rtems_clock_set() or rtems_clock_get() works on MPC5554 after building without -O2
Peter Dufault dufault at hda.com
Fri Feb 14 12:34:01 UTC 2014
On Feb 14, 2014, at 07:06 , Peter Dufault <dufault at hda.com> wrote:
>> which issues do you have?
> I wanted to get more details before posting.  The first thing I noticed is that either rtems_clock_set() or rtems_clock_get() isn't working properly (and isn't returning an error), so e.g. Task_1_through_3() in sp01 exits immediately because it sees that more than 35 seconds has gone by and exits.  The fact that exit() now calls bsp_reset() had me confused for a while, I thought things were really in bad shape until I realized that (and I checked, that detail is in the release notes).  I recompiled without optimization last night so that this AM I can figure out more.
Oh-oh, this isn't what I wanted to see after rebuilding without optimization.  With optimization on by the time the program printed out "**" TA1 would run, see 35 seconds had gone by, exit and call bsp_reset().
*** TEST 1 ***
TA1  - rtems_clock_get_tod - 09:00:00   12/31/1988
TA2  - rtems_clock_get_tod - T0A93: 0 - rtems_clock_get_tod - 00:90:00   012:/0310/   198812
/31/1988
TA1  - rtems_clock_get_tod - 09:00:05   12/31/1988
TA1  - rtems_clock_get_tod - 09:00:10   12/31/1988
TA2  - rtems_clock_get_tod - 09:00:10   12/31/1988
TA1  - rtems_clock_get_tod - 09:00:15   12/31/1988
TA3  - rtems_clock_get_tod - 09:00:15   12/31/1988
TA1  - rtems_clock_get_tod - 09:00:20   12/31/1988
TA2  - rtems_clock_get_tod - 09:00:20   12/31/1988
TA1  - rtems_clock_get_tod - 09:00:25   12/31/1988
TA1  - rtems_clock_get_tod - 09:00:30   12/31/1988
TA3  - rtems_clock_get_tod - 09:00:30   12/31/1988
TA2  - rtems_clock_get_tod - 09:00:30   12/31/1988
*** END OF TEST 1 ***
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
