smp test failures on using grsim
Jennifer Averett Jennifer.Averett at OARcorp.com
Tue Feb 4 15:11:13 UTC 2014
On a little debugging one or more cpu's are calling
BSP_fatal_return from _Thread_Handler.  This results
the program not returning to grsim, and the program
does not terminate.  Sometimes the other cpu's are
running idle task sometimes all cpus have the
BSP_fatal_return call.
> -----Original Message-----
> From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
> Sent: Tuesday, February 04, 2014 7:51 AM
> To: Jennifer Averett
> Cc: rtems-devel at rtems.org
> Subject: Re: smp test failures on using grsim
> Hello Jennifer,
> I executed the tests on a real NGMP evaluation board.  All tests run
> successfully.  See attached log file.
> What do you mean with "Locks"?
