[PATCH v2] score: Add CPU counter support
Wed Feb 12 12:56:45 UTC 2014
On 2014-02-12 13:38, Chris Johns wrote:
> On 12/02/2014 8:27 pm, Sebastian Huber wrote:
>> Add a CPU counter interface to allow access to a free-running counter.
>> It is useful to measure short time intervals.
> What is meant by a short time interval and also what would a long time mean ?
This actual time interval is CPU/BSP dependent.  The interval should at least
cover a system tick.
> Is an overflow or wrap around status available and/or important ?
A overflow of the counter register will happen on most systems.  Thus we use an
unsigned integer type since here modulo arithmetic is defined.  Also the
implementation must provide the _CPU_Counter_Subtract() function.  Some smaller
ARM controllers have for example only 24-bit timers.
>> This can be used for
>> example to enable profiling of critical low-level functions.
> Why use this rather than the existing rtems_clock_get_uptime_nanoseconds ?
> Are you looking at sub-nano second times ?
The overhead to use rtems_clock_get_uptime_nanoseconds() is too high.  Also
this counter should work without a clock driver and during system initialization.
Also what happens if your driver using the busy wait is initialized before the
clock driver, etc.?
The step from CPU counter ticks to/from nanoseconds is explicit in this API
unlike to rtems_clock_get_uptime_nanoseconds().
How do you profile the spinlock used by rtems_clock_get_uptime_nanoseconds()?
> I would be concerned about trace data based on this unless the over was handled
> or interrupts are masked.
>> Add two busy wait functions rtems_counter_delay_ticks() and
>> rtems_counter_delay_nanoseconds() implemented via the CPU counter.
> How is the user protected in a portable way across different cpus ?
Protected against what?
> Is there range checking or is overflows used ?
The range is limited by the parameter integer types.
> Are the calls re-entrant ?
What do you mean with re-entrant here?
>> diff --git a/doc/cpu_supplement/general.t b/doc/cpu_supplement/general.t
>> index cf28eef..3608705 100644
>> --- a/doc/cpu_supplement/general.t
>> +++ b/doc/cpu_supplement/general.t
>> @@ -341,6 +341,26 @@ _TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
>>   _TLS_Alignment = ALIGNOF (.tdata);
>>   @end example
>> + at section CPU counter
>> +The CPU support must implement the CPU counter interface.  A CPU counter is
>> +some free-running counter.  It ticks usually with a frequency close to the CPU
>> +or system bus clock.  On some architectures the actual implementation is board
>> +support package dependent.  The CPU counter is used for profiling of low-level
>> +functions.  It is also used to implement two busy wait functions
>> + at code{rtems_counter_delay_ticks()} and @code{rtems_counter_delay_nanoseconds()}
>> +which may be used in device drivers.  It may be also used as an entropy source
>> +for random number generators.
>> +The CPU counter interface uses a CPU port specific unsigned integer type
>> + at code{CPU_Counter_Ticks} to represent CPU counter values.  The CPU port must
>> +provide the following two functions
>> + at itemize
>> + at item @code{_CPU_counter_Read()} to read the current CPU counter value, and
>> + at item @code{_CPU_counter_Subtract()} to subtract two the CPU counter values.
>> + at end itemize
> Is overflows handled in the maths ? I could not see it if important.
> Should the user be able to ask the range of the counter ?
The only useful operation with values obtained by _CPU_counter_Read() is
_CPU_counter_Subtract().
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
