sections
> > to the *.cfg file of the BSP.  You need a proper linker command file to
> use
> > these options.
> > Avoid printf() and instead use printk() or no output.
> > For a really small RTEMS we need the constructor based initialization.
> We
> > should probably also get rid of the workspace and use static
> initialization
> > only.
> > On 17/12/14 17:00, Hesham Moustafa wrote:
> >> Hi all,
> >> I am working on reducing RTEMS size to fit into <32KB as every Epiphay
> >> core has only 32KB of local memory. I was able to get hello and
> >> minimum samples with aggressive size reduction by manually removing
> >> un-needed code. Currently I only use libcsupport, sapi, score, rtems
> >> built for cpukit only, and for each, some source code files were
> >> removed. No IO, no FS, no barrier, event, managers are included. And I
> >> added -Os flag. However when building ticker, the .text area overflows
> >> the 32KB local memory by about 8KB.
> >> The question is, what are the very basic mandatory sources/libraries
> >> and/or managers that are enough to build ticker?
> >> Regards,
> >> Hesham
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone   : +49 89 189 47 41-16
> > Fax     : +49 89 189 47 41-09
> > E-Mail  : sebastian.huber at embedded-brains.de
> > PGP     : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> devel mailing list
> devel at rtems.org
<http://www.tallertechnologies.com>
Marcos Díaz
Software Engineer
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: +54 351 4217888 / +54 351 4218211/ +54 351 7617452
Skype: markdiaz22
URL: <http://lists.rtems.org/pipermail/devel/attachments/20141218/3cd04353/attachment-0002.html>
