LEON3 Clock and Timer Driver
Tue Feb 11 08:46:58 UTC 2014
Hello,
the LEON3 clock and timer driver use both LEON3_Timer_Regs (usually GPTIMER 0).
In separate source files we have
http://git.rtems.org/rtems/tree/c/src/lib/libbsp/sparc/leon3/clock/ckinit.c#n33
#if defined(RTEMS_MULTIPROCESSING)
   #define LEON3_CLOCK_INDEX \
     (rtems_configuration_get_user_multiprocessing_table() ? LEON3_Cpu_Index : 0)
#else
   #define LEON3_CLOCK_INDEX 0
#endif
and
http://git.rtems.org/rtems/tree/c/src/lib/libbsp/sparc/leon3/timer/timer.c#n24
   #define LEON3_TIMER_INDEX \
       ((rtems_configuration_get_user_multiprocessing_table()) ? \
         (rtems_configuration_get_user_multiprocessing_table()->node) - 1 : 1)
#else
   #define LEON3_TIMER_INDEX 0
#endif
So we cannot use a clock and timer driver at the same time.  Is this intentional?
Why are there different methods used to select the index in the
RTEMS_MULTIPROCESSING case?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
