[PATCH] score: Add CPU counter support
Wed Feb 12 14:49:48 UTC 2014
Sebastian,
On Wed, Feb 12, 2014 at 8:40 AM, Sebastian Huber
> On 2014-02-12 09:43, Sebastian Huber wrote:
>>> I'm not quite sure about the _CPU_ interfaces naming convention. I
>>> thought in the score the CPU is the "package" and we logically
>>> associate 'subpackages' and their methods, like _CPU_Context_xxx(),
>>> _CPU_Exception_xxx(), etc. However, I see at least _CPU_atomic_Xxx()
>>> violates this, so I don't know what the right way should be by looking
>>> at the code.
>> Ok, if we use the rule _Package_name_Sub_package_name_Function_name, then
>> we
>> should use
>> _CPU_Counter_Read()
>> We should also adjust the CPU atomic API.
> Maybe we should drop the sub-packages.  This would lead to
> _CPU_Counter_Read() -> _CPU_Counter_read()
> _CPU_Atomic_Compare_exchange_ptr() -> _CPU_Atomic_compare_exchange_ptr()
> _CPU_SMP_Get_current_processor() -> _CPU_SMP_get_current_processor
Yes. I think this matches more closely what already exists with the
other "CPU_"-related methods. I'm OK with your suggestion, but you
should make this suggestion in a separate email thread since the
change impacts more than the new Counter API.
-Gedare
