[PATCH] score: Change debug helper functions
Sebastian Huber
Fri Feb 7 09:10:19 UTC 2014
Rename rtems_internal_error_description() to
rtems_internal_error_text(). Rename rtems_fatal_source_description() to
rtems_fatal_source_text(). Rename rtems_status_code_description() to
rtems_status_text(). Remove previous implementation of
c/src/lib/libbsp/powerpc/shared/startup/panic.c | 2 +-
cpukit/libcsupport/include/rtems/error.h | 2 -
cpukit/libcsupport/src/error.c | 42 --------------
cpukit/rtems/Makefile.am | 2 +-
cpukit/rtems/include/rtems/rtems/status.h | 10 ++-
cpukit/rtems/src/statusdesc.c | 69 -----------------------
cpukit/rtems/src/statustext.c | 69 +++++++++++++++++++++++
cpukit/sapi/Makefile.am | 4 +-
cpukit/sapi/include/rtems/fatal.h | 20 ++++---
cpukit/sapi/src/fatalsrcdesc.c | 53 -----------------
cpukit/sapi/src/fatalsrctext.c | 53 +++++++++++++++++
cpukit/sapi/src/interrdesc.c | 67 ----------------------
cpukit/sapi/src/interrtext.c | 67 ++++++++++++++++++++++
doc/user/Makefile.am | 2 +-
doc/user/dirstat.t | 13 ++--
doc/user/fatal.t | 22 ++++---
testsuites/psxtests/psxfatal_support/init.c | 4 +-
testsuites/sptests/spfatal_support/init.c | 4 +-
testsuites/sptests/spinternalerror02/init.c | 48 ++++++++--------
19 files changed, 258 insertions(+), 295 deletions(-)
delete mode 100644 cpukit/rtems/src/statusdesc.c
create mode 100644 cpukit/rtems/src/statustext.c
delete mode 100644 cpukit/sapi/src/fatalsrcdesc.c
create mode 100644 cpukit/sapi/src/fatalsrctext.c
delete mode 100644 cpukit/sapi/src/interrdesc.c
create mode 100644 cpukit/sapi/src/interrtext.c
diff --git a/c/src/lib/libbsp/powerpc/shared/startup/panic.c b/c/src/lib/libbsp/powerpc/shared/startup/panic.c
index 4553f77..f832054 100644
--- a/c/src/lib/libbsp/powerpc/shared/startup/panic.c
+++ b/c/src/lib/libbsp/powerpc/shared/startup/panic.c
@@ -39,7 +39,7 @@ void _BSP_Fatal_error(unsigned int v)
switch (THESRC) {
case INTERNAL_ERROR_CORE:
printk(" RTEMS Core\n");
- err = rtems_internal_error_description(THEERR);
+ err = rtems_internal_error_text(THEERR);
break;
case INTERNAL_ERROR_RTEMS_API:
diff --git a/cpukit/libcsupport/include/rtems/error.h b/cpukit/libcsupport/include/rtems/error.h
index 9556763..cbcfa98 100644
--- a/cpukit/libcsupport/include/rtems/error.h
+++ b/cpukit/libcsupport/include/rtems/error.h
@@ -84,8 +84,6 @@ typedef Internal_errors_t rtems_error_code_t;
#define RTEMS_ERROR_MASK \
(RTEMS_ERROR_ERRNO | RTEMS_ERROR_ABORT | RTEMS_ERROR_PANIC) /* all */
-const char *rtems_status_text(rtems_status_code sc);
* @brief Report an Error
diff --git a/cpukit/libcsupport/src/error.c b/cpukit/libcsupport/src/error.c
index 0e63fa4..81ddae2 100644
--- a/cpukit/libcsupport/src/error.c
+++ b/cpukit/libcsupport/src/error.c
@@ -24,48 +24,6 @@
int rtems_panic_in_progress;
-const rtems_assoc_t rtems_status_assoc[] = {
- { "successful completion", RTEMS_SUCCESSFUL, 0 },
- { "returned from a thread", RTEMS_TASK_EXITTED, 0 },
- { "multiprocessing not configured", RTEMS_MP_NOT_CONFIGURED, 0 },
- { "invalid object name", RTEMS_INVALID_NAME, 0 },
- { "invalid object id", RTEMS_INVALID_ID, 0 },
- { "too many", RTEMS_TOO_MANY, 0 },
- { "timed out waiting", RTEMS_TIMEOUT, 0 },
- { "object deleted while waiting", RTEMS_OBJECT_WAS_DELETED, 0 },
- { "specified size was invalid", RTEMS_INVALID_SIZE, 0 },
- { "address specified is invalid", RTEMS_INVALID_ADDRESS, 0 },
- { "number was invalid", RTEMS_INVALID_NUMBER, 0 },
- { "item has not been initialized", RTEMS_NOT_DEFINED, 0 },
- { "resources still outstanding", RTEMS_RESOURCE_IN_USE, 0 },
- { "request not satisfied", RTEMS_UNSATISFIED, 0 },
- { "thread is in wrong state", RTEMS_INCORRECT_STATE, 0 },
- { "thread already in state", RTEMS_ALREADY_SUSPENDED, 0 },
- { "illegal on calling thread", RTEMS_ILLEGAL_ON_SELF, 0 },
- { "illegal for remote object", RTEMS_ILLEGAL_ON_REMOTE_OBJECT, 0 },
- { "called from wrong environment", RTEMS_CALLED_FROM_ISR, 0 },
- { "invalid thread priority", RTEMS_INVALID_PRIORITY, 0 },
- { "invalid date/time", RTEMS_INVALID_CLOCK, 0 },
- { "invalid node id", RTEMS_INVALID_NODE, 0 },
- { "directive not configured", RTEMS_NOT_CONFIGURED, 0 },
- { "not owner of resource", RTEMS_NOT_OWNER_OF_RESOURCE , 0 },
- { "directive not implemented", RTEMS_NOT_IMPLEMENTED, 0 },
- { "RTEMS inconsistency detected", RTEMS_INTERNAL_ERROR, 0 },
- { "could not get enough memory", RTEMS_NO_MEMORY, 0 },
- { "driver IO error", RTEMS_IO_ERROR, 0 },
- { "internal multiprocessing only", THREAD_STATUS_PROXY_BLOCKING, 0 },
- { 0, 0, 0 },
- rtems_status_code status
- return rtems_assoc_name_by_local(rtems_status_assoc, status);
int rtems_verror(
rtems_error_code_t error_flag,
const char *printf_format,
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index f219db8..6688317 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -255,7 +255,7 @@ librtems_a_SOURCES += src/workspacegreedy.c
librtems_a_SOURCES += src/modes.c
librtems_a_SOURCES += src/status.c
-librtems_a_SOURCES += src/statusdesc.c
+librtems_a_SOURCES += src/statustext.c
if HAS_MP
# We only build multiprocessing related files if HAS_MP was defined
diff --git a/cpukit/rtems/include/rtems/rtems/status.h b/cpukit/rtems/include/rtems/rtems/status.h
index 19df500..f82b1f4 100644
--- a/cpukit/rtems/include/rtems/rtems/status.h
+++ b/cpukit/rtems/include/rtems/rtems/status.h
@@ -242,14 +242,16 @@ RTEMS_INLINE_ROUTINE bool rtems_are_statuses_equal(
int rtems_status_code_to_errno(rtems_status_code sc);
- * @brief Returns a description for a status code.
+ * @brief Returns a text for a status code.
+ * The text for each status code is the enumerator constant.
* @param[in] code The status code.
- * @retval description The status code description.
- * @retval ? The passed status code is invalid.
+ * @retval text The status code text.
+ * @retval "?" The passed status code is invalid.
-const char *rtems_status_code_description( rtems_status_code code );
+const char *rtems_status_text( rtems_status_code code );
diff --git a/cpukit/rtems/src/statusdesc.c b/cpukit/rtems/src/statusdesc.c
deleted file mode 100644
index 4cc426d..0000000
--- a/cpukit/rtems/src/statusdesc.c
+++ /dev/null
@@ -1,69 +0,0 @@
- * @file
- * @ingroup ClassicStatus
- * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
- * embedded brains GmbH
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.com/license/LICENSE.
-#if HAVE_CONFIG_H
- #include "config.h"
-#endif
-#include <rtems.h>
-static const char *const status_code_desc[] = {
- "RTEMS_SUCCESSFUL",
- "RTEMS_TASK_EXITTED",
- "RTEMS_MP_NOT_CONFIGURED",
- "RTEMS_INVALID_NAME",
- "RTEMS_INVALID_ID",
- "RTEMS_TOO_MANY",
- "RTEMS_TIMEOUT",
- "RTEMS_OBJECT_WAS_DELETED",
- "RTEMS_INVALID_SIZE",
- "RTEMS_INVALID_ADDRESS",
- "RTEMS_INVALID_NUMBER",
- "RTEMS_NOT_DEFINED",
- "RTEMS_RESOURCE_IN_USE",
- "RTEMS_UNSATISFIED",
- "RTEMS_INCORRECT_STATE",
- "RTEMS_ALREADY_SUSPENDED",
- "RTEMS_ILLEGAL_ON_SELF",
- "RTEMS_ILLEGAL_ON_REMOTE_OBJECT",
- "RTEMS_CALLED_FROM_ISR",
- "RTEMS_INVALID_PRIORITY",
- "RTEMS_INVALID_CLOCK",
- "RTEMS_INVALID_NODE",
- "RTEMS_NOT_CONFIGURED",
- "RTEMS_NOT_OWNER_OF_RESOURCE",
- "RTEMS_NOT_IMPLEMENTED",
- "RTEMS_INTERNAL_ERROR",
- "RTEMS_NO_MEMORY",
- "RTEMS_IO_ERROR",
- "RTEMS_PROXY_BLOCKING"
- size_t i = code;
- const char *desc = "?";
- if ( i < RTEMS_ARRAY_SIZE( status_code_desc ) ) {
- desc = status_code_desc [i];
- return desc;
diff --git a/cpukit/rtems/src/statustext.c b/cpukit/rtems/src/statustext.c
new file mode 100644
index 0000000..bdb91bb
--- /dev/null
+++ b/cpukit/rtems/src/statustext.c
@@ -0,0 +1,69 @@
+ * @file
+ * @ingroup ClassicStatus
+ * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems.h>
+static const char *const status_code_text[] = {
+ "RTEMS_SUCCESSFUL",
+ "RTEMS_TASK_EXITTED",
+ "RTEMS_MP_NOT_CONFIGURED",
+ "RTEMS_INVALID_NAME",
+ "RTEMS_INVALID_ID",
+ "RTEMS_TOO_MANY",
+ "RTEMS_TIMEOUT",
+ "RTEMS_OBJECT_WAS_DELETED",
+ "RTEMS_INVALID_SIZE",
+ "RTEMS_INVALID_ADDRESS",
+ "RTEMS_INVALID_NUMBER",
+ "RTEMS_NOT_DEFINED",
+ "RTEMS_RESOURCE_IN_USE",
+ "RTEMS_UNSATISFIED",
+ "RTEMS_INCORRECT_STATE",
+ "RTEMS_ALREADY_SUSPENDED",
+ "RTEMS_ILLEGAL_ON_SELF",
+ "RTEMS_ILLEGAL_ON_REMOTE_OBJECT",
+ "RTEMS_CALLED_FROM_ISR",
+ "RTEMS_INVALID_PRIORITY",
+ "RTEMS_INVALID_CLOCK",
+ "RTEMS_INVALID_NODE",
+ "RTEMS_NOT_CONFIGURED",
+ "RTEMS_NOT_OWNER_OF_RESOURCE",
+ "RTEMS_NOT_IMPLEMENTED",
+ "RTEMS_INTERNAL_ERROR",
+ "RTEMS_NO_MEMORY",
+ "RTEMS_IO_ERROR",
+ "RTEMS_PROXY_BLOCKING"
+ size_t i = code;
+ const char *text = "?";
+ if ( i < RTEMS_ARRAY_SIZE( status_code_text ) ) {
+ text = status_code_text [i];
+ return text;
diff --git a/cpukit/sapi/Makefile.am b/cpukit/sapi/Makefile.am
index d7df541..7159208 100644
--- a/cpukit/sapi/Makefile.am
+++ b/cpukit/sapi/Makefile.am
@@ -30,8 +30,8 @@ libsapi_a_SOURCES = src/debug.c src/extension.c src/extensioncreate.c \
src/iounregisterdriver.c src/iowrite.c src/posixapi.c \
src/rtemsapi.c src/extensiondata.c src/getversionstring.c \
src/chainappendnotify.c src/chaingetnotify.c src/chaingetwait.c \
- src/chainprependnotify.c src/rbheap.c src/interrdesc.c \
- src/fatal2.c src/fatalsrcdesc.c
+ src/chainprependnotify.c src/rbheap.c src/interrtext.c \
+ src/fatal2.c src/fatalsrctext.c
libsapi_a_SOURCES += src/chainsmp.c
libsapi_a_SOURCES += src/delaycpu.c
libsapi_a_SOURCES += src/delaymicro.c
diff --git a/cpukit/sapi/include/rtems/fatal.h b/cpukit/sapi/include/rtems/fatal.h
index 47bf74f..1230182 100644
--- a/cpukit/sapi/include/rtems/fatal.h
+++ b/cpukit/sapi/include/rtems/fatal.h
@@ -86,24 +86,28 @@ void rtems_fatal(
) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
- * @brief Returns a description for a fatal source.
+ * @brief Returns a text for a fatal source.
+ * The text for each fatal source is the enumerator constant.
* @param[in] source is the fatal source.
- * @retval description The fatal source description.
- * @retval ? The passed fatal source is invalid.
+ * @retval text The fatal source text.
+ * @retval "?" The passed fatal source is invalid.
-const char *rtems_fatal_source_description( rtems_fatal_source source );
+const char *rtems_fatal_source_text( rtems_fatal_source source );
- * @brief Returns a description for an internal error code.
+ * @brief Returns a text for an internal error code.
+ * The text for each internal error code is the enumerator constant.
* @param[in] error is the error code.
- * @retval description The error code description.
- * @retval ? The passed error code is invalid.
+ * @retval text The error code text.
+ * @retval "?" The passed error code is invalid.
-const char *rtems_internal_error_description( rtems_fatal_code error );
+const char *rtems_internal_error_text( rtems_fatal_code error );
diff --git a/cpukit/sapi/src/fatalsrcdesc.c b/cpukit/sapi/src/fatalsrcdesc.c
index fbe8485..0000000
--- a/cpukit/sapi/src/fatalsrcdesc.c
+++ /dev/null
@@ -1,53 +0,0 @@
- * @file
- * @brief Implementation of rtems_fatal_source_description()
- * @ingroup ClassicFatal
- * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
- * Obere Lagerstr. 30
- * 82178 Puchheim
- * Germany
-#if HAVE_CONFIG_H
-#endif
-#include <rtems/fatal.h>
-static const char *const fatal_source_desc [] = {
- "INTERNAL_ERROR_CORE",
- "INTERNAL_ERROR_RTEMS_API",
- "INTERNAL_ERROR_POSIX_API",
- "RTEMS_FATAL_SOURCE_BDBUF",
- "RTEMS_FATAL_SOURCE_APPLICATION",
- "RTEMS_FATAL_SOURCE_EXIT",
- "RTEMS_FATAL_SOURCE_BSP_GENERIC",
- "RTEMS_FATAL_SOURCE_BSP_SPECIFIC",
- "RTEMS_FATAL_SOURCE_ASSERT",
- "RTEMS_FATAL_SOURCE_STACK_CHECKER",
- "RTEMS_FATAL_SOURCE_EXCEPTION"
- size_t i = source;
- if ( i < RTEMS_ARRAY_SIZE( fatal_source_desc ) ) {
- desc = fatal_source_desc [i];
- return desc;
diff --git a/cpukit/sapi/src/fatalsrctext.c b/cpukit/sapi/src/fatalsrctext.c
index 0000000..902a269
--- /dev/null
+++ b/cpukit/sapi/src/fatalsrctext.c
@@ -0,0 +1,53 @@
+ * @file
+ * @brief Implementation of rtems_fatal_source_text()
+ * @ingroup ClassicFatal
+ * Copyright (c) 2013-2014 embedded brains GmbH. All rights reserved.
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#if HAVE_CONFIG_H
+#endif
+#include <rtems/fatal.h>
+static const char *const fatal_source_text[] = {
+ "INTERNAL_ERROR_CORE",
+ "INTERNAL_ERROR_RTEMS_API",
+ "INTERNAL_ERROR_POSIX_API",
+ "RTEMS_FATAL_SOURCE_BDBUF",
+ "RTEMS_FATAL_SOURCE_APPLICATION",
+ "RTEMS_FATAL_SOURCE_EXIT",
+ "RTEMS_FATAL_SOURCE_BSP_GENERIC",
+ "RTEMS_FATAL_SOURCE_BSP_SPECIFIC",
+ "RTEMS_FATAL_SOURCE_ASSERT",
+ "RTEMS_FATAL_SOURCE_STACK_CHECKER",
+ "RTEMS_FATAL_SOURCE_EXCEPTION"
+ size_t i = source;
+ if ( i < RTEMS_ARRAY_SIZE( fatal_source_text ) ) {
+ text = fatal_source_text[ i ];
+ return text;
diff --git a/cpukit/sapi/src/interrdesc.c b/cpukit/sapi/src/interrdesc.c
index 5301475..0000000
--- a/cpukit/sapi/src/interrdesc.c
+++ /dev/null
@@ -1,67 +0,0 @@
- * @file
- * Copyright (c) 2012 embedded brains GmbH. All rights reserved.
- * 82178 Puchheim
- * Germany
-#if HAVE_CONFIG_H
-#endif
-static const char *const internal_error_desc [] = {
- "INTERNAL_ERROR_NO_CONFIGURATION_TABLE",
- "INTERNAL_ERROR_NO_CPU_TABLE",
- "INTERNAL_ERROR_TOO_LITTLE_WORKSPACE",
- "INTERNAL_ERROR_WORKSPACE_ALLOCATION",
- "INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL",
- "INTERNAL_ERROR_THREAD_EXITTED",
- "INTERNAL_ERROR_INCONSISTENT_MP_INFORMATION",
- "INTERNAL_ERROR_INVALID_NODE",
- "INTERNAL_ERROR_NO_MPCI",
- "INTERNAL_ERROR_BAD_PACKET",
- "INTERNAL_ERROR_OUT_OF_PACKETS",
- "INTERNAL_ERROR_OUT_OF_GLOBAL_OBJECTS",
- "INTERNAL_ERROR_OUT_OF_PROXIES",
- "INTERNAL_ERROR_INVALID_GLOBAL_ID",
- "INTERNAL_ERROR_BAD_STACK_HOOK",
- "INTERNAL_ERROR_BAD_ATTRIBUTES",
- "INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY",
- "INTERNAL_ERROR_IMPLEMENTATION_BLOCKING_OPERATION_CANCEL",
- "INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE",
- "INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0",
- "INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP",
- "INTERNAL_ERROR_GXX_KEY_ADD_FAILED",
- "INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED",
- "INTERNAL_ERROR_NO_MEMORY_FOR_HEAP",
- "INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR"
- size_t i = error;
- if ( i < RTEMS_ARRAY_SIZE( internal_error_desc ) ) {
- desc = internal_error_desc [i];
- return desc;
diff --git a/cpukit/sapi/src/interrtext.c b/cpukit/sapi/src/interrtext.c
index 0000000..a66add5
--- /dev/null
+++ b/cpukit/sapi/src/interrtext.c
@@ -0,0 +1,67 @@
+ * @file
+ * Copyright (c) 2012-2014 embedded brains GmbH. All rights reserved.
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#if HAVE_CONFIG_H
+#endif
+static const char *const internal_error_text[] = {
+ "INTERNAL_ERROR_NO_CONFIGURATION_TABLE",
+ "INTERNAL_ERROR_NO_CPU_TABLE",
+ "INTERNAL_ERROR_TOO_LITTLE_WORKSPACE",
+ "INTERNAL_ERROR_WORKSPACE_ALLOCATION",
+ "INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL",
+ "INTERNAL_ERROR_THREAD_EXITTED",
+ "INTERNAL_ERROR_INCONSISTENT_MP_INFORMATION",
+ "INTERNAL_ERROR_INVALID_NODE",
+ "INTERNAL_ERROR_NO_MPCI",
+ "INTERNAL_ERROR_BAD_PACKET",
+ "INTERNAL_ERROR_OUT_OF_PACKETS",
+ "INTERNAL_ERROR_OUT_OF_GLOBAL_OBJECTS",
+ "INTERNAL_ERROR_OUT_OF_PROXIES",
+ "INTERNAL_ERROR_INVALID_GLOBAL_ID",
+ "INTERNAL_ERROR_BAD_STACK_HOOK",
+ "INTERNAL_ERROR_BAD_ATTRIBUTES",
+ "INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY",
+ "INTERNAL_ERROR_IMPLEMENTATION_BLOCKING_OPERATION_CANCEL",
+ "INTERNAL_ERROR_MUTEX_OBTAIN_FROM_BAD_STATE",
+ "INTERNAL_ERROR_UNLIMITED_AND_MAXIMUM_IS_0",
+ "INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP",
+ "INTERNAL_ERROR_GXX_KEY_ADD_FAILED",
+ "INTERNAL_ERROR_GXX_MUTEX_INIT_FAILED",
+ "INTERNAL_ERROR_NO_MEMORY_FOR_HEAP",
+ "INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR"
+ size_t i = error;
+ if ( i < RTEMS_ARRAY_SIZE( internal_error_text ) ) {
+ text = internal_error_text[ i ];
+ return text;
diff --git a/doc/user/Makefile.am b/doc/user/Makefile.am
index 1b6ddcb..eec627a 100644
--- a/doc/user/Makefile.am
+++ b/doc/user/Makefile.am
@@ -144,7 +144,7 @@ fatal.texi: fatal.t
-n "Board Support Packages" < $< > $@
bsp.texi: bsp.t
- $(BMENU2) -p "Fatal Error Manager INTERNAL_ERROR_DESCRIPTION - Returns a description for an internal error code" \
+ $(BMENU2) -p "Fatal Error Manager INTERNAL_ERROR_TEXT - Returns a text for an internal error code" \
-u "Top" \
-n "User Extensions Manager" < $< > $@
diff --git a/doc/user/dirstat.t b/doc/user/dirstat.t
index adb675d..ea33883 100644
--- a/doc/user/dirstat.t
+++ b/doc/user/dirstat.t
@@ -40,16 +40,14 @@
@section Directives
@page
- at subsection STATUS_CODE_DESCRIPTION - Returns a description for a status code
- at cindex fatal error
+ at subsection STATUS_CODE_TEXT - Returns a text for a status code
@subheading CALLING SEQUENCE:
@ifset is-C
- at findex rtems_status_code_description
+ at findex rtems_status_code_text
@example
+const char *rtems_status_code_text(
@end example
@@ -57,8 +55,9 @@ const char *rtems_status_code_description(
@subheading DIRECTIVE STATUS CODES
-The status code description or "?" in case the passed status code is invalid.
+The status code text or "?" in case the passed status code is invalid.
@subheading DESCRIPTION:
-Returns a description for a status code.
+Returns a text for a status code. The text for each status code is the
+enumerator constant.
diff --git a/doc/user/fatal.t b/doc/user/fatal.t
index 20faa64..61e5261 100644
--- a/doc/user/fatal.t
+++ b/doc/user/fatal.t
@@ -230,16 +230,16 @@ Prints the exception frame via printk().
@c
@c
@page
- at subsection FATAL_SOURCE_DESCRIPTION - Returns a description for a fatal source
+ at subsection FATAL_SOURCE_TEXT - Returns a text for a fatal source
@cindex fatal error
@ifset is-C
- at findex rtems_fatal_source_description
+ at findex rtems_fatal_source_text
@example
@end example
@@ -247,26 +247,27 @@ const char *rtems_fatal_source_description(
-The fatal source description or "?" in case the passed fatal source is invalid.
+The fatal source text or "?" in case the passed fatal source is invalid.
-Returns a description for a fatal source.
+Returns a text for a fatal source. The text for fatal source is the enumerator
+constant.
@c
@c
@c
@page
- at subsection INTERNAL_ERROR_DESCRIPTION - Returns a description for an internal error code
+ at subsection INTERNAL_ERROR_TEXT - Returns a text for an internal error code
@cindex fatal error
@ifset is-C
- at findex rtems_internal_error_description
+ at findex rtems_internal_error_text
@example
@end example
@@ -274,8 +275,9 @@ const char *rtems_internal_error_description(
-The error code description or "?" in case the passed error code is invalid.
+The error code text or "?" in case the passed error code is invalid.
-Returns a description for an internal error code.
+Returns a text for an internal error code. The text for each internal error
+code is the enumerator constant.
diff --git a/testsuites/psxtests/psxfatal_support/init.c b/testsuites/psxtests/psxfatal_support/init.c
index 93645e6..ce83027 100644
--- a/testsuites/psxtests/psxfatal_support/init.c
+++ b/testsuites/psxtests/psxfatal_support/init.c
@@ -65,7 +65,7 @@ char *Errors_Rtems[] = {
void Put_Error( uint32_t source, uint32_t error )
if ( source == INTERNAL_ERROR_CORE ) {
- printk( rtems_internal_error_description( error ) );
+ printk( rtems_internal_error_text( error ) );
else if (source == INTERNAL_ERROR_RTEMS_API ){
if (error > RTEMS_NOT_IMPLEMENTED )
@@ -80,7 +80,7 @@ void Put_Error( uint32_t source, uint32_t error )
void Put_Source( rtems_fatal_source source )
- printk( "%s", rtems_fatal_source_description( source ) );
+ printk( "%s", rtems_fatal_source_text( source ) );
void Fatal_extension(
diff --git a/testsuites/sptests/spfatal_support/init.c b/testsuites/sptests/spfatal_support/init.c
index 216c766..dfea488 100644
--- a/testsuites/sptests/spfatal_support/init.c
+++ b/testsuites/sptests/spfatal_support/init.c
@@ -77,7 +77,7 @@ void Put_Error( uint32_t source, uint32_t error )
static bool is_expected_error( rtems_fatal_code error )
diff --git a/testsuites/sptests/spinternalerror02/init.c b/testsuites/sptests/spinternalerror02/init.c
index b08a7d4..0d07fab 100644
--- a/testsuites/sptests/spinternalerror02/init.c
+++ b/testsuites/sptests/spinternalerror02/init.c
@@ -20,50 +20,50 @@
-static void test_internal_error_description(void)
+static void test_internal_error_text(void)
rtems_fatal_code error = 0;
- const char *desc = NULL;
- const char *desc_last;
+ const char *text = NULL;
+ const char *text_last;
do {
- desc_last = desc;
- desc = rtems_internal_error_description( error );
+ text_last = text;
+ text = rtems_internal_error_text( error );
++error;
- puts( desc );
- } while ( desc != desc_last );
+ puts( text );
+ } while ( text != text_last );
rtems_test_assert( error - 3 == INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR );
-static void test_fatal_source_description(void)
+static void test_fatal_source_text(void)
rtems_fatal_source source = 0;
do {
- desc_last = desc;
- desc = rtems_fatal_source_description( source );
+ text_last = text;
+ text = rtems_fatal_source_text( source );
++source;
- puts( desc );
+ puts( text );
rtems_test_assert( source - 3 == RTEMS_FATAL_SOURCE_EXCEPTION );
-static void test_status_code_description(void)
+static void test_status_text(void)
rtems_status_code code = 0;
do {
- desc_last = desc;
- desc = rtems_status_code_description( code );
+ text_last = text;
+ text = rtems_status_text( code );
++code;
- puts( desc );
+ puts( text );
rtems_test_assert( code - 3 == RTEMS_PROXY_BLOCKING );
@@ -72,9 +72,9 @@ static void Init(rtems_task_argument arg)
puts("\n\n*** TEST SPINTERNALERROR 2 ***");
- test_internal_error_description();
- test_fatal_source_description();
- test_status_code_description();
+ test_internal_error_text();
+ test_fatal_source_text();
+ test_status_text();
puts("*** END OF TEST SPINTERNALERROR 2 ***");
1.7.7
