Software License Hint after RTEMS.ORG and RTEMS.COM Domain Announcement
Ralf Kirchner
ralf.kirchner at embedded-brains.de
Tue Feb 11 10:33:08 UTC 2014
Hi All,
I just noticed that a lot of our files cotain license hints which point
to "http://www.rtems.com/license/LICENSE".
I think with Joels RTEMS.ORG and RTEMS.COM Domain Announcement (see
below) these all should get changed to
"http://www.rtems.org/license/LICENSE"
Kind Regards
Ralf Kirchner
Am 05.12.2013 19:51, schrieb Joel Sherrill:
> Hi
> I am trying to get the news out since the new DNS change goes into effect Friday. Currently RTEMS.ORG and RTEMS.COM point to the same machine, same services, and same content. The RTEMS.ORG and RTEMS.COM domains are being moved to separate machines.
> + The RTEMS Community will continue to operate under the RTEMS.ORG site as it always has.
> + The RTEMS.COM site will be used provide information concerning OAR’s RTEMS Services and Products.
> If you have used the RTEMS.COM site for any RTEMS Project and Community resource, please update this to RTEMS.ORG.
> There is good stuff in the works and this is the one of the steps in the process. :)
> Thanks.
> --joel sherrill
> rtems-users mailing list
> rtems-users at rtems.org
Embedded Brains GmbH
Ralf Kirchner Dornierstr. 4
D-82178 Puchheim Germany
email: ralf.kirchner at embedded-brains.de
Phone: +49-89-18 94 741-17
Fax: +49-89-18 94 741-08
